For those interested in F500 install results.
I installed the allinone noob image (includes MSN) and the only problem i can see is that TTS does not work, and Samantha is actually not even an option in the language menu anymore. I have Jason, and two other countries. Actually, even picking Jason doesn't work as I don't get spoken directions at all right now. I am going to load of the most recent mod'd Samantha TTS and try to load it manually in the settings menu, as opposed to using Testmode install (copy and paste). Hopefully this will restore the spoken commands!
Anyone with the F500BT had any luck installing the allinone hack without problems?
BTW, I love the 2.0 firmware...so far, much more responsive!
BTW, I REALLY love that the F500BT can be found under 200 bucks now...makes me so glad I was an "early adopter"!
UPDATE: I did a poor job searching the thread, and now I see i need to edit the sys.txt file to reflect the right device. My question now, is do I just update the sys.txt, and then re-run the full blown allinone testmode install, or do i just need to update the sys.txt and copy over the one currently on my device (using testmode of course, but not with the auto-copying procedure).
I succesfully updated sys.txt with the right device, and now I get spoken nav guidance again, but the only option is for Jason (not TTS). I did a full reinstall of the allinone mod with the udpated sys.txt; still no go on the new Sam TTS voice. I even loaded the standalone TTS zip and went into the "language" menu on the Avic and tried to load Samantha manually of an SD card, and while appearing to load I never get the choice of Sam in the language menu once done loading.
Any ideas?
