Complete 3.0 Install Guide
By Retell · Jul 18, 2009in Hacks/Mods💬 968 posts👁️ 380,894 views
Page 17 of 39
Posted Aug 08, 2009 · 05:12 UTC#401
Can you REINSTALL 3.0 ?
would just redoing the process wipe everything and reinstall properly?
Posted Aug 08, 2009 · 05:37 UTC#402
i dont have an alp2 folder. Whats going on?
Posted Aug 08, 2009 · 15:41 UTC#403
Has anyone had a problem with the wince upgrade screen. My F90bt goes to this screen and that's as far as it will go. Cannot get it to respond or recognize the sd card with the two wince img files on it.
Posted Aug 08, 2009 · 16:02 UTC#404
Try wiping your card and re-downloading everything using perhaps a different web browser. I fear people may be getting corrupt downloads and that's why you're getting problems. I performed the upgrade with no problems, my SD card works perfectly when playing MP3's off it it no matter what screen I'm in...
Posted Aug 08, 2009 · 16:37 UTC#405
This may sound stupid..do those files need to be unzipped first... i tried to unzip them .. i got file broken error.
also is this just a firmware upgrade or it includes maps also?
Posted Aug 09, 2009 · 15:17 UTC#406
I don't know if this will help anyone here but when I did my update I started doing it with my car ignition in the "ACC" (Accessory) setting, this caused the unit to continuously restart a few seconds after inputting the password combination via the volume button.
The car's ignition has to be in the "ON" setting to do this update. Make sure your battery is able to power your unit for at least 20 mins otherwise you may want to start the car and keep it running before you start the process. But I would not advise you do this unless totally necessary, be kind to the environment. :mrgreen:
I'm having that same problem regardless of whether my car is running or not (and I measured my battery's output, that's not the problem).
I'll have to pull the deck out and install it on my bench hooked up to a power supply, hopefully that will fix the problem.
Posted Aug 09, 2009 · 19:07 UTC#407
TIPS on 3.0 Install:
1. When updating the WinCE version, do it FAST and try multiple times, it should eventually work! otherwise the screen goes black.
2. Only one sd card is needed, you can power down your stereo in between steps if needed as well.
2. torrent files requires you to download a converter, I downloaded "BitTorrent" for free and it converted the file.
3. ALWAYS MAKE a BACKUP!!!!!!!! create an empty file on your SD, copy and paste everything in "myflashdisk" onto your SD card, then proceed to overwrite with the new 3.0 files.
4. Be prepared to wait, the update takes quite a while.
Consequences:
1. You can no longer use the AUTOMATIC updates after you to update to 3.0 using this process, the 3.01 update off the pioneer website will not work, its the hacking method for everything forward.
My voice recognition no longer works with my Iphone contacts, only my music, this may be a result of the newest Iphone update however, either way....it really sucks and i hope it isn't from the way I did this 3.0 upgrade.
Posted Aug 09, 2009 · 20:50 UTC#408
This is false, I was able to use the automatic update from the Pioneer website..if you are unable to perform the update then you did something wrong and should start over, unless you don't mind copying the files for each update.
Posted Aug 09, 2009 · 21:17 UTC#409
I thought I'd add to this thread instead of starting a new one.
I installed 3.0 on my F900 as per the instructions provided in the first post, but now my unit doesn't boot up properly. It boots fine up to the menu screen, but "System is starting up please wait" won't go away.
I've done some searching and tried deleting the gpsparaxx.bin files and clearing the user\userdata\ contents with still no luck.
I have performed the steps provided for the 3.0 upgrade carefully 3 times now, and I always get the same result. Is there something I'm missing?
Posted Aug 09, 2009 · 22:46 UTC#410
I had the same issue, but only when I tried to install the 3.0.1 update from the Pioneer website.
The only way I could overcome it was to go back all the way back to installing the WINCE updates, then the 3.00. I'm not tackling the 3.0.1 again until someone posts a definitive "how-to" on what the best way to do it is. I wasted enough of my Saturday trying to do that update the first time. ;)
By the way, do we have a list of what's supposedly fixed/addressed in the 3.0.1 update?
Posted Aug 09, 2009 · 23:10 UTC#411
I first upgraded to 3.0 on Friday didn't add any mods until Saturday. I decided to upgrade to 3.01 today and add my mods back on. I have not had one issues as of yet. I got the upgrade from the pioneer site. Also on the site list all the fixes that 3.01 are suppose to fix. They are listed below.
AVIC X-Series Firmware Update Change History
Applicable models: AVIC-X910BT, AVIC-X710BT
Ver 3.010100
CHANGE HISTORY:
- Fixes the case that “distance to destination” is incorrectly displayed in French Canadian kilometer mode.
- Improves the reliability of “Delete All User Data” feature
- Improves 2D map display performance in scales > 20,000ft.
- Fixes the case that city names on 2D map may not be displayed when large amounts of MSN Traffic data is present.
- Enhances reliability during firmware update process.
- Fixes the case where Track Log data is not retained in memory when unit is shut off.
- Improves reliability of iPod alphabetical search feature.
Posted Aug 10, 2009 · 00:44 UTC#412
http://www.pioneerelectronics.com/ephox ... Update.pdf
Use this PDF for the 3.0 to 3.01 update.. its so easy I'm not sure how you can mess this up since you were able to do the 3.0 upgrade as far as I can tell.
