Keeper did you get my PM?
How To: Quick Lauch Buttons and other mods....
Sorry I just checked it.
to move the boxes you will have to find wherethere is a reference to 746_32K_OM-003_32b.bmp and 746_32K_OM-005_32b.bmp and then look around and see what else it there that you have to move ie (arrows and text)
here is my code but I am not sure it that is where you want them. I believe you will have to move everything in the ui_NavigateMapRouteNavigation layer.
note there are refrences to another font, so unless you have my same set up you will only want to use the x and y values. ;corner picture ;road arrow
Ok I got all of this perfect except for the second, smaller arrow millage distance at the bottom of the green box. The arrow is fine but the milage distance text is slightly overlapping the arrow. I need to move it a little to the right and I cant seem to edit the right code to move the distance milage text. Help me with this and I will be done.
Nevermind, I figured it out. ![]()
lilngineer if your still around PM me, Im interested in some of your mods.
Here is lilengineers data.zip plus original fonts
http://www.mediafire.com/?sharekey=f020 ... b9a8902bda
Never used this site before so get it while you can.
Hey Keeper,
I'm using your zip and looks great but I have a couple problems I'd like to figure out.
1.) My arrow has dissapeared after uploading your files. ![]()
(edit: oops, read back in the thread a bit and found this fix)
2.) My map is perma zoomed out and auto zoom is not working.
Can you (or anyone) help me out with this?
Thanks, and awesome work on the ui mod. ![]()
Ok zoom problem seems to be resolved, must have been a glitch as it's now working ok.
Alright now I am having some trouble getting it working on the avic. Everything works fine untill I hit the map button then the unit just keeps rebooting. I noticed there were other files besides the data.zip do I need to do anything with those. I just copied your data.zip file to my sd card then replaced the data.zip file on the avic with yours, is this the right way to do it? Any help would be greatly appreciated. Thanks in advance.
yea you need all the files... copy them all to the same DIR!
This is from Pg 2, I've read this post over and over and still have this same problem, with all the Data.zip posted so it must be something I'm doing wrong. What other files do I need to copy??? I've seen the SYS file mentioned here somewere, is it a modified SYS???? where do I get it???? sorry if this are all dumb questions I really want to get this mod working on my 700BT. Help will be apreciated.
Bump
O sorry about that windows error, I will get rid of that. I removed someone else's mod from earlier that showed longitude and latitude when you press the current street. I never used it...
But I forgot to get rid of the button's action. It is a quick fix and I will repost the data file when I do it.
What do we need to add if we want the LAT/LONG to show?
Add this:
run 'MSC_Lat.x 200, MSC_Long.x 200'
run 'MSC_Lat.x 1200, MSC_Long.x 1200'
add this to "scripts_800_480.ui" file
I did that but I am getting the error message:
FFUI Error: unknown object identifier
Identifier=[sc_msc_showPOS] script "[unnamed]" commandO
Thanks for your help!
Add this:
Plus you'll need to add this to your navigatemap800_480 file. You''ll need to adjust the "Y" position to your liking though.
and add the onrelease part of this script to the button bmp
That did the trick. Thanks for your help!
You're welcome. Glad I was able to help.
Okay, I did this mod and I am getting an FFUI Error box when I touch the house numbers.
It reads" Unknown Object Identifier [uI_housenumbers] script (unamed) command 4" . Also, in the lower left selectable boxes, if I change one of them to "speed" it reads Km/hr but a couple of screens back and forth and goofing with it it will come back as MPH.
What is this and how do I correct them??
Thanx,
Bud
