peace out.
By cmh928 · Apr 05, 2009in Hacks/Mods💬 723 posts👁️ 101,422 views
Page 19 of 29
Posted May 21, 2009 · 22:57 UTC#451
BorisM thank you in advance
You're welcome.
Theoretically, this is controlled by this entry in SYS.TXT:
[warning]
warn_distances="100:1500,70:1000,50:500,0:200"
where the number before the colon is speed (Km/h obviously) and one after being distance in meters. It affects the non-linear function that iGO uses to start warning about the camera.
I could not see warn_distances in our build of EZRider, but I do not have IDA Pro handy right now...
ok thank you, I added this parameter in my sys.txt (firm 2.005000) but in the options of "custom camera setting" the zone of "warning beep distance" does not go further than 300m!
Posted May 21, 2009 · 23:52 UTC#452
CMH, I see you have a Beta file you just uploaded. Are you changing your mod?
Posted May 22, 2009 · 02:51 UTC#453
hey anyone know why my buildings won't show up. followed the directions to a tee and i love the mod but i can't find a menu to control buildings and i can't edit speed cams, i know i'm missing something i just cant figure out what. any help is appreciated. i did the unzip to sd card so the mod copied automatically. it should be perfect??? let me know
thanks
Posted May 22, 2009 · 03:23 UTC#454
thanks
Try here first.... viewtopic.php?f=34&t=23411&hilit=buildings&start=105
Posted May 22, 2009 · 03:29 UTC#455
This is a great mod and I had no problems loading it on my AVIC. But I am hoping that you might help me change the way I view the map on 2d. I would like my 2d to look more like the 3d does and shows a arial view more than a cockpit view.
Posted May 22, 2009 · 04:34 UTC#456
thanks for the reply but i still dont know i did a fly over of nyc and still no buildings? i thought this was all included in the all in one... am i wrong?
Posted May 22, 2009 · 04:38 UTC#457
you need to add the 3dc and 3dl files for the buildings and landmarks to show
Posted May 22, 2009 · 06:35 UTC#458
The all-in-one UnziptoSDcard files are the only ones with buildings included. If you installed the whole 65MB then you have all you need to see buildings. Read the readmes and go through your settings to enable everything.
The beta file has IDT's latest mods to the speedcam interface and the Amigo style POI icons. It fixes the Canadian speed limit issues but does away with the Eurostyle speed limit sign. I am writing some new scripts to make IDT's mods live happily with GTIMatt's mods (speedcam muting), but the file is stable to download. I am making the new POI icons less transparent using Gimp as well.
Posted May 22, 2009 · 13:32 UTC#459
cmh i used the all in one and i see the files your talking about, in my 3d landmarks screen it says buildings, close or far etc., but thats it, which menu would it be in? i've gone through the read me but it doesn't tell you how to get them to show up. is it because i didn't use your image.res because that is the only file i took out? thanks for your help
Posted May 22, 2009 · 14:30 UTC#460
GUGA's image.res seems to blank out XM channel logos, is this by design or something I messed up? Replacing image.res with stock restores the logos.
Posted May 22, 2009 · 15:05 UTC#461
even if you have all those settings turned on if you dont have the 3dl and 3dc files no buildings will show up
Posted May 22, 2009 · 17:46 UTC#462
ok i have all the building files. i just reinstalled them to make sure and still no building menu or anything only speed cams was that ezrider and license file in the aio zip the right version to make them show up or do i need to get new copies? i have the maps that came with the unit are they the wrong maps? please help!!
Posted May 22, 2009 · 18:36 UTC#463
do you know what license file was included in the aio? try adding this license file, this one fixed my problem with the buildings, extract the file and load it
Posted May 22, 2009 · 19:26 UTC#464
IDT, he has everything he needs to see buildings in North America if he used the 65MB AIO. He doesn't mention what unit he installed it on, however. If it is not a UC version F700, F900 or F90, he will need to modify the sys.txt by hand. It's also possible he didn't extract things properly to the SD card. Use 7zip! You should only see TWO items in the root folder of the card.
Posted May 22, 2009 · 19:30 UTC#465
i see,
Posted May 22, 2009 · 20:27 UTC#466
hey thanks for helping i tried that license and still not working. i switched it back to the cmh license. whatever i guess it just doesn't work. if anyone has directions on how to get to the menus and what not let me know that readme file is pretty useless for buildings. i didn't extract anything wrong i have an f90bt. i did not however modify the system.text because the aio didn't specify that i had to, is that my issue then? thanks
Posted May 22, 2009 · 21:26 UTC#467
If the 65MB AIO installed properly and the screens on your unit look like the pictures posted on here, then you have all you need. Set the map to 3D mode and simulate a trip to a big city. I would recommend downtown Chicago. The sys.txt in the AIO is fine as-is for US/Canada versions of f700-f90. For that matter, the F90 already came with landmark files OEM.
If in doubt, re-download a fresh UnzipToSDCard, format the SD card(2GB or smaller in FAT), extract AIO to it, insert card to unit, turn on and wait to see the green box. Turn off ignition.
Posted May 22, 2009 · 22:44 UTC#468
cmh i appreciate your reply but i have already done those things where do i go on the f90 menus to enable the buildings i know i should have a screen somewhere but i don't. i did a fly over of nyc and no buildings? i'm just frustated and you keep telling me the same stuff over and over, i am not being a jerk and i appreciate all the hard work you put into this mod but if you don't know, you don't know. all i could do was ask, cause i don't know either like i said i followed the directions. thanks for trying
Posted May 23, 2009 · 01:00 UTC#469
It works fine for the hundreds of other people who have DLed the AIO. The only reports of issues were from EU users or F500 owners. Try posting in the 3D buildings forum.
I guarantee all you need to see US buildings is in the AIO.
Posted May 23, 2009 · 01:43 UTC#470
Here ya go...Look for 1 Wacker Dr Chicago,IL...click starting point, you will get some kind of message, click Ok, then look for your home address and click go here now. Click your info box on lower left and click simulate. I just did it 5 minutes ago and I seen all kinds of buildings. The mod works and works well.
Posted May 23, 2009 · 01:58 UTC#471
Thanks, awesome mod and super easy to install. I did the all-in-on-one for my f90bt then re-did the auto install with the big clock mod. This is beyond anything I could do and fixes a lot of annoyances that were there from the factory, updated the graphics nicely, and added some much needed features (quick cnx of the route, home short cut, etc.)
Anyone can ask for you to move this or that, or change the color of this to x. I just want to say thanks, you made my system go from good to great. Maybe pioneer will copy some of this into the next update :?
Posted May 23, 2009 · 02:43 UTC#472
ok i believe you, please don't get upset about this because your mod is awesome regardless if i can find buildings or not. it's probably something stupid that i over looked. i won't have my car for some of this week but when i get back to it i will try to re-download the aio from scratch and try again. i'll post results when i get back sorry to drive you guys crazy.
Posted May 23, 2009 · 05:31 UTC#473
no prob bro,
Posted May 23, 2009 · 05:38 UTC#474
the download link doesnt work anymore :(
Posted May 24, 2009 · 00:55 UTC#475
Thanks a million... I've installed this mod - and it's awesome!!!
My F90BT is so much better than it was before!
Quick question.
I'd like to add some additional screens to put into the unit (particularly a NY Giants and a NY Yankees splash screens).
How do I do it? Do I need to enter into TESTMODE? Or do I just add them in as pictures on a normal SD card with no Testmode or anything else on it?
Does the whole mod need to be on the SD card each time I want to add something?
Thanks. I appreciate your help and hard work. You guys rock!
Page 19 of 29
