My new 3.0 impressions
By tacomaboy · Jul 16, 2009in General💬 140 posts👁️ 22,797 views
Page 5 of 6
Posted Jul 17, 2009 · 20:43 UTC#101
- unit switches to NAV when a call is placed or received
Well, to be honest I wouldn't call this a bug
Because when you are using navigation while e.g. watching a DVD (means: no map on the screen) and someone calls you, then the voice of the navigation will get muted - and if the unit wouldn't change back to the map mode, you wouldn't know where to drive to, because you have *no* voice out of the navigation system (muted by the phone call) and *no* view to the map, because the DVD is still runing.
Of course, a parameter switch would be nice to steer that behavior - but I wouldn't call it a bug on the first hand...
Bye,
Boby
in my wifes car you get the arrows in the bottom of the screen to point you the directions when on the phone. and beleave me she is on that phone a lot! (working as contractor nurse so every phone call can be work -> money)
Posted Jul 17, 2009 · 20:48 UTC#102
Bye,
Boby
Not so bad, that solution...and propably Pioneers way isn't the smartest. I just said that it's (maybe) not a bug, but was implemented intentionally. So, maybe to put it on a wish list would help more than to keep claiming this being a bug?
Posted Jul 17, 2009 · 21:14 UTC#103
Ahh if its already booted, then it takes mayb 3 seconds which is not so bad. But 99% of the time, the car is turned off before I kick it into reverse.
Start car, switch to reverse -- my camera comes right up.
Switch car, pick nose, switch to reverse -- have to wait for system to boot before it switches.
Posted Jul 17, 2009 · 21:29 UTC#104
Switch car, pick noseignore person honking behind you to back out already!, switch to reverse -- have to wait for system to boot before it switches.
fixed hehe.
Also, how does it take you 10 seconds to put on a seat belt?
Posted Jul 17, 2009 · 22:05 UTC#105
honestly why do you guys need a rear camera... kill the kid that was running behind your car... evolution of the fittest :)
Posted Jul 17, 2009 · 22:14 UTC#106
The only thing I have to compare the F900BT to is the Lexus factory navigation system. If I were to rate the two comparatively, I would give the F900BT a 3 out of 10 and the Lexus system a 10 out of 10. It's a world of difference. I just don't understand why, after many many years of research and development, Pioneer can't develop a system which can compete with the factory navigation systems.
Posted Jul 17, 2009 · 22:19 UTC#107
where is this "on the side of the road" at? can someone PM me and clue me in?
Posted Jul 17, 2009 · 22:23 UTC#108
And if it was your kid that wasn't so fit would you shed a tear or even care?
Really we've driven without them for about 100 years. Mind you as the cars become safer there appears to be more blind spots as well as the American fascination with SUV's that makes backing up a challenge.
Pioneer with the F series fits the bill of "Jack of all trades and master of none".
Posted Jul 17, 2009 · 23:10 UTC#109
Sorry you're not happy with your Avic. But I did the WinCE update and it did make a diference, Thanks for the tutorial : )
For the best and only real fix in the 3.0 update - just update WinCE for free and legitimately (at your own risk of course)
1. Download the 3.0101 update here: http://www.pioneerelectronics.com/PUSA/ ... port?tab=B
2. copy the WINCEIMG.bin and WINCEIMG.cks from the zip file onto formatted SD card or USB thumbdrive.
3. Disconnect any USB connections connected to your unit (Ipod, USB drive). Power it up.
4. When the pioneer logo comes up, press and hold the menu, map, eject and the reset button at the same time. When you hear a pop sound from your speakers, let go of the eject button but continue to hold menu, reset and map buttons. This will bring you to a blue screen where you will have to enter the service combination. Press the volume knob in this sequence and you will see * signs for each push: Up, Up, Down, Menu, Left, Right.
5. Once there, go to the option that says Update WinCE. Be careful with not to press the knob while trying to move up and down, or you might press the wrong choice by accident.
6. Insert the SD card or USB thumbdrive that has WINCEIMG.bin and WINCEIMG.cks on it
7. Select Update using SD/USB (*WITHOUT FORMATTING*) option.
8. Wait for the update to finish. When the prompt says to restart your unit, take out the SD, and enjoy faster button presses.
