Using Europe Map on US F900BT
By ydokter · Nov 12, 2008in Hacks/Mods💬 181 posts👁️ 65,930 views
Page 3 of 8
Posted Jan 05, 2009 · 03:10 UTC#51
Boris,
There are both the 2d and 3d visualization....i tought that this was his doubt..
GUGA
Posted Jan 05, 2009 · 04:00 UTC#52
Boris,
GUGA
Right, but still, new maps would not give him any different display...
Posted Jan 07, 2009 · 04:27 UTC#53
Ok, just want to get an understanding on this. I downloaded the file named "ir" from rapidshare, along with a license. I placed the license in the license folder next to the other one. Now am I to simply copy this onto the flash memory of the AVIC?
If so, will this replace or alter any modifications that may currently be on my unit?
And is my ending result the most updated maps?
(All I really want is an updated map, since there are problems and alot of outdated things with the current map file I am using on my unit.)
Posted Jan 07, 2009 · 15:14 UTC#54
Yes - If you copy the licence file and and the hacked eazyrider.exe to the flash memory, you will be able to use updated maps...
But you still have to buy (or find) new maps. If you are not too worried about copyright issues, they can be found on the internet in version 2008.10.
As mentioned elsewhere in this thread make sure to look for IGO8.0 maps, as IGO8.3 wont work.
Posted Jan 07, 2009 · 17:50 UTC#55
Can we use a license file and maps from a handheld version? I am having trouble locating maps and license files.
Posted Jan 07, 2009 · 18:10 UTC#56
Yea, they are all the same. I used the same maps i had on my WM6 phone.
Posted Jan 07, 2009 · 18:33 UTC#57
I also heard people deleting maps they won't use(such as Europe, etc..) to make the unit go faster.
1) Does this actually work?
2) If so, where are the actual map files that you can remove?
Posted Jan 07, 2009 · 18:41 UTC#58
Yes you can do that and it does work. The maps are in APL2\Igo\content\maps
Posted Jan 07, 2009 · 18:49 UTC#59
Except, of course, for the fact that US-spec units do not have Europe maps on them, and deleting state maps will not make anything any faster anyway...
Posted Jan 07, 2009 · 19:58 UTC#60
So it would be on a state-by-state basis? Ah, it's not worth it. I'd probably end up lost in some state that I deleted one day and my GPS wouldn't be able to help me.
So back on the subject of these maps-- Why can't we just download the map file? Do the newer map data files require all the other things(inside the ir zip) we need to put on the unit as well?
Posted Jan 07, 2009 · 20:06 UTC#61
Maps require an appropriate license file to be used. EZRider on the unit works only with Pioneer's license file which in turn only works with maps Pioneer gave us. Hacked EZRider works with any iGO 8 license file, so you can use newer maps until Pioneer gives us an official update...
Posted Jan 07, 2009 · 20:17 UTC#62
Ahhh I see. Thanks much for the explanation.
Posted Jan 07, 2009 · 20:34 UTC#63
2008.4 seems to be the lastest available...or am I missing something?
Posted Jan 07, 2009 · 20:42 UTC#64
You're welcome.
Posted Jan 07, 2009 · 21:29 UTC#65
Cheers everyone, updated my UK map to 2008.1, works a treat.
Posted Jan 08, 2009 · 21:36 UTC#66
superbbbb!!!
i have update 2008.07 map to my avic f500BT
the ezerider patch works perfectly ! :D:D:D
now i am on the search for the rest of europe maps thanks to all !
Posted Jan 09, 2009 · 23:34 UTC#67
I got the ezrider and license file on the unit, but I wasn't able to get the DATA and SYS because it conflicted with my modifications. However, the unit still booted up fine. Will I notice anything different with that version of EZRIDER?
Also, why in SYS does it say
[device]
type="ASUS 63X"
Posted Jan 10, 2009 · 03:13 UTC#68
[device]
type="ASUS 63X"
You have a very wrong SYS.TXT...
Hacked ezrider is identical to Pioneer's one in every respect except for license support...
Posted Jan 10, 2009 · 14:50 UTC#69
Hmmm, odd. I got that sys.txt from one of the links in here. Is there much different in the file? If someone could tell me what's in there I could just add it myself.
Posted Jan 10, 2009 · 19:42 UTC#70
Started a new thread on 3D Buildings as a how to with files linked.
Sys.txt and the data.zip are there as well.
Posted Jan 11, 2009 · 12:21 UTC#71
I've updated my uk maps from 2008.01 to 2008.07 but both show in the map info list. When I updated from 2007.10 to 2008.01 the 2008.01 maps was the only one that showed. Does this mean 2008.07 maps aren't working?
Cheers
Posted Jan 11, 2009 · 13:23 UTC#72
Cheers
i think 2008.7 maps need to be patched to work on (older 8.0.0.xx) igo versions..
from another forum: """iGo8 2008.07 Map Patcher [RapidShare]
use it to patch 2008.07 maps to make them work with 8.0.0.49545 version, caution: may cause street search error"""
Posted Jan 11, 2009 · 13:39 UTC#73
Thanks wenigwiser
I installed 2008.4 maps ok, will try the patch later.
Cheers
Posted Jan 12, 2009 · 16:47 UTC#74
yupeeeee . i have update my f700bt maps ... with romanian map 07.2008
Posted Jan 16, 2009 · 18:29 UTC#75
Is anyone able to post the maps for Europe. I know it's a lot to ask but having it broken up and incomplete on rapidshare sucks.
Page 3 of 8
