OK everything is fixed, I just deleted the zip out and copied it back in and now my phone works and the voice commands work fine. I must have done something wrong, stupid me.
so does this zip have the speed cam mod ?
dont I get a thanks for posting the damn thing??? HAHAHAHAHA kidding...
ABSOLUTELY!!! You the man!!! Or Woman?!
Ceger
I believe so, but you might need to copy the speedcam txt files yourself (get from BorisM's thread) into the APL2/IG0/CONTENT/SPEEDCAM directory.
Humptystyg can confirm, though he told me that copy the items of the zip into the IG0 folder will do it all, but he has no txt files for cameras and I do not see the enable_speedcam = 1 setting in the debug section of the SYS.TXT file.
Ceger
Ceger
Will I still don't see an option to turn on the speed cam under the warnings icon in settings, I did move them files into the content/speedcam directory but still no option in my settings to turn it on.
Hey folks, I see some of you have loaded my Data mods, and I also see there are a few probs.
The 'Enable Speedcam' button should still be there, I've done nothing to that part of the content, it's only the warning layout/position/.bmp that I've altered - works fine on my unit.
There is no reason why BT should be a prob, this was also untouched in my mods - again, it still works fine on my unit.
All of my mods are basically superficial, altering .bmp images, positions of buttons/icons, changing font/size/text. I haven't delved into anything serious, I'm not that good anyway!
Anyone who has loaded this and has not had any probs?
Ceger
Try adding speedcam_enabled=1 under the [debug] section of the SYS.TXT file.
Ceger
Hennessy, where are you located?
I'm in uk so I'm using the Poicon Speedcam prog for Europe, I'm guessing you are not in EU so there may be some difference if you are using Boris' Speedcam mod (for US). Maybe Boris has ideas on this?
I think the only difference in speedcams between US and EU is that you should have it activated by default, and we don't...
Also, no DATA.ZIP hack can have any effect on BT -- they are handled by entirely different software...
Ok I have it working now, I had to download the ui_pioneer folder that Boris has a download for, then place them in the AP2/IGO folder now it works. I am in TN USA
Thank you everyone, everything is now up and running
It might just be me but it also seems to boot up faster now
Glad you sorted it Hennessy, hope you like the new mods ![]()
And thanks again Boris, you really are a wealth of information ![]()
One thing I'm not happy with and still trying to sort, is the Speedcam icon in the warning box when in Night mode; it's a crappy red coloured thing and doesn't look at all right, so I'm gona try and change it to the same one as shown in Day mode.
And thanks to Ceger and basstoy for your recent help with this topic ![]()
To:-
Parekh1926,
paq,
robertkirkland
Thanks for your PM's, I'm having probs as I cant send replies for some reason?????
paq, I will post some screenshots shortly.
robert, I think the limit is 2MB but as I can't reply maybe it would be easier if you PM your email addy.
Mark ![]()
Happy to help ![]()
Thank you Boris for all your hard work, I just tested out the speed cam in Knoxville TN and it works Perfect. Now maybe i'll pay attention and not get anymore tickets. ![]()
You're welcome.
I would not necessarily assume that it a) lists _all_ the cameras and
camera speed limits are accurate.
Still, better than nothing.
WOOHOO smiles all round
You're welcome.
I am having an issue whenever I try to get the Speedcam mod going. I have loaded dumpystig's items, moved in the place and setting UI files from your zip, updated the SYS.txt to have the speedcam enabled under debug and copied the large speedcam.txt file you posted into the flash's APL2/IG0/CONTENTS/speedcam directory.
Every time I boot the system it shows the "System Startup In Progress. Please Wait" message for 5 minutes and then proceeds to reboot over and over. When I go back in to check the APL2/IG0/CONTENTS/speedcam directory, I see a new file is made (I assume the database file it creates) along with the speedcam.txt file and pre-existing speedcamupdate file.
Not sure what is going on or if I am missing something, but the only thing I can do at that point is rollback to a data.zip and sys.txt with no speedcam.
Any help appreciated.
Ceger
Hey Ceger, I'm sure Boris will sort it out, tbh I aint got a clue LOL. How you gettin on with the mods, everything else running ok with them?
getting nowhere fast. ![]()
Ceger
Hmm, is it just the Speedcam mod your having trouble with, or you got other probs too?
You pretty much described a crash. Paste the contents of the crash file on here, as long as it's not 10 pages long. I think the most current instance would be the top portion. It may provide clues as to why it crashed.
The file should be in apl2 as a text file titled "crash".
