Ver 2.7 appeared on Pioneer Eu today
By BrianF · Jun 12, 2009in General💬 61 posts👁️ 12,866 views
Page 3 of 3
Posted Jun 20, 2009 · 10:27 UTC#51
My friends you are able to use testmode , so delete everything you dont need or like and put what you want to flash.
Ussualy everybody has backup of his avic FLASH :lol: procedure was to downgrade windowsce on avic the rest of all is up to you :lol:
Posted Jun 20, 2009 · 22:00 UTC#52
What I did to get back to Ver 2.0 was to use konick's method and CE image files, delete flash and copy previously saved flash back. Was then able to update to 2.005 using the standard update file. Tried this just to see if I could. The only prob. I am having a couple of minor problems. With euro software on a US unit you loose bluetooth. Put US firmware back on so no real prob. and secondly I have lost all audio relating to NAV, key beeps etc. This happens with standard firmware and flash drive and anything other than standard as well. Any source audio works fine. Any suggestions to fix :? ??
Posted Jun 21, 2009 · 08:26 UTC#53
This maybe a dunb suggestion, but did you try to reset the nav to factory settings, sometimes these are messed up, certenly using us/europe versions mixed up.
Posted Jun 22, 2009 · 07:24 UTC#54
Already tried a factory reset. Strange thing is the nav started working. Still no key beeps which is a good thing. Just wondering if anyone else who has upgraded to 2.7 noticed the key beeps gone?
Posted Jun 22, 2009 · 15:29 UTC#55
Another question about the upgrade:
I allready upgrades to 2.007 yesterday and now I found this thread with the bad news. :(
What I want to do is to install some software hacks described in the Wiki, but to do this I think I would need the test mode or another possibility to force the F900 to install the modified files.
If I understand all the information correctly, I've to apply konick's hack to get the old version of WinCE back on the F900. Then there might be 2 possibilities:
1.) Getting into test mode and copy only the files needed for the software hack
2.) Copy the LPUE080 folder with the modified files to the flash card and let the unit do the upgrade again to get the original 2.007 working with some mods
I'm not sure if the second version will work but if it does, I'll use this one because I've never used the testmode.
Posted Jun 22, 2009 · 15:57 UTC#56
I did your option 1. and it worked out fine.
Posted Jun 22, 2009 · 16:38 UTC#57
I followed option 1 from what you are saying. Result was being able to get into testmode again and firmware shows 2.007!! One thing only, I did not format before copying the files from the SD card but choose option 2 that only replaced them.
Posted Jun 26, 2009 · 20:12 UTC#58
So, I've just tried option 1, but when I want to enter the testmode there is only an error message and no test mode.
So I inserted a flash card with 2.007 and got back the actual CE version.
Now I did something stupid I think: fallback again with the older CE image files, but this time with "format".
After finishing this, the F900 only shows the startup picture and then a black screen. :cry:
After inserting the card with the 2.007 version (modified files) there is a message that the data.zip file is wrong. :x
The version infos at the top show no actual firmware, so the F900 might be empty. At the moment I copy the files from 2.005 (modified) to the flash card and hope to get my F900 back into life.
Edit: Damn, the 2.005 modified files also cause an error message with data.zip. The original 2.005 installs, but without DATA and MAP, it seems they are missing. :?
The testmode also doesn't work. I get the following error message:
MapDBInfo: 0x1000 <=> Device 0x0010
AU: 0x0001
EW: 0x010
RF: 0x0100
UX: 0x1000
Does anybody know how to reinstall "MAP" und "DATA" data without test mode?
I will now try it with Firmware 1.9, there were changes at the MAP data, so this version might install the maps again.
Edit2:
Ok, I got the testmode running, that thread helps me. But now there are some problems I can't manage by my own, so I opened a new thread for my special problem, that can be found here.
Posted Jun 26, 2009 · 23:52 UTC#59
Gettig the message below
AU: 0x0001
EW: 0x010
RF: 0x0100
UX: 0x1000
is due to a problem with the right file in you IGO\content folder where the MapDBinfo.txt is located. Make sure you have the European version. It should say something like
Area: EW
IntegrationVersion: 01.000600
Had the same problem and that's how I fixed it.
Hope this helps!!!
Posted Jun 27, 2009 · 00:02 UTC#60
I allready found the solution for the "testmode problem" 2 hours ago, but thanks for your help.
Posted May 27, 2011 · 12:02 UTC#61
I know this is a shot in the dark but is it possible to downgrade?
hey my man i can help you i have installed working maps of cyprus pm me for help
Page 3 of 3
