- bootup time
- slow menus and button responses
I agree with these.
- bluetooth - hangs for 50 seconds after most calls
I have had occasional problems but very limited and seems to be better with the 2.006.
- the reverse camera takes 10 seconds to come on after starting the car
Not using a reverse camera at present but this would not be an issue for me, I can wait.
- ipod VR mode sucks - I have to go through the menu to turn it on and off again. Good lord how hard is it to add a small icon in the corner of the ipod source interface that would initiate this process without having to go through crap load of menus?!?!
I am not using an ipod so no issues for me - I do sympathize for you ipod users.
- when I am in the settings and I press the upper left corner, it takes me to the source selection rather than the actual source
Not really an issue for me but interface could be smarter.
- the fader/balancer is slowwww
- the EQ settings customization is slowwwwwwww
Never found this to be an issue. I pretty much set my settings then forget it. Rarely ever change anything.
- selection of songs in SD, the selection of XM radio channels, the selection of artists or genres via ipod are all painfully slow
- I cant actually SEE what song is currently on when in ipod/SD/XM mode and in song/preset selection mode. This has got to be the stupidest UI decision EVER. Why should I have to toggle back and forth between modes just to see who is playing, and use the preset mode?
I don't have XM or ipod but I do find it stupid that while listening to the radio I have to keep changing the disp mode to go between station name display, artist name and song name. Why can't we have them all scrool or have multiple lines of info?
- trying to initiate a phone call within 30 seconds of bootup - currently my system "reboots", then takes 2 minutes to finish booting, and ends up putting me in the phone call menu. Just press the button after 10 seconds, or 15 seconds, and it freaks out.
I can wait for the system to boot up, but I never had a problem with the system rebooting when trying to use the phone. I have had a couple of random reboots though.
- takes 2 minutes to connect to the phone
Not an issue for me.
- turn the car off while on a phone call, takes who knows how long for the phone to kick over to handset mode. My wife's OEM system takes 2 seconds, if that.
Another non issue for me. I never noticed the time lag. I don't talk on the phone a lot. My phone stays in a belt holster. I just shut the car off and walk away.
- When you reach your fucking destination, the damn thing wont end the route automatically! After it says your destination has been reached it needs to STFU.
Mine unit usually ends the route if it realizes I am at my destination although many times it does not realize I am in the right place since gps is sometimes off slightly due to a destination like some store being off the road a bit.
- It randomly decides to automatically set the route to home, for no reason whatsoever when you turn it on! This may be hard to test since it does it only once a month or so. You know it has happened if you turn it on and before the screen pops up it tells you to take your next left.
Nevr had this happen in the four plus months I have had my unit. Sounds like a bad unit to me.
- The ipod randomly connects when you turn it on. I get about a 60% connect rate despite a brand new cable, and perfectly good ipod touch. Restarting the car is the fix for this. Well after driving for 30 seconds and realizing it didnt connect.
Again I don't have an ipod, but this does seem to be a problem from other post I have read.
- OH! If the voice recognition does not understand you, it say "WHATWASIT?" That drives me nuts
It is voice recognition and it is not perfect. I have had cell phones that sucked at this too.
- Samantha in general just sucks.
I agree. There are many other voices there but for some reason Pioneer did not enable them. I notice quite a few different vioce files while I was watching my 2.006 update.
- the bluetooth randomly sets call volume. Sometimes a call is blaringly loud, sometimes I cant hear the caller at all, and sometimes the frigging controls for volume don't even show up!! Sometimes the music continues in the background (at full volume) and sometimes not.
I never had bluetooth volume issues. I am on my second F7010BT though because bluetooth quit working on my first one.
These are just the ones off the top of my head
My main complaints are as follows:
1. Slow response
2. Occasional lockups
3. Poor interface without choice of different color schemes on map screen. (Can be fixed through mods but should be available options)
4. HD module does not show station present info. (UNACCEPTABLE)
5. No nav voice mute. (Fix by mod only)
6. Clock on Radio screen is so small it is almost unusable.
7. Stock clock on nav screen is hard to read at times. (Another mod only fix)
8. Speed cam should be available without mod.
9. Not being able to chose the type of route I want to set at the time of inputting the route, such as choosing Fast, Avoid Highways, etc. at route time instead of have to go through a bunch of menus and change routing selections. If anyone has every used a Hertz Magellan system you will know how it should be. If you have not used one or any other good system rent a Hertz car with nav for one day to try it.
I might be able to think of some more but I don't want to at this time. Even with these fault I think it is a pretty nice unit for the price I paid.
