DUMPYSTIG's mods... FTP
By basstoy · Feb 20, 2009in Hacks/Mods💬 114 posts👁️ 16,929 views
Page 3 of 5
Posted Feb 21, 2009 · 01:05 UTC#51
You pretty much described a crash. Paste the contents of the crash file on here, as long as it's not 10 pages long. I think the most current instance would be the top portion. It may provide clues as to why it crashed.
The file should be in apl2 as a text file titled "crash".
Did not know that. I'll take a look. Thanks.
Ceger
Posted Feb 21, 2009 · 01:06 UTC#52
Hmm, is it just the Speedcam mod your having trouble with, or you got other probs too?
Posted Feb 21, 2009 · 01:14 UTC#53
It says "WinCE CallStack snapshot (function names unknown - map file \My Flash Disk\APL\..\APL2\iGo\ezrider.map not found):"
Looking at my flash backup, I never had that file, so some modification for the SpeedCam must be calling it?
Crash.txt file attached.
Ceger
crash.txt
Posted Feb 21, 2009 · 01:43 UTC#54
Dumpystig,
Did you do an EZRider.exe updates for maps and such that the SYS.TXT file or something might be referencing?
Ceger
Posted Feb 21, 2009 · 01:44 UTC#55
There's a broken link somewhere. At least this may help the real experts in diagnosing the problem.
Posted Feb 21, 2009 · 01:55 UTC#56
Dumpystig,
Ceger
No, EZRider remains untouched. All my mods are in the DATA.zip, >project.config< and >pioneer.ui<
But I'm thinking, as I also did the mods for getting more sky/better horizon which involved slight alteration of >iGO/SYS.TXT< if this could be causing the prob your having
EDIT- I just read your earlier post and it seems you already had the SYS.TXT covered
Posted Feb 21, 2009 · 02:05 UTC#57
Dumpystig,
Ceger
I pretty much rolled back the place and setting UI files from BorisM's zip and everything worked just fine, but I cannot access speedcam setting options.
BTW, your mod looks awesome!
BorisM, do you need to have the updated EZRider.exe for using the speedcam controls?
Ceger
Posted Feb 21, 2009 · 02:09 UTC#58
EZRider.map file that crash log refers to is a debugging file that converts memory addresses to function/variable names etc. Used only for debugging, and NavNGo are the only people who have it. So no problem here (other than crash).
If you do get a speedcam.spdb file in speedcam directory, then this piece is fine. You can leave it there.
Try backing out changes one by one (SYS.TXT, DATA.ZIP changes) until you get it to a point where it does boot. Then we will know where the problem is...
Posted Feb 21, 2009 · 03:15 UTC#59
Hi, I would like to try the Data.zip, what is the username for the FTP. It wont let me enter just a pw.
Thanks!!
:D
Posted Feb 21, 2009 · 03:32 UTC#60
Hey Ceger
I was having the same problem as you did, and i think i got a fix for it.
Did u use BorisM's speedcam.txt(pasted) into ur igo/content/speedcam folder?
I just replaced the Boris's data w/ old data which was "Red_Light_Camera_us.txt", and "Speed_Trap.txt"
from http://www.avic411.com/forum/viewtopic.php?t=19523
and my 700 began to operate as it usually did.
i guess i've made a mistake when i was making speedcam.txt data
provided by BorisM.
Anyways, really wanna say thank u to all of AVIC411 members, especially to Boris, Mavs & dumpystig
:D
Posted Feb 21, 2009 · 04:31 UTC#61
Thanks!!
:D
user name is "avic" & there is no password
Posted Feb 21, 2009 · 05:06 UTC#62
Hey Ceger
provided by BorisM.
:D
I got it working and with the over a meg speedcam.txt from BorisM. It was my own stupidity though as you CANNOT use the setting and place UI files from BorisM's zip (as he had stated a while back). You need to just pull those files from the main speedcam zip of the original topic poster and add those in to the data.zip. Then make sure you have speedcam_enabled = 1 in the [debug] section of the SYS.txt file and it all WORKS.
