FINALLY: NO MORE RED DIAMOND ICON
By VBLUE42 · Apr 23, 2009in Hacks/Mods💬 60 posts👁️ 58,074 views
Page 3 of 3
Posted Apr 13, 2010 · 12:06 UTC#51
1) With 7-Zip, zip to DATA.7z, then rename to DATA.zip; or
2) With 7-Zip, directly zip to DATA.zip; or
3) With WinZip or any other zip utility, directly zip to DATA.zip.
1) NOT working.
2) WORKING.
3) NOT working.
Posted Jun 05, 2010 · 09:17 UTC#52
Hello,
On my Avic [European F900BT upgraded in F910BT] with
[poi]
use_multi_poi_icon=0
I don't have any red diamond in 3D mode and I can see all icones. But in 2D, I already have this red diamond.
Do you have any suggestion to remove this diamond and show all icones (The solution to hide all icons is not good for me and I prefer to have the red diamond)
Posted Jun 05, 2010 · 11:42 UTC#53
Hi Marlysa,
For the 2D fix, there is a file called multipoi.icon in your ui_pioneer\icon\poi folder under the DATA.zip. All you have to do is open it, change the value of both lines from 74 to 79, and rezip it.
Voila!
Posted Jun 05, 2010 · 18:39 UTC#54
Hi Chuck88,
I already did it but this replace the diamond icon by a blank one and we don't see anymore if there is some POI or not. I don't like this solution and I prefer to have the red diamond.
For your information I found a solution to do it without any modification of the data.zip. [We are testing this solution with some other french AVIC users and I'll come back to explain here how to do it :wink: ]
My previous asking is to know if it is possible to display all icons in 2D view even if there is an overlap (Like in 3D).
Posted Jun 05, 2010 · 22:48 UTC#55
No.
Posted Jun 06, 2010 · 01:09 UTC#56
Hi Marlysa,
I afraid that I have to say no, like VBLUE42 had said. In the 2D mode there is no such thing as graphic overlay, so impossible to display one icon over another.
A bit off topic, since you have a forum, can you help me for this one: I have smartzoom enabled but I find that the default zoom is too far (I want the view to get closer to the car or the arrow). What is the [smartZoom] parameter that I have to adjust in order to default a closer zoom distance? This should be set in the SYS.TXT file.
I tried defaultzoom3d=xxx parameter but didn't work (=100 or =2000 is the same). Any idea?
Chuck.
Posted Jun 27, 2010 · 03:34 UTC#57
Hi Guys, don't know if anyone else has posted on this, I been away for a minute, but i just formatted my unit to get rid of junks files that had accumilated and decided to go with the FX3.1 Complete Firmware Image thread to see if it was an improvement over what I had and the first thing I noticed when I was in split screen was a kfc icon in 2d mode, never seen it before, after i got rid of red diamond there were no icons in 2d until today. Again, this might not be news but was a first for me.
http://avic411.com/forum/viewtopic.php?f=34&t=32351
on a different note, i have always used winrar for zip files because i can click on the file and a window opens to show contents without unzipping. I edit all the files in this window as well as drag and drop to overwrite, it confirms the change and then i just close the window. No unzipping and re-zipping. it is very simple and the best program i have ever used for zip files, it's on the bay, as all good things are :)
Posted Jul 03, 2010 · 10:06 UTC#58
Hello,
As I promised some days ago, I found a solution to suppress the red icon without any modification in data.zip. My solution is to introduce in branding.zip some specific files:
In folder: \ui_pioneer\icons\poi\ add this file:
multipoi.icon
$poi_mapclose.spr	79
poi_mapclose.spr	79
[Nota]
As bonus, I give you another tip to have your own icon for your personnal POI (For the example I consider my File AVICMBkml.bmp]
In folder: \ui_pioneer\icons\poi\ add this files: kmlpoi.icon
$AvicMBkml.spr	0
AvicMBkml.spr	0
And place you personnal icon and its .spr file in folder: ui_pioneer\common\
For the example: AVICMBkml.bmp and AVICMBkml.spr
BmpFlags = 0
DefFlags = ALPHA_PIXEL | ALPHA_LAYER
DefPhase = 1
Stripes = 30
DefAlpha = 22
Posted Apr 25, 2013 · 00:27 UTC#59
Hey guys ive tried every which way to do this but i alway keeps getting the error when i reload into my avic. I always unzip the DATA.ZIP file make the changes to the multipoint.poi to 79 save the file, Rezip it. And then overwrite the previous DATA.ZIP file and it never works? ive tried zipping from my mac, from windows, nothing ever works?
i get an program application database not found or something like that error upon boot up it says system is starting up and then it just reboots. As soon as i put the original DATA.ZIP file back startup works fine again...ive tried changing the sys.txt file too with no luck? any other ideas
i know i did it the write way because its not rocket science here....
Posted Apr 25, 2013 · 07:46 UTC#60
ok got it taken care of
Page 3 of 3
