I have both SW and HW bypass on mine as do many others. Works fine.
thank for quick reply. I gonna try your mod tonight.
hey ... MY BUILDINGS WORK!!!!!!! A SPECIAL THANKS TO crilleym cmh and idt for helping me out. it turns out that i just don't know what i am doing! LOL. i flew over that address in chicago and there they were! thanks for helping out kids and i am sorry to drive you nuts. i appreciate all your help. THANKS
No problem. I am not as knowledgable as cmh and idt, but I have learned a lot from them and others. The key is read, read and re-read these threads.
I loaded it as-is and found what appears a repeatable occurence. That occurence being if I change the setting to show the hist/Gps or hist/msn icons through the NaviSettings/Visual/CustomSettings, then set a destination, then cancel/clear my destination, the history icon is then missing from the top row, but the icon will come back after navigating away to other screens and back to the map screen.
I will probably have to put a direct call on the Delete route button to fix the ghost. I hadn't experienced it yet, but I had a similar issue ages ago on the Go Home button not showing route info properly because the nav screen isn't fully refreshed when you push that button. Changing screens to start or delete a route always runs the scripts. I'll post back later.
I loaded it as-is and found what appears a repeatable occurence. That occurence being if I change the setting to show the hist/Gps or hist/msn icons through the NaviSettings/Visual/CustomSettings, then set a destination, then cancel/clear my destination, the history icon is then missing from the top row, but the icon will come back after navigating away to other screens and back to the map screen.I will probably have to put a direct call on the Delete route button to fix the ghost. I hadn't experienced it yet, but I had a similar issue ages ago on the Go Home button not showing route info properly because the nav screen isn't fully refreshed when you push that button. Changing screens to start or delete a route always runs the scripts. I'll post back later.
so what script is the best to refresh the nav screen?
i still don't have buildings
check Chicago and Detroit, my sys.txt is the one being used in mod and its enabled in menu. any ideas?
Normally the sc_Fullscreen will suffice as it calls and is called by many other scripts. Another good bet for you would be the Alpha down/restore scripts as these are called by just about every other script. Without leaving the screen and coming back, I know of no script that will truly refresh the whole screen.
To fix my ghost, I ended up modifying advmenu.ui to set vValidRoute 0 after DELETEROUTE but before it calls sc_frhideri in nm.ui.
I also made the back key match the one in GUGA's theme and added another option under Visual/Custom to hide speed and elevation. I will post new copies in the morning.
hey i need some help with editing speedcams. i just updated this mod with the new all in one and so far it is flawless and amazing! props to CMH once again. switching between screen seems to be faster, thanks for that. my speedcams work fine i just want to delete the ones that are there that really aren't there. i tap the speedcam and then i am supposed to hit the cursor, but i am not sure what the cursor is. does anyone have a pic or can you describe it to me? oops forget it i figured it out!!!
slothy i had the same problem but they are there you just have to keep looking. put the map in 3d also once your in like downtown chicago maybe try zooming in a bit. make sure that in the navi menu the buildings are turned on
i seen landmarks that's about it.
scratch my post about speedcam edit. i figured it out.
slothy it should say building under there too. if it doesn't then someone else will have to help because i don't know. i have no idea how these mods really work, i am still learning myself. sorry i can't be more help.
Slothy, if you aren't using a UC model f700,f900, or f90, you will need to edit your sys.txt by hand. The line [device] type="PIONEER746UC" has to match your unit's ID.
There's nothing else I know of that would prevent you from seeing buildings if you used my all-in-one. Be aware, unless you live in a BIG city, you won't see diddly.
cmh, I just d-loaded you 05/29 zip. Looks good so far. Now I see you have a 05/30 zip. What changes if any did you make? I don't want to have to redo it if I don't have to. Thanks.
ya i did a fly over in detroit and chicago all i get is landmarks, when i get home ill check device id
i do have a us model f90
Look at my comments on page 32 of this thread. All I did was a Simulation at a slower speed and I saw the buildings.
Trust me, it does work.
i did slow down, ill try your addy when i get home. what map scheme are you using btw?
I am using cmh's latest. I didn't do a "flyover" I did a "simulation"
First pic is to a simulation to Colorado and second is to Maryland.
Crilley, minor bug fixes for icon ghosting is the main difference as well as some spacing changes in a few places. Looking at your pix, all I can say is TURN DOWN POI VISIBLILTY. It looks like you have them all cranked up to far or satellite to have that many "multi-POI" icons showing.
When I get back home to fast broadband, I will upload the latest set of changes. Only big change is adding the abitity to turn off speed/elev display. The rest is just clean-up.
I had a few extra calls to my custom script to try to narrow down the occasional icon ghosting problem. Once I found the source, I removed the extra calls. I doubt it actually impacted performance, but I like to keep things clean.
Yeah, I know I have them cranked up because I had a compatablity map/poi problem, remember. I couldn't see any at all. So now that is fixed, I should turn them down. Thanks.
Anyone else getting a system startup boot loop (using the full)? Mine says its starting up then about 2 minutes in it reboots and does it again. I tried it with both win-rar and 7zip with the same results. I can see the new menu icons while it says system starting but it never goes away and reboots.
FYI- The return to OEM works fine.
ahahah wow im a idiot, why did i think there was light grey shaded buildings also - thats what i thought i i was missing.... /ignore me ![]()
mine did that after install, but after 2 loops its working fine
Hmmmm.... I let it go for 10 mins or so. Maybe I should try it again.
Diaftia, make sure you delete any current route and leave the nav screen for a menu or source screen before you shutdown. Then install the AIO again.
I found a few bugs in Guga's theme and fixed the BMPs. This is included in the new all-in-one.
Fresh copies of all are uploading now. Give them 20 minutes or so to finish.
If you are happy with what you currently have, then leave it alone. Don't get upgrade happy just because I'm a perfectionist and keep playing with the files. ![]()
whoa whoa whoa... did you just updated your file like twice today? because i just zipped up the red theme to yours at the request of a few people. now im not sure if i zipped the latest file or not.
