Complete 3.0 Install Guide
By Retell · Jul 18, 2009in Hacks/Mods💬 968 posts👁️ 380,894 views
Page 15 of 39
Posted Jul 29, 2009 · 21:14 UTC#351
the new one :
map version : 02.000400
version: 3.010100
Posted Jul 30, 2009 · 02:02 UTC#352
As others have said, I recommend doing a "select all/delete" on your current flash disk contents before copying over the new files. When I did the install the first time, just copying the new files over without deleting the old files, I would have issues with playing mp3s from the SD card and also really slow or non working steering wheel controls. I reinstalled, deleting the old flash disk files first, and everything works great now.
Posted Jul 30, 2009 · 02:13 UTC#353
what kind of issues? Screen freezing up and stuff?
Posted Jul 30, 2009 · 19:48 UTC#354
My bluetooth is working a lot better with the 3.0. I'm not saying it has a bluetooth update in it because i dont know for sure but my HTC phone had a lot of problems with the unit before. Although I don't know if it was my phone's fault (many htc users had trouble) or the navi i DID have a lot of trouble with the call not ending after hangup, the pickup/hangup buttons not coming up, phone book not conecting without extra firmware. After the 3.0 i didnt change anything on my phone. Yet the nav automatically imported my contacts without any firmware needed. And still after days of usage, the bluetooth has had no new troubles. =D
Posted Jul 30, 2009 · 19:56 UTC#355
+1 ...since the 3.0 update when I end a call either on my phone directly or using the nav it ends right away. Before, it would take 30-45 seconds for my ipod/radio to come back on.
Also noticed that if I am using my nav in route and I make a call, the amount of space the call info takes is much smaller! Instead of taking the bottom third of my navy screen, the call box has been reduced to a small square off to the side.
Definitely happy!
Posted Jul 31, 2009 · 13:55 UTC#356
omg batman, this update is the shit. one problem i was having was the ipod nav buttons were ass to use. you had to make sure you touched exactly the white arrows to get it to switch tracks. now its great. i just finished the 3.0.10 update (or whatever it is) and its working fine. i just dont have my european maps, which does indeed suck.
Posted Jul 31, 2009 · 16:19 UTC#357
First Post here, for those of you having problems with downloading via torrent, someone posted a mirror that is pretty fast, im downloading at 700K
http://energy.wub.nu/Pioneer/x910bt.zip
Posted Jul 31, 2009 · 17:39 UTC#358
Retell, you rock! Install went smooth, other than my screen being misaligned so I couldn't get the top menu buttons in WinCE. Thank God for people like you who go out of their way to help others! My hats off to you. You are a gentleman and a scholar.
Dear Pioneer, for about a year I have been struggling with this unit. Quite a few times my frustration bubbled over and my fist was close to smashing through it. Didn't any of your staff have it in their cars? This experience has sullied Pioneer's name in my mind. That being said, the unit now operates properly.
Posted Jul 31, 2009 · 17:49 UTC#359
That comes up a lot. If you ever go into testmode, the FIRST thing you should do is open Control Panel and run the Stylus Calibration utility. The process takes perhaps 30 seconds and eliminates all problems with clicking anywhere on the screen.
Posted Jul 31, 2009 · 20:10 UTC#360
Of coarse! I was so focused on continuing the process I dragged and dropped and used the keyboard option. Next time I'm in there, I'll configure. Thanks.
Posted Jul 31, 2009 · 23:39 UTC#362
hey i need some help mess up at the end can someone help me my unit is not bricked yet If you can help me please call me cell 201 982 5782
Posted Jul 31, 2009 · 23:46 UTC#363
um first of all I can barely understand what you just said...
secondly, what exactly is your problem? Where did you get stuck?
viewtopic.php?f=34&t=25817
This guide is much easier to understand... read it... or print it out and try it again..
Posted Jul 31, 2009 · 23:51 UTC#364
at the end the "my flash disk" i accidently tried putting the x910 bt zip into that i deleted some stuff and now the unit just keeps reseting blue screen then black
Posted Jul 31, 2009 · 23:54 UTC#365
then start over at step one... and copy the correct files to the proper place... you need to UNZIP the .zip file with WINRAR (www.rarlab.com) and then follow the instructions in the link above.
Posted Aug 01, 2009 · 00:00 UTC#366
alright one question for the end for the x910 file where i am putting that exactly.
Thank for your help so far
Posted Aug 01, 2009 · 00:07 UTC#367
Copy the files inside that zip file into the "\my flash disk".... it should look like this:
http://www.imagebam.com/image/7d979142574344
But first delete everything that is in your "\My Flash Disk" .....then copy the files over... be sure to copy the files INSIDE "My Flash Disk" from the SD card and not the folder "My Flash Disk"...
Posted Aug 01, 2009 · 00:38 UTC#368
but there is only that one x910 file ???
Posted Aug 01, 2009 · 01:33 UTC#369
Did u unzip it???
Posted Aug 01, 2009 · 01:38 UTC#370
I think you better do a little more reading before you really hose your unit. The instructions are very simple. There are too many posts about on how to do this. I know it can be frustrating, but follow the instructions carefully and you will be fine...print them out.. Here is a good guide
viewtopic.php?f=34&t=25817&start=0
Posted Aug 01, 2009 · 02:02 UTC#371
+1... or buy the official one...
Posted Aug 01, 2009 · 02:16 UTC#372
its not hard at all i put all the files on one sd card and works no problem?
Posted Aug 01, 2009 · 02:37 UTC#373
yes but you have to follow a few different steps if its all on one card.... as in be sure u are copying the correct files etc
Posted Aug 01, 2009 · 18:13 UTC#374
thanks enkrypt3d. i figured it out thanks for all the help.
Posted Aug 02, 2009 · 01:06 UTC#375
Just finished this upgrade, THANK YOU!!!! This was the easiest upgrade I ever did. Tomorrow I will tackle getting to 3.01. I'm just thankful for Heads up mode in 2d, this was my only complaint about my f900.
Page 15 of 39