Props to GCL915, adamdenterkin,Retell and others for this (I compressed it to just do the Windows update).
If you somehow *magically* find the 3.0 software lying on the side of the road as I did, then go ahead and:
7. Select Update using SD/USB (*FORMATT*) option.
8. Wait for the update to finish. When the prompt says to restart your unit, take out the SD insert the testmode 2.3 SD card (download/file.php?id=7376) copy the actual testmode folder (not just its contents) to an SD card.
9. When in windows testmode, plug in the USB drive with the backup you downloaded in Step 1.
10. Go to start, control panel, Storage.
11. Unmount FlashDisk, and press FORMAT.
12. Once formatted, create a new partition and call it part0. Mount it back up.
13. Copy ALL files from USB drive backup to FlashDisk This should take about 40 min or so
14. Take out any SD cards from the unit and reboot.
Posted Jul 17, 2009 · 23:15 UTC#110
fixed hehe.
Dunno... I put the belt on first.
Posted Jul 17, 2009 · 23:32 UTC#111
This link does not seem to work anymore. Is anyone willing to send the files to me, or host them elsewhere?
Posted Jul 17, 2009 · 23:49 UTC#112
Uh-oh. Followed the directions to update WinCE posted here and it seemed to work until I booted up my F700BT and now the system startup sceen remains. I can access my radio and SD music and my backup camera works but can't get the navi functions to work since it tells my to wait for system startup in progress.
I attempted to restore my last backed up and working flash disk and that didn't work. Attempted to reload the default backed up flash disk I had and that didn't fix it. I just now thought I'd load the firmware update 2.006 thinking surely this would fix it--but it didn't. I think I may have semi bricked this thing. Could I have downloaded a corrupt WINCEIMG.bin and or corrupt WINCIEMG.cks?
Help?
Posted Jul 17, 2009 · 23:55 UTC#113
Help?
You have to use a hacked ezrider to use the latest WinCE update.... or get the full 3.0 Flash Disk file I uploaded to turboss ftp
Posted Jul 18, 2009 · 00:27 UTC#114
Thank you, thank you SK360--it was the hacked ezrider I failed to remember. It now works and I've restored my datazip and mods (except Guga's theme mod-which I'll have to figure out where I put all that stuff again).
Seems that the button pushes are snappier--but I'm not sure yet--just relieved to be back up and running since I'm one of those that has really enjoyed this unit-warts and all.
Posted Jul 18, 2009 · 02:29 UTC#115
This is a helpful forum. I fall squarely into the paying $1100 dollars for mine and very unhappy. I made a decision to support my local dealer, who then wanted to charge me for the uninstall, and full retail and install for another unit if I wanted to swap! Then I would have to sell it for whatever on sBay.
So I have learned to live with it. It frustrates me to no end--not because it doesn't work, but because it does everything so poorly, and every step is more difficult than it has to be. Many people don't mind going through several steps to get to do something, but I do. It especially hurts because this unit has the potential to be freakin' awesome. So close and yet so far!
I had this vision (a delusion) that I would be able to get into the car, and say "audio: select CD" then "navigation: destination Dairy Queen" then after I am riding along, "phone: call Steve". Is this too much to ask? Apparently so.
I get used to the mediocrity after a while, then I borrow my sister's Garmin Nuvi and all of a sudden realize that the display is giving me useful information! Wow! I can even see time to go in the day time! I can touch the buttons! Wow! I can adjust the phone call volume.
Sarcasm aside, I do like the audio quality though I still plan on adding an aftermarker equalizer. The crossover and sub flexibility is great! I do like having a built in Nav system to get me out of New Orleans late at night, and I just leave the voice off entirely. The radio reception in my car is terrific. Even if balky, I do a lot of driving and being able to have bluetooth built in is much safer.
So, I can live with it, but would much rather have something better. It did not come close to meeting my expectations. I am not expecting much from 3.0, but any change is welcome. I plan to learn to hack it, and with the help of all the expertise on the forums may actually have some fun with this Nav!
Thanks to everyone who contributes to this.
