can you change the illumination color on U310BT or not?
I've read in one extensive review that the key color cycles and can not be set fixed - so claims the guy reviewing the unit.
You can change the color to whatever you want, but not the screen.
but how do you import colors other then the default 10?
and how do you import start-up background pictures?
To import start-up background pictures, it's really simple - you get an SD card (I bought a 16GB class 6 card from Amazon), and create a folder called "Pictures" at the top level directory. Insert the card, and then you go to the menu screen that allows you to select the picture you want. The bottom photo on this post shows my start up photo: viewtopic.php?f=56&t=26314&p=180882#p180882
I'm not sure you can import colors. Not sure why you'd want to anyhow, there isn't much to see. If you look at the third photo from the bottom on this post - viewtopic.php?f=56&t=26314&p=180882#p180882, you'll see the lettering is in red. It currently rotates from red to white to green to blue, etc. Cool, but nothing I'd really want to try to import a custom color for.
thanks, will try.
Pity you can't browse the CD like with other pioneer units.
to match the colors of interior. The green available in U sellection menu is too light. I know there are 2 shades of green, both are too light.
It is indeed mentioned in the manual (just a brief notice stating it may be imported), no details hovewer.
I see you must be lucky in that you're having a garage )))
you can't have these units last any long if you park on the street.
ok I figured that.
Last question: where can you buy the additional POI data for less?
used, referbished, whatever...
somebody selling may be...
