Hi Guys,
I just got an F700BT with the 2.0 firmware and I have downloaded the current Leetloader, and also the Tomtom 720.1803 maps. I have been trying to activate the maps. I get the Device ID from ttnavigator.bif, and type it into the commandline "utility" to generate the meta.dct file using:
tt7keygen "C:\tt7-stuff" "XXXXXXXXXX".
I copy both the .meta and the meta.dct file it generates into the folder with the maps on the card (overwriting the .meta file), and try it out in the F700. When I open TomTom, it trys changing maps to North America, however it says the activation is not correct. I have also tried the 7.25.1905 maps with the same attempt to use the device ID to set it properly, and had no luck either.
Does anyone have any suggestions as to what I might be doing wrong? Does anyone have a combination package of the TomTom software, and the appropriately registered maps along with it that I could try out without having to play with the command line activation?
If people arent comfortable posting on here, I would appreciate a PM.
Thanks, and your help is greatly appreciated!