Mark
Posted Jul 18, 2009 · 02:43 UTC#116
your welcome mark :)
Posted Jul 18, 2009 · 03:45 UTC#117
Ok, so I tried downloading the files from the ftp://www.turboss.com and they didn't show up on my computer.
I sincerely apologize for my lack of computer program cloning and formating etc etc.
If anyone wants to walk me through it via AIM let me know.
sidewalksquare on AIM
I don't have much to give but if you have att cell phone I can hook you up on the back end.
Sorry again for being a noob!
G-
Posted Jul 18, 2009 · 11:39 UTC#118
does this hack include the updated maps, like the $60 version does?
Posted Jul 18, 2009 · 15:47 UTC#119
Well, to me, a Software Engineer with a Masters in Software Engineering and 8 years experience under my belt,
Then, as a software engineer, you should be familiar with rules 22 and 23 of the unwritten rules of systems engineering.
*Systems Management Risk. The systems engineering management of a large project is very difficult in the start up phase. Requirements are late. Of course they are late but engineering should never use that as an excuse and fail to conduct parametric analysis around expected requirement limits. Staffing is under the planned level. Design engineering is yelling for firm requirements as if the system engineer knows what the requirements are but just won't tell. The result is that the Chief Systems Engineer is under fire and may be replaced by a new person who is given a new longer schedule and increased budget and perhaps reduced expectation of results. This typical half life of one year makes some people cautious.
The Twenty Second Law:
Never go in with the first wave.
*More Risk. It is not clear that you can succeed if you are part of the second wave. Some projects are so difficult that an extension of the law is as follows:
The Twenty Third Law:
Never go in with the second wave either.
http://evansopticalengineering.com/Page00/sysenlaw.htm
:wink:
Posted Jul 18, 2009 · 18:21 UTC#120
I'm the same way. That navi and bluetooth works unbelievably well. Lexus really has it figured out.
Posted Jul 19, 2009 · 08:55 UTC#121
Having to pull out then reinsert the usb/sd card everytime you turn the deck on is nonsense. Good thing that is bypassable but still shouldn't have to go through hoops like that.
Another thing is that the songs end before the end of the song on usb/sd cards...wtf?
Load time of usb/sd cards is horrible..
Anyone know if these going to be fixed in the 3.0 update?
"GPS signal lost" so annoying when i have the woofers up. :( oh well
Posted Jul 19, 2009 · 17:27 UTC#122
Maybe try adjusting the sound settings. I have a relatively large sub in my car and I don't recall it being used when announcing GPS thingers. Unless you have the crossover turned up really high, in which case it would be emphasizing the highs on the sub as well.
Posted Jul 19, 2009 · 17:36 UTC#123
Toyota and Lexus use Fujitsu Ten (i.e. Eclipse) systems. I have decided to go with the AVN726e. I have done research and messed with one in the store and it is rock solid. INSTANT bootup.
Posted Jul 19, 2009 · 17:39 UTC#124
:wink:
Sounds very familiar - like every major project I have been in. Pioneer went with the first wave. No real requirements and so Engineers(If you want to call em that) just hacked out what they could with no design.
Posted Jul 19, 2009 · 17:44 UTC#125
I've updated my EU f900bt to the 3.x firmware (taken from the X series update). I stuck with the original maps.
First impressions are definitely favourable, even if there have been no revolutionary changes.
Time to iPod play is 30 sec, time to bluetooth phone connection is 1m 18s. Not much change there. However, the screen is immeasurably more responsive, with very little lag (due to the WinCE update, I believe). This makes it much more pleasurable to use.
The bluetooth phone software seems a little less buggy - so far no problems with calls not being transferred to the car unit. Also, so far the call controls appear on the screen each time, in contrast to previously.
I was also having strange intermittent problems with the left channel of iPod audio becoming corrupted, which seems to have resolved with the update.
Sadly, the useless iPod navigation system remains. Why can't we use the knob to browse the iPod? Using the touch screen is frustrating and non-intuitive (although a bit less frustrating now that the screen lag is fixed).
All in all, a worthwhile update, if just to get the F900BT to what it should have been at version 1.0
Page 5 of 6
