Is there any way to change the default zoom level on the map? I like it zoomed a little closer in, but even after I manually zoom, the screen automatically zooms back out to an apparent default level after 5-10 seconds.turn smart zoom off
But I like that the smart zoom zooms in really close when you are about to make a turn. For the standard zoom, I like it about three clicks in further than the default. It's not a huge deal, but I thought if it's an ini modification, I might be able to do it. I saw the settings for max and min zoom, so Ithought there may be a setting for the standard view zoom.
Thanks for your responses to my questions.
I guess for the previous question, I'll try putting the default maps back in and see if that fixes the TTS. I had version 2007.10 ( I believe that was it) and had copied in 2008.04.