Just put the ""LPUE080" folder on the root of the SD card and boot up the AVIC with the SD card in it and it will start automatically...
I also tested MP3 playback from my SD card and changing tracks is instant... For those that are having slow performance from their SD cards, I would try getting a better quality SD card. I am using a 2GB Sandisk from Radioshack which was about $14... I am able to copy files to it from my PC at about 2-3MB/s so the avic should be fine with this.
Posted Aug 10, 2009 · 00:53 UTC#413
funny I'm quoting myself. I attempted 3.0 again and noticed an error message when copying the My Flashdisk from the torrent. It says "Error: can not copy canada.poi". The torrent must have gotten corrupted for me while downloading. It took forever. I'll try it again later.
Posted Aug 10, 2009 · 01:08 UTC#414
try unzipping it with winrar on your pc...
Posted Aug 10, 2009 · 08:38 UTC#415
Allright. So. I redid 3.0 and formatted My Flash Device (I, for some reason, only had 20MB left. Completely unmodded. Strange.). After that, I had 200+ MB free, and installed 3.01 just peachy.
Two questions:
1. I'm STILL getting that incredibly laggy inputs playing MP3s from an SD card. Any ideas?
Things I'm trying tomorrow to help:
A) Reverting to my non-modded Data.zip file. (See below)
B) Changing to a 4GB SD card from a 16GB SD card. (If that doesn't work, I'll try a 2GB I suppose. It's fast as heck.)
2. I edited my data file and put the speed limit thingie that's normally at 16 to 256. I was under the impression that was a bypass so I can have full access to the options menu while driving and such. It didn't seem to work. I still need the parking brake on or what? Do I have to do the hard bypass as well? (I don't have the tools to get my deck out, so soft bypass is my only option)
Posted Aug 10, 2009 · 11:11 UTC#416
the sizef of the sd card wont matter cause i still got the freeze ups from the sd card. I went back to 2.06 and no problems whatsoever. Waiting on the pioneer sd updates for my F900bt.
Posted Aug 10, 2009 · 12:10 UTC#417
I'll give that a shot. I used winzip initially. I'm downloading it again.
Posted Aug 10, 2009 · 15:47 UTC#418
For those with problems upgrading WinCE. I've had this problem.. Just format the sd card in fat32, copy the two files, power on the radio, when the logo appears, push the four buttons (Menu, Map, Eject and Reset), wait like 5 seconds, leave the reset button, shot after that, release the Eject button, wait for the blue screen, release the two other buttons. On mine, i'd have a "please restart again" message, but i've been capable to entering the code. Enter your SD Card, Select WinCE Upgrade, Select SD Card (Format), and it will takes about 2 minutes to reflash the WinCE.
Hope this will helps ...
Posted Aug 10, 2009 · 19:26 UTC#419
So Samantha voice is gone after update? or I am missing something???
Posted Aug 11, 2009 · 02:23 UTC#420
thank you much for this thread. my system was running 2.0 but stopped working for some odd reason and kept playing music only for a few minutes than shutting off and i couldnt even get to the maps without the system startup message. i first had messed up this prodecure and it only had showed a black screen but eventually got it all to work after many attempts and now it is working better then it has ever worked and saved myself 600 dollars to replace it. i appreciate these instructions very much it works brilliantly.
Posted Aug 11, 2009 · 16:44 UTC#421
Please HELP.
I followed the instructions as best I could,
I copied the "my flash disk" (unzipped )from the torrent to the my flash drive on the f900.
then i copied the "data" file to the "my flash drive/apl2/igo" folder.
I pressed the RESET and EJECT for 5 seconds...
now my f900 only will boot to windows. and if i take out the sd card with testmode on it it will just shut off while booting and show nothing at all.
What have I done wrong?
my f900 has been reduced to an old useless PC.
THANK YOU SO MUCH FOR HELPING!!!!
Posted Aug 11, 2009 · 18:19 UTC#422
Please HELP.
viewtopic.php?f=34&t=25817
Try this guide its much easier to understand... print it out and follow along in your car... good luck.
Be sure you are coping the right files to the right place...
http://www.imagebam.com/image/5fa19542574343
this is what you should see on your "\My Flash Disk" after copying... be sure there is no testmode folder on the AVIC's Flash Disk otherwise it will get confused...
So go through this process again and DELETE everything in the \My Flash Disk drive on the avic and be sure to copy ONLY the stuff from the torrent and not anything else... dont do any mods for now... leave the data.zip out for now. you can always do the mods later. for now just get 3.0 working.
Posted Aug 12, 2009 · 00:22 UTC#423
Figured it out. It turns out that my initial download of the torrent got corrupted. Thanks for everyones help.
Posted Aug 12, 2009 · 17:25 UTC#424
Hi guys. I tried searching but got no hits; however is it possible that I update the Wince through my sd card and upload the new files through a 2 gig usb drive?
Posted Aug 16, 2009 · 18:09 UTC#425
Ok so I'm officially a newbie at this. I recently bought a BT7100 and was told that this hack was the way to go to bypass the video functionality. I have followed the steps as stated in the install guide and have hit a wall. I get to step 9 and when looking for the flash dump folder it seems to be an empty folder. When I copy it on the the Avic it takes almost no time as the folder is empty. Also when looking for the "My flash disk\APL2\iGo" on the Avic i can't find it. Any help someone can give would be great. Thanks
Page 17 of 39
