Okay, I placed the tripcomputer UI file in my datazip and it doesn't boot past the start up screen. I did change the file name to 800_480 and commented out the trip computer I created just to be sure they didn't conflict with each other.
I would think there should be 2 files:
tripcomputer.ui <- goes into COMMON folder
tripcomputer_800_480.ui <- goes into 800_480 folder.
That should get it father along...
Neither the Gurjon or kiker zips had common tripcomputer ui's. I found another on that did have both. Installed both and can't get past the start up screen.
Do you want me to PM the two files to you or post them here?
Whatever is easier.
I've also found where I keep NavNGo's original trip computer files. If Gurjon's skin does not make any changes to the common's tripcompouter.ui then it would not be included into his skin, and iGO will use one from default DATA.ZIP.
The skin that has both might use some custom codes that need the rest of the screen... I could take a look at it...
