AVIC F90BT REBOOT FIX
By GCL915 · Jul 05, 2009in Problems/Troubleshooting💬 130 posts👁️ 95,751 views
Page 5 of 6
Posted Apr 04, 2011 · 23:02 UTC#101
The two files are there...look carefully...if you download the WHOLE backup from step 1 and sort the files by name, they should be the last two files there. You can format the SD card on your laptop....make sure its FAT32
THE TWO FILES ARE NOT THERE I THINK IT BECUASE THE LINK DONT WORK ANY MORE? PLZ HELP I REALLY WANT TO FIX IT?
Posted Nov 27, 2011 · 20:27 UTC#102
Few days ago I tried to update my Avic F90BT when all hell broke loose. The update failed, and I couldn't get my unit working. It just kept on rebooting....even testmode didnt work. :evil: Here is what I did to do a complete wipe and reset back to factory 2.0
You will need a USB drive and 2 SD cards or 3 SD cards.
1. Go to http://avic411.com/f...hp?f=34&t=24888 and download backup files for your unit. Save it on a formatted (FAT 32) 2GB or higher SD card or a UBS drive (recommended)
2. From above, copy the WINCEIMG.bin and WINCEIMG.cks to a different, formatted SD CARD (NO USB DRIVES)
3. Use another formatted SD card for testmode file. See http://avic411.com/f...hp?f=32&t=25329
4. Disconnect any USB connections connected to your unit (Ipod, USB drive). Power it up. When the pioneer logo comes up, press and hold the menu, map, eject and the reset button at the same time. When you hear a pop sound from your speakers, let go of the eject button but continue to hold menu and map buttons. This will bring you to a blue screen where you will have to enter the service combination. Press the volume knob in this sequence and you will see * signs for each push: Up, Up, Down, Menu, Left, Right.
5. Once there, go to the option that says Update WinCE. Be careful with not to press the knob while trying to move up and down, or you might press the wrong choice by accident.
6. Insert into the unit the SD card that has WINCEIMG.bin and WINCEIMG.cks on it (STEP 2)
7. Select Update using SD/USB (format) option. This will format your FlashDisk removing any corrupted files on there that prevent the unit from loading.
8. Wait for the update to finish. When the prompt says to restart your unit, take out the SD, put in the testmode SD card and restart.
9. If testmode starts normally, you see the windows screen and it does not reboot in couple of seconds, ignore this step. If not, download the latest update from Pioneer, put it on the SD card that contained WINCEIMG.bin and WINCEIMG.cks (format it first) and perform an update. Testmode should be working once this is done.
10. When in windows, plug in the USB drive with the backup you downloaded in Step 1.
11. Go to start, control panel, Storage.
12. Unmount FlashDisk, and press FORMAT.
13. Once formatted, create a new partition and call it part0. Mount it back up.
14. Copy ALL files from USB drive backup to FlashDisk This should take about 40 min or so
15. Take out any SD cards from the unit and reboot.
Thats it! This should solve any problems! :D
I CANT DOWNLOAD THE FIRST 2
Posted Jan 16, 2012 · 23:57 UTC#103
I just downloaded and updated my AVIC-F90BT with software version 3.x. The file copying part went without a hitch. When I reset the system after file copy operation, I was prompted to select language. After I selected "English as my language, I was prompted to choose voice language. As soon as I selected English TTS, the system rebooted and since then stays not he Pioneer splash screen. It never goes further than the Pioneer logo.
I have tried it several times and had no luck. I even deleted the partition and recreated it but still no luck.
Please help....
Posted Jan 28, 2012 · 05:16 UTC#104
Just happened to me. Looking for test mode files but I cant find them
Can somebody help
Posted Feb 01, 2012 · 16:04 UTC#105
does anybody still have these files kicking around ? i bought a used avic f90bt and it just died on me !!!
Posted Feb 02, 2012 · 06:16 UTC#106
Fixed the old links.
Posted Feb 08, 2012 · 05:09 UTC#107
just tried the links again and none of them work...
I have a f90bt thats been dead for about 4 months can someone please help... it is frozen on the blue splash screen when I put a CD in it plays but can not use any functions because the unit is stuck on the splash screen. I have spent days and hours reading and searching please help
Posted Feb 08, 2012 · 05:14 UTC#108
I found these files through somewheres on my search they appear to be working but im not sure which files will be needed for this rebot process thanks in advance http://www.4shared.com/dir/BAyG_X5F/pioneer-avic.html
Posted Feb 20, 2012 · 05:07 UTC#109
I followed al the steps but just can't get to the service screen.
