Wiring help here if you need it.
By theE40punisher · Jan 22, 2009in Vehicle Specific Wiring💬 67 posts👁️ 21,274 views
Page 2 of 3
Posted Jan 26, 2009 · 23:38 UTC#26
Ummmmm, I think so. It sounds right. It does not say you have amps. Im assuming you do so yes. I have not used that harness so as long as it makes its own door chime in the harness module you should be good to go. If it is like the metra one that routes the chime through the speaker then no!
If this does not help or if your confused then PM me and ill review all your parts and go from there.
E
Posted Jan 26, 2009 · 23:54 UTC#27
Tell me what part number you ordered. Most all give you the VSS and E-brake in the wiring harness. I use the metra GMOS01 and it does the data conversion and gives reverse/VSS/E-brake all in the plug behind the radio.
if not then the
VSS is GREEN/BLACK AT PCM. PCM IS IN THE FRONT LEFT OF ENGINE COMPARTMENT.
E-BRAKE IS LIGHT BLUE ANT THE FOOT BRAKE (E-BRAKE) SWITCH. IT SHOULD BE ATTACHED TO THE TOP BACK OF THE BRAKE ASSEMBLY.
E
Posted Jan 27, 2009 · 00:13 UTC#28
I wasn't clear in my earlier post, I will be adding an amp and speakers at the same time as the pioneer(no amp in truck now). Do I still need the same chime adapter, then wire preamps to amp , not connect factory speaker harness to new headunit, and just run new speaker wires from new amp?
Tom
Posted Jan 27, 2009 · 01:23 UTC#29
From what I read on the PAC CR2-GM24 is that it makes the chime from its own little box, which is good for you. just hook it up as it says. Just yellow, red, black, and then do not connect the speakers out from the radio. Tape them up. Run the remote and RCAs and hook up the 4CH amp output to the car side of the of the speakers. so the amp plays its output into the car side of the wiring harness and it will go out to all the speakers. Just make sure the radio outputs are NOWHERE in the loop or you will burn out the radios output stage and it will smoke.
Sounds like you know whats up.
Hit me back if you have any other questions.
E
Posted Jan 27, 2009 · 02:56 UTC#30
I ordered the PAC SWIPS, CM-1, OS-2 Bose. Thanks.
Posted Jan 27, 2009 · 16:43 UTC#31
Thanks a lot. I think I'm going to order all my stuff today. I'm thinking about doing everything at once, f90bt,5 channel amp,sub, component speakers in front, coax in back, maybe even headrest monitors. I'll let you know how it turns out.
Tom
Posted Jan 28, 2009 · 00:34 UTC#32
hello, i have a couple questions.. i have an 07 cobalt SS supercharged and was wondering where the vss wire and reverse wire are? im going to be putting in the f90bt and i had to buy the gmos lan 4 wiring harness to keep onstar and my pioneer 7 speaker system and door chimes. and also, i bought the pac swi-ps and im confused on one of the parts on the instructions.. it says: Connect pin 14 (white/black) in connector 2 to +12v accessory. im guessing i have to tap into this wire? but how? thanks alot
Posted Feb 01, 2009 · 23:42 UTC#33
theE40punisher, I've received my f90bt, waiting on adapters,speakers and amp. I went with a Profile ap740 (4 channel) and 4 reference component 6020cs. I'll add a mono block and sub later. I've already moved the mute wire in the plug. I think I'll install the headunit and run rca's behind back seat for amp and then pay for amp and speaker install. I want to add headrest monitors at some point and will run component video cable with preamps. My question is how do I get audio to the monitors? I didn't see any plug for this on the back of the unit. I guess since the f90bt is not dual zone most people just listen through the sound system, but on long trips that gets annoying. I'm starting to think it may be better to just add a 2nd dvd player in back and be done with it.
Tom
Posted Feb 11, 2009 · 11:35 UTC#34
Hi Punisher!
Can you tell me where to find the vss wire on my 1995 JDM 300zx tt.
