LeetLauncher v3.0!!!
By leetcoder · Oct 11, 2008in Completed Mods/Themes💬 844 posts👁️ 380,404 views
Page 15 of 34
Posted Feb 21, 2009 · 13:19 UTC#351
Hi. I installed LeetLauncher and trying to use iGO. Installed maps..
Everything good, but there is no sound in menu, no voice etc..
How to enable it?
I tried to TURN ON sound in iGO settings but it's not helped me..
Posted Feb 23, 2009 · 01:20 UTC#352
Two things:
1) I know it has been discussed, but if a "script" or something could be written which would autolaunch our desired GPS, and then launch into AVIC, that would be awesome. I am trying to play with the binaries now, and see if I can't rig up something, but without the code I don't know how far i'll get.
2) Is this still being worked on? If not, any chance the developer would want to open source what he has done so that others might continue where he has left off.
Posted Mar 03, 2009 · 23:53 UTC#353
Hi,
I'm having problems with the stock nav TMC after using the igo8 nav from the avic launcher. There is no TMC info coming in when using the stock nav and there are no options to reconfigure/or force the stock nav to reset the TMC settings.
Anyone having the same here? or better a solution for my problem?
Posted Mar 05, 2009 · 08:48 UTC#354
Hack was quick and easy after sitting down and reviewing everything. Loads up IGO8 and it all works. However when going into Settings for Phone I get a wince popup that is unreadable and the unit resets. I'm assuming this may be known but wanted to let you know. The unit is an F700BT
Even not having those right now, hope to use them soon in the future, being able to run the 8.3.2 and some of the skins I found make it worth it.
I have noticed a combination of keys takes me into the Pioneer GPS on accident. I'll to mess around and get that to you unless you know about that already. I assumed you shouldn't be able to get to the stock pioneer gps but could be wrong. Thanks looking forward to future builds to make this more stable and faster.
I see the donation button on the front page, look for something nice from me to help the cause in the next week. Thanks again!
Posted Mar 05, 2009 · 08:50 UTC#355
I can only find iGo 8.3.1 maps for the US. Will these work with the iGo software included in this launcher, or must I find 8.3.2 maps? If the latter is the case, can anyone help point me in the right direction?
8.3 maps should be fine. Incompatibility is between 8.0 vs. 8.3 formats.
maps for 8.3.1 will work fine in 8.3.2, maps for 8.0.x will only work for 8.0.x. See PM I sent you
Posted Mar 06, 2009 · 16:16 UTC#356
updates anyone?
Posted Mar 07, 2009 · 04:59 UTC#357
I have a problem I download leet launcer and put it on sd card and have been using the igo8. But now when the sd card is in and when it is out if I try to use the stock avic navigation i get a error.
Any help?
Posted Mar 07, 2009 · 17:29 UTC#358
Hi
Anybody from Los Angeles, Orange County (california) area?? Please please please help me with this hack. I owned the 500BT, and with help from a wonderful gentlement (who owned the 90BT) from this forum, we were able to get our units up and running with the IGO8 through Leechlauncher. But once in the Leechlauncher, we could not go back to the Pioneer original software (AV, BT, IGO).. doesnt matter which sequence we follow, its stuck in the Leechlauncher. I played so much with the files (it crashed, I had to send back to Pioneer for reflash), but couldnt get any further. If anybody living around here can help, please let me know.... thank you
Posted Mar 08, 2009 · 23:05 UTC#359
is it possible to copy the files leetlauncher files to the flashdisk so that we could go to testmode anytime we want? if so, anyone knows how to do it?
Posted Mar 09, 2009 · 04:50 UTC#360
Any help?
Are you pulling the SD card out and trying to access the Avic navigation? If so you can't do that, you must turn the unit off, pull the SD card out and then turn back on and then it should work fine. Does on mine.
Posted Mar 09, 2009 · 15:31 UTC#361
Without reading 20 something pages, how practical is it to use this to get Garmin's interface for GPS, I hate the one that came with the F700BT. Im good at computers and will have no problem doing the mod, but is it buggy? Can you use the Garmin software in unison with your ipod or AM/FM seamlessly or is it a single application that you have to run and not run anything else?
