IDT skin#1 v5.5 03/02/10 9download link to be updated)
By ill.die.trying · Aug 05, 2009in Completed Mods/Themes💬 1,618 posts👁️ 210,687 views
Page 14 of 65
Posted Aug 22, 2009 · 23:49 UTC#326
if you're referring to the icons with the black background it means that there's something wrong with their alpha layer
they are all screwed up even the ones that dont look screwed up. I replaced all the icons cmh928 had because some of the ones he had were not done well, so i tried to make them look better, so they may be screwed up too.
ok try this one📎 onmapicons.zip
first of all thanks a lot you have always been good to me. the house has a white outline around it, is that the same problem as the ones with the black around them? Is this something i have to do in photoshop?
Posted Aug 22, 2009 · 23:52 UTC#327
no problem bro, it doesn't matter what the background is on the picture,it'sthe alpha channels that matter,
Posted Aug 22, 2009 · 23:54 UTC#328
is there somewhere on here that expains this so i can read on it?
Posted Aug 22, 2009 · 23:56 UTC#329
not that i know, i just figured it out from the daycar bmp thread
Posted Aug 23, 2009 · 00:04 UTC#330
I think you answered this once before but what setting in nav800 480 do I have to change to make the clock font a little more bold? I already changed the glowsize and fontsize but i think there was another setting i had to change just dont remember which.
Posted Aug 23, 2009 · 00:29 UTC#331
maybe change the font to tahomabd
Posted Aug 23, 2009 · 00:50 UTC#332
wow you are good man that was it. amazing
Posted Aug 23, 2009 · 01:10 UTC#333
I know i am being a total pain in the ass but the home icon has a white outline around it I was hoping you could fix that for me also, please.
Thank you
addressselect_onmap.zip
Posted Aug 23, 2009 · 01:55 UTC#334
Finally had free time to update to 3.0 followed by installing your mods. Looks great! Thanks a lot, IDT!
On a different note, I don't know if it's just a faulty installation on my navi but when my zoom is at 1000ft (3D) the local street names are not given.
Posted Aug 23, 2009 · 03:30 UTC#335
wow read through that thread on how to mask the images and got my icons to look great. I am good with photoshop but just didn't understand the instructions at first. Everything works now.
Thanks IDT
Posted Aug 23, 2009 · 09:17 UTC#336
IDT,
This is a awsome hack and work ok but have one problem and have this with all 3.xxx mod hacks.
When hack installed my trafic info in navigation screen is not working anymore.
It is not finding any stations so no trafic info will be displayed.
When check just radio the normal TMC is available.
The org DATA file is not gving any problem, have others same problem here?
Iám using:
* 3.01 firmware(Europe) inc EZRider 3.01 hack
* TeleAtlas maps 2009
* Mod IDT 3.0 V3
could you check this part of your original sys.txt and compare it with the one included in my mod pack
[device]
IDT, thanks for help the device was for US so updated it to PIONEER746EW and TMC works again ....
Posted Aug 23, 2009 · 12:48 UTC#337
Hey IDT,
Do you know why my NAV does not automatically switch to the night map when it becomes night? I always have to press your button manually. Is it because of your mod or is it just my unit?
Posted Aug 23, 2009 · 13:31 UTC#338
Hey IDT,
is the setting set to automatic?
Posted Aug 23, 2009 · 14:11 UTC#339
IDT
This is by far the best mod I have used on my unit...I love it; easy and functional at the same time. Some beer money is heading your way soon. One question for you.. I noticed that you said you need a different scheme to have the route choices show in multiple colors. What scheme did you use on your photo? And is it available somewhere?
Again...love the setup; it is awesome
Regards,
Posted Aug 23, 2009 · 14:13 UTC#340
IDT
Regards,
i'm working on it right now bro, i'll have it up later,
Posted Aug 23, 2009 · 14:51 UTC#341
Thanks for the quick response..
Regards,
Posted Aug 23, 2009 · 14:59 UTC#342
Hey IDT,
It is set to automatic.
I just installed your V3, which is fantastic BTW, so i'm gonna have to see if it works again, but if you have any other ideas, that would be great.
Posted Aug 23, 2009 · 15:16 UTC#343
Mine too does not switch "automatically", so if you figure out how to make that work, please update this thread.
Posted Aug 23, 2009 · 15:19 UTC#344
minor update,
-poi onmap onrelease will go to search by name and onlongclick will bring you to poi search screen
-included in the download is a bunch of schemes, i edited the scheme to have different colors for the multidraw screen including the edited stock pioneer schemes
-if you want different sky on your nav just replace sky.bmp on GFX/DAY and GFX/NIGHT on the data.zip
instructions:
for newbies READ THE HACKS THREAD FIRST, don't just jump into doing a mod without enough knowledge,
1) first off this is not an auto installer,
2)extract files and transfer all files to a freshly formatted SD card
3)this already has testmode file so no need to add anything else
4)insert SD to unit,
5)boot up unit
***if this is your first time,PLEASE BACK UP YOUR FILES
6) copy DATA.ZIP, SYS.TXT, and DS-DIGI file to igo folder
7) to add a different scheme, come the contents of scheme folder MYFLASHDISK\APL2\IGO\CONTENT\SCHEME
**IT'S MANDATORY TO DELETE THE SAVE FILES, it's in My Flash Disk\USER\UserData\iGo\save, everything should be deleted except for favourites.dat if you have it
8) once done copying turn off the unit, remove sd card and then turn unit on,
any comments, suggestions are welcome, i need more than one set of eyes to get this thing going
any donations thru paypal are very much appreciated http://[email protected]
here's the lnik ftp://avic:[email protected]/illdietrying/IDT%203.0/
Posted Aug 23, 2009 · 15:20 UTC#345
i will look into it,
Posted Aug 23, 2009 · 15:24 UTC#346
lobelsteve
thanks for the donation bro
Posted Aug 23, 2009 · 16:35 UTC#347
Hey IDT I don't see the call button on the POI information screen.
Posted Aug 23, 2009 · 17:15 UTC#348
IDT, any luck with the clips_planes.ini file on your new schemes? I posted up on the street labels thread about my issue. I know that it's not the mod because it didn't work when I upgraded to 3.02. I tried to look up 2.0 Data.zips in order to find a good value but no go. Thanks for your time and help. I'd pay pioneer for what you've added so I guess I'm gonna have to fire up Paypal!
thanks!!
Posted Aug 23, 2009 · 17:30 UTC#349
Sorry guy, there are 3 files on the server, which ones do I need for a 746EW? Not the MSN, that's clear, but what anout the other 2?
Jörg
Posted Aug 23, 2009 · 17:39 UTC#350
do you have your phone connected? it would only show up if you have bluetooth connection
Page 14 of 65