I have formated SD cards and have the wince files
I too made the testmode SD card.
This set seems problematic. Anyone out there can help?
Do I depress all the buttons before turing on? Or turn it on and depress all the buttons? It just freeze with blue screen on the wince options but just wont proceed.
Posted Feb 21, 2012 · 06:58 UTC#110
I will do anything for those files bro, I have been trying to find them for around 5months now just to attempt fix my frozen screen. I'll gladly give email if files work I'll paypal you money...
And no u press everything all together hear a pop then release either the reset then the othe three(pretty sure) or vis verse the three buttons then the reset.. You will get a blue screen where u put the service code in and it will bring u to the service option.. I'm not just what it is I always just search it before trying... I can't do anything with out the wince files... And the back ups I beg u have a heart and share hating pioneer..
Posted Feb 21, 2012 · 16:22 UTC#111
Hey, I don't know if you've solved your issue yet, but I sure had a ton of similar problems a few months back. I took my unit out - didn't take very long - and sent it to Turbo Tunes for the reset. Works great now. Cost $120 and is all updated with current OS, etc.
turbotunes.com
Check 'em out.
Posted Feb 25, 2012 · 15:59 UTC#112
I am also having issues with mine, with the using stuck in a constant reboot loop.
The turbotunes.com option seems good, but I would rather not have to ship my radio internationally and be without it for a long amount of time, and honestly would much rather not have to pay 120$.
So if nayone has these files, I would also be very thank-full.
Posted Feb 29, 2012 · 04:06 UTC#113
I installed firmware version 3.0 from eBay store Kofat. It was $29 and works flawlessly. Good luck!
Posted Aug 01, 2012 · 23:35 UTC#114
Anyone have the files needed for this? My F90BT just started doing this..... Not sure what version I'm on......
And if I find 3.0 would installing that fix my problem too? Thx! :?
Posted Aug 02, 2012 · 00:58 UTC#115
Read the pinned threads up top. Fix in 2 before you do 3
Posted Aug 04, 2012 · 09:09 UTC#116
I tried using a 2.0 backup but it didn't work... so I did it again but this time I was able to get it working by copying the 3.0 backup files instead which upgraded me at the same time! Woot! Going to try to upgrade to 4.0.... but what does 4.0 provide since it doesn't come with maps?
2nd question is, since it doesn't come with maps, I should be able to copy the maps folder from the 3.0 to the 4.0 and load that right? Thoughts? Thx! My AVIC Boots up so much faster now too.... I'm currently uploading the files to my web server so I will mirror these files for everyone to share since BT is unreliable most of the time. Thanks!
Edited Aug 04, 2012 by enkrypt3d
Posted Aug 04, 2012 · 17:48 UTC#117
If you live on east cost of US you will be all set. If you live in west coast may need some PIOs. You can go into APL2 igo content PIOs and Map files and see what's in there.
Yes you can copy 3.0 maps but would defeat purpous of update as its primarily maps.
Posted Aug 04, 2012 · 19:36 UTC#118
So why doesn't 4.0 come with the updated maps for USA? It doesn't make any sense. Can someone please post a complete copy of 4.0? Thanks!
Posted Aug 04, 2012 · 20:31 UTC#119
The 4.0 isn't real it's a Hybrid. Go to hacks mods section to read more about it. Overall be happy there is that much. If you want to create your own compilation with maps feel free.
Posted Aug 05, 2012 · 06:02 UTC#120
http://www.enkrypted.com/4.01.zip
Yup just got this loaded and used the latest maps I could find (2012) and 3d buildings and it works great....
Posted Aug 05, 2012 · 12:57 UTC#121
Correct. That's what you had from within that torrent but you can not fit all US and Canada with all states PIO
Edited Aug 05, 2012 by tail24
Posted Aug 06, 2012 · 06:36 UTC#122
Feel free to post these on the original thread (my mirrors) Thanks!
Posted Oct 28, 2012 · 14:37 UTC#123
whats up guys i been reading the forum for a while now and i think my issue is very far fetched!!!!
when i turn on my unit i have no screen action but the lights around the volume knob comes on
and thats it!!! im able to get into the service screen for the wince update but all im getting is
a message that says progress read 100% and thats it...so i try to do the test mode and i get nothing!
any ideas?
Posted Oct 29, 2012 · 01:26 UTC#124
Try running a pioneer firmware update for 2.07 after you've flashed wince
Posted Nov 22, 2012 · 04:03 UTC#125
Does anyone have a direct link or a torrent to these files to fix a rebooting AVIC-F90BT?
Page 5 of 6
