Try reversing the sys.txt edit.
Could you expand on this? I'm probably lost here but what sys.text edit? I don't recall which edit in sys.text affects this?
[poi]
use_multi_poi_icon=0
oh.. the multipoi.icon
do you mean remove this
[poi]
or remove the other text and just leave this?
Remove the entry you added earlier.
[poi]
Hube2002 - VBLUES method is executed in the data.zip. What I posted is an entry to the sys.txt file located in the apl2 folder.
I never saw a diamond on my unit with the sys.txt entry listed above.
Thanks, I tried, it didn't work. Can't figure it out. I tried every scenario. Weird thing is I just had this working the other day with just VBLUE42 method but I reverted back to a fresh 3.0 to get rid of any unnecessary stuff I might have added in the past. Then I upgraded to 3.02 and now I can't make it work. Tried every scenario. Not a big deal I just wanted to make a backup of IDT's mod with abb's chrome them cause I have everything looking how I want but I hate to make a backup with unresolved issues.
Could I save space by just staying at 3.0 instead of upgrading it to 3.02?
Is there any big improvement that makes it worth it? I read somewhere that the update took up valuable space?
Got it worked out, thanks...
So which method was the best solution for you?
I would have to say after lengthy testing both obviously work but I think the sys.txt modification works best. It seems to separate the icons and space them better. I like the way one appears for a few seconds and then whatever is on top of it or behind it replaces it. Not saying one is better than the other, both may work exactly the same (don't go by my observations, I know nothing) but it just seems to me that with the sys.txt edit you get a broader view of what is around you and it seems more accurate. I still can see the diamond but only in 2D or overview mode. Judge for yourself. Click photos below. They are huge!!!!
I can't wait to go into the city tis weekend . Gonna turn 'em all on.
**Running Abbs Chrome Theme & Abbs Modified IDT Skin#2v3.0 Mod**
Hube = Be careful about turning them all on. They can become overbearing, plus it's a pain to turn them off if you decide to. Once you turn them on the main poi category, it in turn turns on all the sub categories as well. But will not turn the subs off when you turn it off in the main. They will all need be done manually. Pain in the ass.
Oh Shit!! Good Info.
Can I back up a file for the POI's I have branded so every time I change Data files I don't have to re-brand them all? I guess wiping out the save files erases them all.
I don't know the answer to that one.
I tested this, mine switches them all back off, isn't that what the option is on this screen below, weather the sub-cats take the same action as the main category.
Just save the "save" files user/userdata/igo/save and the branding file. When you reinstall, restore these files and it may retain your settings.
I thought it was a mandatory to delete the save files when replacing the data file? Wouldn't adding back the original be the same as skipping that step.
I dont think it is mandatory. However if it causes problems then you would not want to do that. I have switched between two different mods and retained all of my settings. Doesn't mean it will work the next time I do it but for now, thats the method I am using to retain my settings.
Good to know, I will try this and see what effects not deleting them has. I'm sure there is a POSSIBILITY of problems as all the gurus seem firm on this.
Thanks for your help.
Or you can add to the sys.txt file:
[poi] use_multi_poi_icon=0
Can I also edit the sys.txt and change default lat & long to my location as well as default day and night schemes to those of my choosing??
Finally had time to follow up on this more. I looked through Diaftia's mod and noticed in his data file he had 3 sub folders in his icon folder (poi, pioneer_poi & sys) All three have the multipoi.icon file.
VBLUE42 stated earlier that
If your on 3.0 the path to find the multipoi.icon has changed. Its in data.zip/ui_pioneer/icons/sys
This is true but i noticed that Alex had the multipoi.icon file in all 3 folders but the only one with the values changed to 79 from 74 was in the poi folder, the other two remain at 74, I followed this and added the multipoi.icon file back to the poi folder and it does indeed remove the red diamond in 2D mode
So you guys are both correct, I guess, but if you want the diamond gone on all screens then you will have to have the file in the poi folder. At least this is what finally fixed it for me in all modes, I no longer have any diamonds anywhere and I'm sure you can accomplish this by just the changing of the value as VBLUE42 had stated. It just seems that it has to be in the poi folder, regardless of the same file being in the other 2 folders.
Make any sense?
Hey VBLUE42, is it possible that the red diamond icon is still show in the 2D view?
Thanks.
It doesn't on my unit. I am using Diaftia's mod.
When zipping back to DATA.zip after modifying multipoi.icon, can someone remind me which method to use?
1) With 7-Zip, zip to DATA.7z, then rename to DATA.zip; or
2) With 7-Zip, directly zip to DATA.zip; or
3) With WinZip or any other zip utility, directly zip to DATA.zip.
I always use method #2 and it works. But if I use method #1, the file size is signficantly smaller. Please note that Image.res is zipped with method 1. However, 7zip.dll is not presented in the iGo folder.
Thanks.