Posted Mar 09, 2009 · 15:51 UTC#362
It's possible and Leet's put in the launcher. However, the Garmin app is still buggy...it drops the GPS signal after a few seconds. Leet says he's working on it.
Posted Mar 09, 2009 · 18:24 UTC#363
Gotcha, i'll just wait it out. Is the tomtom software still better than the pioneers?
Posted Mar 10, 2009 · 02:11 UTC#364
Hello, I tried out the new launcher, it's really cool - awesome work. The iGo8 looks great, unfortunately at least on the one trip I took, it gave me bad routing, about 100 miles around the long way. Luckily I knew a little better. I will try the tomtom and see if it does a better job.
I have one problem. After removing the SD card and going back to the original software, I get an error when trying to go to the map. The error box says that 746_32K_OM-065_32b.bmp cannot be found. Yes, the dash is correct, it's not an underscore. I tried copying the original data.zip back in, that didn't fix it. Any other ideas on an easy fix? I could probably just re-apply the 2.0 update but I was hoping there might be a simpler solution.
wm
Posted Mar 13, 2009 · 11:57 UTC#365
wm
So using leetlauncher you copied files over to your Avic unit? I don't have that problem and didn't copy anything to the Avic. I just installed LeetLauncher on the SD, put IGO8 on the SD card Booted pressed the IGO button, when IGO finished I pressed Menu button 1 time and then Down on the control knob everything done from the SD card. then I can play musc from the Avic. I don't think anything gets loaded to the Avic unless your putting in more current maps, poi, buildings etc. I stop the car, pull out the SD start back up and the Avic runs fine. If you copied anything to the Avic and you backed up first (always) put back all the original files on the Avic and see if it starts
Posted Mar 13, 2009 · 14:20 UTC#366
Well I didn't knowingly copy anything to the AVIC internal storage, I think I did pretty much just what you did, put the leet launcher on SD card, pop in, that's it. I figured out how to fix the problem though, I did the "restore factory settings" option from the Navi options screen (using original software) and that seems to have fixed it. I noticed that using the LeetLauncher I still had my favorites from the original software, and I did add to the favorites while in leetlauncher. I wonder if maybe the new software stores the favorites in a slightly different format? But after restoring the factoy defaults I still have my favorites, so maybe it is the settings file that's slightly different? Anyway it's working now. If only there was a setting for daylight savings time! I can't use the GPS time anymore....
Posted Mar 13, 2009 · 15:32 UTC#367
Hmm not sure, I have saved favorites routes etc without any trouble at all on either the Avic or the SD card. pretty strange or lucky me! Good Luck
Posted Mar 16, 2009 · 22:37 UTC#368
:D THANK YOU!! My Avic F700 with US maps, now works with European TomTom and IGO8 maps.Donation is transfered. :D
Posted Mar 17, 2009 · 03:43 UTC#369
Sorry everyone i've been pretty busy with other project outside of the avic community as well as doing stuff for work. Im working on updating the launcher so that it would automatically launch selected navigation software and adding extra features. I wasn't able to make good use of the pioneer library yet, but will let you guys know when I am successful.
Posted Mar 18, 2009 · 00:17 UTC#370
can't wait for the next update
Posted Mar 19, 2009 · 03:06 UTC#371
Same here, can't wait for the next update.
Glad to see you have not forgotten us
:D:D:D
Posted Mar 19, 2009 · 13:22 UTC#372
Excellent work!
Any chance on getting Iguidance 2009 working? It's the only GPS software that seems to have my 8 year old subdivison on its maps yet! :lol:
Posted Mar 24, 2009 · 11:01 UTC#373
Hello everyone, a big update to the Launcher is coming very soon... Sorry to keep everyone waiting. Some of the new key feature to the launcher will include:
1.) A Total Redesign of applications launcher including automatic launching
2.) CorePlayer (Modified and skinned for car used of Audio and Video). Thanks to xdng79x figuring out that switching Audio to SD allow full sound output source to the Windows CE.
3.) Easier Navigation between programs.
4.) Media Library Management (still in progress...)
For now here is 2 screenshot of the coreplayer.
Posted Mar 24, 2009 · 11:47 UTC#374
all i can say is wow
Posted Mar 24, 2009 · 16:33 UTC#375
:shock: Great job!!! :wink:
Page 15 of 34