Thanks all.
BorisM, please keep us updated when you get the sppedcam working with voice working, in english that is. ;)
Ceger
Posted Feb 21, 2009 · 22:04 UTC#63
Hey Ceger
provided by BorisM.
:D
Thanks all.
Ceger
So u r saying that u used Boris' progressive report thread's data.zip(pioneer_ui) at first and then u replaced the pioneer ui in data.zip w/
this thread?
neways, glad to see u got it working :lol:
Posted Feb 21, 2009 · 22:21 UTC#64
tried from another computer to login and it worked fine.. :oops:
Posted Feb 23, 2009 · 01:04 UTC#65
Ok so I have everything working great now but does anyone know if I can just delete my Ipod art work. I did search but had no luck yet, I will keep looking
Posted Feb 25, 2009 · 08:56 UTC#66
Nope...i want to get rid of ipod album art as well, but do not know how.
I also notice that the icon buttons on the right hand side, sometimes seems to be duplicated or two buttons are showing up at the same spot.
I decided to ignore it, cuz this mod is still awsome :lol:
Hey Ceger
Do u hear a warning sound when approaching the speed traps?
I only get to see a red warning window, however i can't hear anything.
Is this normal or do I need to adjust some setting in warning section?
Posted Feb 25, 2009 · 09:05 UTC#67
You shouldn't be getting duplicated buttons/icons. Try re-installing the DATA.zip, see if that cures it.
Speedcam has a newer sound that someone else here (forgot who) pointed me to. Go to Top Menu > Settings > Navi Settings > Warnings > Audible Warning Enable/Disable.
Can't help with Ipod Art, it's not something I use so haven't looked into it.
Posted Feb 25, 2009 · 09:07 UTC#68
I decided ignore it, cuz this mod is awsome :lol:
I haven't used his .zip but I did make some modifications to my own that caused this problem. I had to create a script to fix it, and then had to call it in a bunch of different ui files. This was the gist of the code.
An example of one of the calls.
runifnot vStateMode "0" sc_fr2d3d
Depending on what exactly was changed in this particular .zip, it could be as simple as finding all the 'btnNMB_Cursor.y 210' statements and changing them to whatever syncs them up vertically. Such as
runifnot vStateMode "0" 'btnNMB_Cursor.y 210'
Posted Feb 25, 2009 · 09:15 UTC#69
Good call matey, that's the gist of it. I reckon the probs some of you are having are after you have made your own alterations, but that's what this is all about! :)
Posted Feb 25, 2009 · 09:21 UTC#70
BTW, What font are you people using, stock Tahoma or the included 'Julius'? And if anyone has reverted back to stock, did you find it hard work?
Posted Feb 25, 2009 · 12:47 UTC#71
DS, any chance to post a screenshot?
(tinypic.com)
Posted Feb 25, 2009 · 17:18 UTC#72
(tinypic.com)
Sure, but of what? :)
Posted Feb 25, 2009 · 19:30 UTC#73
(tinypic.com)
Of the screens how they look with the mods loaded.
Posted Feb 25, 2009 · 21:57 UTC#74
Ah, you said a screenshot, but you meant several screenshots LOL. Leave it with me, I'll post em shortly
Posted Feb 26, 2009 · 04:16 UTC#75
I had a problem with Bluetooth being disabled when I performed this mod. After a lot of trial and error I was finally able to re-enable it by changing the '749ew' to '746uc' line in sys.txt. 746uc is what is in my original file. I will play with this to confirm but it was the last thing that I did in order to fix this. I had thought that it was due to exchanging the placexxx.ui, settingxxx.ui, and speedcamxxx.ui while trying to enable the speedcam mod (while adding the txt files from the other mod) They have no effect on bluetooth. Hard and Soft resets did nothing either. I even tried to reload the firmware but kept coming up with an error. Eventually it was the sys.txt.... I have a f90bt and I noticed the creator of the mod has an f500 in his sig, this is where this came from. I hope this helps someone.
Page 3 of 5
