How To: Quick Lauch Buttons and other mods....
By keeper22 · Nov 10, 2008in Hacks/Mods💬 192 posts👁️ 42,037 views
Page 5 of 8
Posted Nov 21, 2008 · 23:47 UTC#101
I already did...
For some odd reason its not showing up. :roll:
Posted Nov 22, 2008 · 01:26 UTC#102
Kevin, the new DATA.zip is corrupt, when you get a moment can you repost, thanks again!
Posted Nov 22, 2008 · 01:29 UTC#103
Well I waited a few moments and i worked again, must have been a glitch in the server
Posted Nov 22, 2008 · 03:34 UTC#104
it is a page back
Posted Nov 23, 2008 · 02:38 UTC#105
Hmmm, for some reason the new data.zip crashes my F90BT. I'll have to do some diff'ing later and see if I can just graft some of the known good changes into my data.zip instead.
Posted Nov 23, 2008 · 02:52 UTC#106
mine works fine just when I click on the street name I got an error other than that is perfect thanks keeper
Posted Nov 23, 2008 · 03:04 UTC#107
Mine crashes too..... Hmmm... Is there a data zip for lilngeneers mods too? I really like that set up...
Posted Nov 23, 2008 · 03:13 UTC#108
The only error I see is the bottom left corner where is shows what streeet I'm on... gives me an error when I press it.... with Lava's DATA.zip it went to the destination folder... with yours I get a windows error.....
Thought I'd let you know.....
Posted Nov 23, 2008 · 03:22 UTC#109
OMG....
so my car has been parked for a month or so. I thought i had my F90 set the way i wanted it. WHAT happened There are so many new Hacks I dont know what to do first!!!!
Posted Nov 23, 2008 · 15:14 UTC#110
will F700BT show speed of car using keeper22s mod (left top corner)?
Posted Nov 24, 2008 · 01:36 UTC#111
So guys, I need help....
I downloaded Kevin's file and replaced the Data.ZIP file and the SYS file. I deleted the original SYS file and forgot to make a copy to keep...oh well.
Anyway, the system boots up but when I press the MAP button it restarts over and over and I am never able to get it going.
So I used the DATA.ZIP file from Bman69 and got the same result.
I am missing anything?
BTW, I have a 700BT
Thanks in advance.
Posted Nov 24, 2008 · 02:57 UTC#112
BTW, I have a 700BT
Install Keepers Data.zip, sys.txt and the 3 font files.... They are all in his zip on the first page.
Thanks in advance.
Posted Nov 24, 2008 · 06:55 UTC#113
BTW, I have a 700BT
Thanks in advance.
Thanks!! That did it!
You guys rock. Keepers, you're da bomb!
Posted Nov 24, 2008 · 15:16 UTC#114
O sorry about that windows error, I will get rid of that. I removed someone else's mod from earlier that showed longitude and latitude when you press the current street. I never used it...
But I forgot to get rid of the button's action. It is a quick fix and I will repost the data file when I do it.
Posted Nov 24, 2008 · 16:08 UTC#115
hey Keeper, I also got an error when toggling with a route between the ETA and the Remaining Time to destination. Can anyone else get this as well?
Posted Nov 24, 2008 · 16:40 UTC#116
Keeper you also seem to have the same issue as i am in settings... go under settings, system settings (one to the right of navi settings), language... try to change the language or voice... the unit crashes... I dont know why, I have the same issue in my version, and im trying to resolve it...
Posted Nov 24, 2008 · 23:05 UTC#117
keeper, i found another bug in yours (I dont have it) the blue box which has time to dest/distance/speed it is a button that points to [unamed] it gives a windows error, maybe just remove the button? or have it point to results ?
Posted Nov 25, 2008 · 15:37 UTC#118
lilngineer - would you mind sharing your data.zip. I really like the cleaned up look and the street color signs.
Posted Nov 26, 2008 · 04:28 UTC#119
Jason everything installed perfectly! You and Keeper have put together what Pioneer should have released in the first place! Thanks again!
Posted Nov 26, 2008 · 18:25 UTC#120
I would be happy to send my file via email to anyone who wants it. Just send me a PM.
I tried to post it, but I keep getting an error that says empty file.
Maybe because its over 5MB?
Posted Nov 26, 2008 · 19:10 UTC#121
Looks good lilngineer! Do you have a mute nav button on there anywhere I'm missing? Eitherway, I'd love a copy. PM'ed.
Posted Nov 26, 2008 · 23:39 UTC#122
Are you using that same arrow or the original 3d arrow?
Posted Nov 27, 2008 · 00:13 UTC#123
Hi lilngineer maybe you can use my account with rapidshare to post any file you want so anybody can download included me :D just send me a PM if you want.
Posted Nov 27, 2008 · 00:23 UTC#124
Well i think I ironed out the little windows errors people were getting. A couple scripts got skipped when I was trying to combine Boris's mods and mine.
I updated the link a few pages back and here it is again if you are too lazy to look for it
zip
Let me know if there are any other errors and I will try to work them out.
Posted Nov 27, 2008 · 00:45 UTC#125
Thank you keeper.
Page 5 of 8
