Thanks Kevin!
How To: Quick Lauch Buttons and other mods....
Well i think I ironed out the little windows errors people were getting. A couple scripts got skipped when I was trying to combine Boris's mods and mine.
I updated the link a few pages back and here it is again if you are too lazy to look for it
Let me know if there are any other errors and I will try to work them out.
Thanks Keeper..... works good.....
Hello -
I am still seeing the script error noted above with the most recent data.zip. Everything else seems to work fine, but when I touch the bottom left icon by the street address is when I get the error.
Also, oddly, I have neither an arrow or a truck in 3D mode for Nav. I have a teeny tiny dot, barely noticeable. I searched and confirmed daycar.bmp and nightcar.bmp were OK - they are - not sure if there is something else to review for 3D. This is something I have never messed with. If I switch back to my old data.zip, the arrows come back. I *think* I just need to edit sys.txt to remove the 3D stuff. Correct?
AND THANKS. My biggest complaint about this unit has been the amount of presses needed to access some areas and the time eyes are off the road - this solves it perfectly.
Keeper, I'll send you my version, it's working good all except the language thing... were you able to fix that?
I think Boris would be able to answer that best, you should see if he could help.
I still get that windows error touching the bottom left icon...
OK I removed the 3D lines from the sys.txt, that fixed the issue with the icon. Woohoo.
One other thing.......does anyone else have a problem with the "tilt" feature on the 3D screen after doing this mod? Mine doesn't seem to respond at all.
sorry I took that out because I never use it, I will show you how to add it back. later when i have time.
To all who PM and requested my data.zip file I have sent it to you via email. I would appreciate if someone could post it for others.
What did you have to comment out to get rid of the "displayed info" box that was on top of the quick launch buttons? I searched through the file for a pointer to the pictures it appears to use, but no luck.
Keeper,
I had one of your older data.zips that had the F150 and I just got the one you posted a couple of posts up. Will I have my red arrow back or no?
thanks man
Keeper,
thanks man
If you just have a single "dot" in 3D now, just edit out the 3D lines in the sys.txt from the original downloaded files.
I have Keepers 11-20 data zip and its working great. Thanks for all your hard work Keeper !!!! But I have the arrow in 3D and nothing in 2D. Anyone know how to get the arrow back? I've been trying to figure it out for a few days, LOL
No ideas on how to get rid of that box in the bottom left corner?
sorry I took so long if you want the tilt feature back
I believe the layer you need to find is :
and change it back to this:
Got the new HTC Fuze and I have been modding that, just as fun as here.... can't leave anything alone.
keep,
i just put on your latest upload and I lost your f150 and now dont have any cursor. do you know how the other guy that had the problem got it back?
OK I figured out a handful of things based on some of the questions above. I'll send my data.zip in PM only if someone else wants to post it. Mine has the original 10 shortcuts which I like. All credit for this still goes to Keeper - this is all very minor touch up.
To add the 3D Tilt back if you miss it - see above. That and each of the edits below are in the navigatemap_800_480.ui file.
To fix the script error, simply add a semicolon. The button on the lower left is supposed to display latitude/longitude when pressed. I have never used this, so I just turned it off - script error is gone. Search for the following, and ADD the semicolon in red to comment it out (or just delete the entire line).
;*** When current street icon in lower left is pressed, current Lat/Long will be displayed ***
To move the StopNav button so the Ipod doesn't cover it, just change the X and Y axis.
Original:
;Stop Nav Button
Edit to be:
;Stop Nav Button
If you don't like where I put the button, then just play with the X (horizontal) and Y (Vertical) numbers til you hit the one you like.
or you could have fixed the error by adding code to the scripts_800_480.ui
This one kept blowing up on me also.
Search for
; *** When current street name is pressed, destination menu will be brought up ***
and replace with...
The latest data zip had these last changes right?
As of a couple of days ago it did...
I have another favor to ask, I would like to press the compass and have the itinerary pop up. I cannot figure out how to do it. Can you post "find" and "replace" code so this can work?? Thanks in advance!
Also, how can I keep the buttons showing, I do not want the hide option.
See the instructions for the "Compass/Detour Mod" in this thread (it's the 3rd or 4th post):
I did look at this, but with the data.zip file from keeper, I do not see that line, as he put in a custom compass (which rocks!!)