Should I be looking at the ECM or behind the instrument cluster. I've been told it should be a yellow/green wire, is this correct?
Many thanks,
Ade.
Posted Feb 11, 2009 · 16:19 UTC#35
I am working on an 07 GTI, trying to install the f900bt. I bought the metra wiring harness from circuit city yesterday, but apparently the system is turning on by itself with no key in the ignition switch.
Its just always on and I can't turn it off. Can you help me with which wire I could fix this with?
Posted Feb 12, 2009 · 04:29 UTC#36
RATATTACK!! My info says VSS is Yellow/Green at I/P connector.
So it sounds like your good to go!!
E
Posted Feb 12, 2009 · 04:29 UTC#37
JPerez2008, I will PM you
Posted Feb 12, 2009 · 12:27 UTC#38
Punisher!!
Thanks for confirming my question, it's a great help. One thing though, when you say I/P connector, I presume you mean the big plug that fits into the ECM?
Oh yeah, forgot to ask if you happen to know the colours of the reverse gear switch/wires.
Cheers mate!
Posted Feb 13, 2009 · 01:07 UTC#39
It should be behind your instrument cluster. Reverse wire is---GREEN/WHITE in the DRIVERS KICK PANEL. VOLTAGE IS (+)
E
Posted Feb 13, 2009 · 11:39 UTC#40
Thanks again Punisher, you've been a great help, keep up the good work mate!
Regards,
Ade.
Posted Feb 14, 2009 · 00:54 UTC#41
Looking for info on a 2009 Rav4 non limited non JBL.
Installing a D3.
Also looking for info on a 2008 F150 Limited.
Thanks in advance.
Posted Feb 16, 2009 · 08:09 UTC#42
I have a 2002 Mazda Protege 5. Looking for VSS and Reverse Circuits. Any chance your magic screen still works? Thanks in advance. It's an awesome thing you're doing.
Posted Feb 19, 2009 · 02:55 UTC#43
Hi,
Do you know what kind of harnesses i will need to hookup AVIC-F500BT to 2008 Toyota Highlander?
Thank you!
Posted Feb 19, 2009 · 12:31 UTC#44
Looking for VSS and Reverse Circuits for a 2005 Ford Freestyle. Any help is greatly appreciated.
R
Posted Feb 21, 2009 · 06:19 UTC#45
I have 1997 ford explorer and tomorrow i am installing the avic-f900bt. Could you tell me where to hook up the speed sensor and the reverse senor on this vehicle. Also could you tell me the color of the ire i need to hook up to
Thanks-you inadvanced
Posted Feb 22, 2009 · 21:34 UTC#46
I installed a 90FBT in my 08 Tundra Crew Max and I had to use a premium sound interface for the JBL speakers in the doors to work. The issue is the harness does not connect the illumination wire from the rear of the head unit to any harness. Could you help me find the illumination wire for a tundra w/ JBL. Thanks.
Posted Feb 23, 2009 · 05:06 UTC#47
Has Factory Bose. Factory Nav. Factory CD changer, single Cd and cassette. if it matters
Posted Feb 28, 2009 · 04:33 UTC#48
Former CC employee here too....
Im installing a F90BT in my 08 F250 tommorow. Need the VSS and Reverse Signal wire color and locations.
are these necessary?
Posted Feb 28, 2009 · 09:00 UTC#49
:? can you help on an install for a 2001 VolVo V70, no factory navigation OEM radio still installed. I need the VSS, Illumination and the Reverse wire locations. Battery is at the rear of the vehicle. I'm not sure if I should purchase the Pioneer ND-BC2 or Audivox. What would you recommend? How about Satellite Radio? I know Pioneer makes the HD, XM,and Sirrius Adapters. Preferences anyone? Thanks awaiting Help Please!
Posted Mar 02, 2009 · 00:10 UTC#50
Looking for VSS/reverse on a 2009 Honda Fit Sport (MT). Thanks in advance!
Page 2 of 3
