Wiring help here if you need it.
By theE40punisher · Jan 22, 2009in Vehicle Specific Wiring💬 67 posts👁️ 21,274 views
Page 3 of 3
Posted Mar 28, 2009 · 04:30 UTC#51
Nice, hope you can help me out
Maxima 2007
I am trying to find the VSS wire, reverse wire and speed pulse wire
Posted Jul 12, 2009 · 02:28 UTC#52
Looking for help on a 2009 Toyota Tacoma vss/reverse wire and also any info on the stock gps receiver on the roof. I am wondering if I can use it with the avic-f90bt receiver instead of the one that came with the stereo. If so can I get to it without take aprt the headliner. Thank You.
Posted Jul 22, 2009 · 03:29 UTC#53
Just FYI. I am a 15 year Circuit installer that just found out im going to be jobless. Because of the buyout of the company, the new company has given me home access to the Firedog wiring database for the next few months to do service work. SOOOOOOOOOOO,
if anyone needs some help with wiring color/location on speakers, VSS help or remstart, just ask! I would like to help out as long as I can.
E40
Do you have the wiring diagram for the PAC C2R-FRD1 any help would be great thanks
Kirk [email protected] It's for a 2009 ford musstang
Posted Jul 22, 2009 · 15:57 UTC#54
How about the vss for a 09 ford escape?
Posted Sep 23, 2009 · 04:12 UTC#55
can you tell me where the vss wire is on an 08 cobalt ss by chance?
Here is the tech info from directed. it says catch vss at wheel sensor
Posted Sep 23, 2009 · 04:15 UTC#56
Brown/Green
PCM, plug towards driver side, pin 3 or 25
The PCM (Powertrain Control Module) is in the engine compartment, in the center of the firewall. This wire is not available on Hybrid models.
Posted Sep 23, 2009 · 04:24 UTC#58
Maxima 2007
Speed sense is Brown Unified Meter and A/C Amp, gray 16 pin plug, pin 6
The Unified Meter and A/C Amp is in the center of the dash, below the radio.
Reverse Wire Green/White ( + ) positive in driver kick, harness to rear
Posted Sep 23, 2009 · 04:28 UTC#59
MECP Installer 1st class here
If you guys have any questions please dont hesitate to ask. If u need wire colors and locations lmk aswell. email me and lmk u put a request on the forum and i will get to it asap. [email protected] also have access to all harnesses and dash kits
Posted Nov 10, 2009 · 23:21 UTC#60
I have a 2001 Lexus IS 300 and I can't find the VSS wire. Also I have grounded the parking brake wire, but do not know what to do with the mute wire to complete the bypass. Please help!!!
Posted Nov 17, 2009 · 17:10 UTC#61
Can anyone help with the location of the reverse signal in a 2008 dodge charger se plus.
Posted Feb 02, 2010 · 03:32 UTC#62
I installed a Pioneer x710bt Nav system in my 2007 Lariat. I used a Scosche wiring harness and also the SW-PSI steering wheel control adapter. Everything works smoothly now, except one thing. My ABS and Parking Brake lights on the dash stay on. I am sure I must have screwed something up, but I have no idea what. Does anyone have any ideas where I could have screwed up?
Posted Mar 17, 2010 · 20:38 UTC#63
this is my first navigation installation z110bt on 08 nissan frontier (w/o rockford system) and i have a few questions. i found 2 options for the VSS #1 pin 6 at instrument cluster (07frontier post) #2 Lt.blue at radio harness (05frontier post) any suggestions??? since im new to nav not exactly sure what to do/where to locate: reverse light/gear, parking brake, illumination, etc. any info will help
Posted Mar 29, 2010 · 12:39 UTC#64
E40
I have 99 Chevy Astro 2wd. and according to the VSS locator link, it discribes it as GREEN/WHITE. Well when I connected to it (in 3 different places) it did not work! I have an acctual GMC data base for the van and it discribes the LOW end as GRN/BK High end as PUR/WHITE...can you confirm this for me!
Posted Apr 17, 2010 · 05:13 UTC#65
VSS wire location 2007 Ford Sport Trac.
Its not in the radio plug..back/grey as there is no black/grey there.
Any help would be appreciated
Posted Oct 03, 2010 · 19:18 UTC#66
hi guy's, I have a 99f150 that has a avic n3, i've added the bluetooth adapter(cd-btb200), GEX-p920xm, and ipod adapter. i just added the bluetooth and xm. followed install instructions and also had the main unit and hideaway installed by the electronic shop i bought it. Anyway, they didn't hookup the reverse signal so i need help to find the right colour, also all the accesories work except the blutooth. Its got power, but i think my daisy chain instalkl maybe wrong as i couldn't find a diagram to show me how to do it. So from the hideaway blue ipbus to xm in black(out) ipbus, then blue(in) to black ipod. Am I supposed to then connect from the bluetooth back to the ipod adapter.
Help quickly please, i have a physical disability that limits me, so i have to make hay while the sun shines, so any quick replies would be really awesome, as it took me most of yesterday to hook it all up, then the next question am I allowed to trim the power leads as they're quite long and the manual says not to cut them as they'll overheat. I've never heard of that before.
Thanks in advance.
Andrew
Posted Oct 19, 2010 · 19:10 UTC#67
2010 F250 Crew Cab
Looking for a reverse wire other than the taillamp (hopefully something in the dash area) for my AVH-P4100DVD.
Page 3 of 3
