peace out.
By cmh928 · Apr 05, 2009in Hacks/Mods💬 723 posts👁️ 101,422 views
Page 22 of 29
Posted May 31, 2009 · 03:06 UTC#526
Superman, you will need to at least grab nm.ui, nm8x4.ui, setting8x4.ui and advmenu.ui from my new versions or just drop your graphics onto my new data.zip.
Posted May 31, 2009 · 03:36 UTC#527
Awesome Mod
Unzipped it to my sd card put it in the stereo turned the key on , and it all went great ,
thank you for your time creating it and posting it
Posted May 31, 2009 · 13:15 UTC#528
Thanks for posting your mod. Loaded today with no problems. Looks GREAT and a lot of work went into it. Thanks again.
Posted May 31, 2009 · 15:44 UTC#529
Thanks for the update, Cmh928! As always, it works like a charm!
Posted May 31, 2009 · 19:40 UTC#530
Diaftia, make sure you delete any current route and leave the nav screen for a menu or source screen before you shutdown. Then install the AIO again.
I found a few bugs in Guga's theme and fixed the BMPs. This is included in the new all-in-one.
Fresh copies of all are uploading now. Give them 20 minutes or so to finish.
If you are happy with what you currently have, then leave it alone. Don't get upgrade happy just because I'm a perfectionist and keep playing with the files. :-)
hey cmh928-
I will give that a shot... thanks. I had a piece together of some of previous mods loaded and did that by hand. It was quite a while ago. I see yours now and i like it much better. I am always down for a good tweak to make this thing better. ;)
Posted May 31, 2009 · 19:47 UTC#531
whoa whoa whoa... did you just updated your file like twice today? because i just zipped up the red theme to yours at the request of a few people. now im not sure if i zipped the latest file or not.
Hey Superman- Where can we get your red version of the cmh mods package? I have an Audi with Red dash lights and I think it might go nicely. :)
Posted May 31, 2009 · 19:48 UTC#532
I just load the mod. Very nice. I like when you want to change from day to night ( press the compass) .nice clock size ,lot of colour map, menu button very easy to read and use,I need to play with it a bit more but so far very good. Thank you Cmh928.
Posted May 31, 2009 · 19:58 UTC#533
i just went ahead and rezipped it with your latest zip (10pm). so i got the red theme of your settings all done and reorganized posted it up already thanks. its been asked by several members here so i did it.
Posted May 31, 2009 · 20:08 UTC#534
helloo guys...a newbie here...just wanted to ask if i can just add this on my f500 SamHybridTTS-Auto.zip and not all the mods...just wanted to change samantha
Posted May 31, 2009 · 20:09 UTC#535
and...how and where to i put it
Posted May 31, 2009 · 20:24 UTC#536
hey cmh- I hate to be one of "those" people needing troubleshoot assistance; but do you happen to know what its doing when it says system starting and reboots? I wonder if there are some files that I had modded in the past that are not agreeing with your setup. It seems most everyone is loading this fine. I have even done a system reset to make sure everything should be in a good state and I am still getting the reboots. I *believe* (its been quite a while) the mods that I had done in the past were based on Mavericksters data.zip but I would assume that you would be overwriting most of the mods that I had done. I think I have the backup somplace but like I said your restore to OEM setup works great. I am confused.
Posted May 31, 2009 · 20:30 UTC#537
Daftia, you don't say what unit you are using or which region. Try just the data.zip by itself if you are having problems loading the AIO. Otherwise, try the standard list of reboot issue steps. delete user\userdata\ folder and the 4 gpsparaxx.bin files in the root of myflashdisk.
Posted May 31, 2009 · 20:37 UTC#538
Hey chm... good point. F90BT in the US. :)
I will try the tips you mentioned as well. Did not know those.
Posted May 31, 2009 · 22:57 UTC#539
Jasher, the Lord helps those who read !readme! files and use the forum search engine. If it is covered in the first post or the readme files on the FTP, it won't be answered again in the thread.
Posted May 31, 2009 · 23:37 UTC#540
cmh, take a look at my pic in supermans red theme thread. I changed my POI's a little bit. Can you see a change?
Posted Jun 01, 2009 · 14:57 UTC#541
Hi, I have a quick question -
Is it possible to drop all the new maps I have into the AIO and have it install them for me?
I did it manually, but it took pretty long, and I think some were corrupt and now the unit is acting up - rebooting, getting stuck and thing like that, this was before I installed the AIO, so I think it was bad map files.
Also, what should I change in sys.txt for a F700BT? I switched the data.zip with the noMSN one, anything else?
Thanks for the awesome mod and all the help guys, this is a great thing you are doing! Without this forum, this unit wouldn't be nowhere as cool, or useful!
Posted Jun 01, 2009 · 18:42 UTC#542
Evo, you can use the AIO to update maps by creating the correct folder on your SD card. The newest maps that will work are 2008.4 and they WILL screw up TTS naming of highways. 2007.10 gives the best TTS. Any of the newer maps require a hacked ezrider and license file to work properly. These are already in the AIO.
If it is a US/Canada F700, sys.txt is fine as it is.
In the newest AIO, just turn off the MSN icons from NaviSettings.
Posted Jun 01, 2009 · 19:32 UTC#543
Thanks for the quick reply CMH928!
So I assume I should put the already extracted maps in MiTACAP\APL2\iGo\CONTENT and create "maps" folder there right?
I am already running the 2008.4 maps, but just want to do it this way because it seems easier, I want to re-upload the maps because I think the ones on the unit right now are corrupt.
Thanks again for the info!
Posted Jun 01, 2009 · 20:15 UTC#544
cmh, did you fix this issue with the 5/30 release? This happened to me today.
ziplocbodybag wrote:
I loaded it as-is and found what appears a repeatable occurence. That occurence being if I change the setting to show the hist/Gps or hist/msn icons through the NaviSettings/Visual/CustomSettings, then set a destination, then cancel/clear my destination, the history icon is then missing from the top row, but the icon will come back after navigating away to other screens and back to the map screen.
Posted Jun 01, 2009 · 22:25 UTC#545
error
Posted Jun 02, 2009 · 01:20 UTC#546
It has been fixed since I posted the new AIO file. There were probably 3 versions posted on 5/30. The one on there currently is fine.
It was a minor bug and just tapping the screen would clear it up as it was. Don't scare people. :-)
I just posted a new version of the AIO with the newest (2009) 3D building files and speedcam database. All new uploads from now on will be in 7-Zip format to ensure they are unzipped properly. I have posted the latest windows version of 7-zip for download as well.
Posted Jun 02, 2009 · 09:25 UTC#547
I downloaded the previous version just fine but for some reason, this one will not appear in a zipped folder after downloading. I've tried it 6 different times.
Posted Jun 02, 2009 · 11:31 UTC#548
It is in 7zip format. I DL last night and its ready to be put in my unit.
Posted Jun 02, 2009 · 11:57 UTC#549
I just tested your new version data.zip on my EU F900BT version. I just noticed a bug. When I click on the icon "back home" (on map and menu touch) AVIC reboot!
I have not yet found the origin of this problem, do you have a solution?
Posted Jun 02, 2009 · 13:32 UTC#550
I'm also getting the reboot when selecting the "go home" icon. Also, when selecting any destination I get a error box that pops up and says "unknown command", once I clear that error message, the routing will begin. I have the AIO from 5/30/09 and I dl that around 7pm monday night. Street names no longer appear on map, only on the destination info, is this normal with the mod?
Page 22 of 29
