IDT skin#1 v5.5 03/02/10 9download link to be updated)
By ill.die.trying · Aug 05, 2009in Completed Mods/Themes💬 1,618 posts👁️ 210,687 views
Page 19 of 65
Posted Aug 25, 2009 · 23:38 UTC#451
I have question where i can get red light and speed camera files for Canada.
Posted Aug 25, 2009 · 23:43 UTC#452
IDT
Go to this address
3520 Canoncita Lane
Plano,TX 75023
Head South to Parker Road and make a right turn heading west on Parker
Continue to Coit and turn Right
1st Street to turn on is San Mateo. Make a right.
On my system, the numbers disappear on Parker and Coit and reappear on San Mateo
It appears to function the same way whether you are navigating or just cruising.
Regards,
M
Posted Aug 25, 2009 · 23:45 UTC#454
IDT
Go to this address
3520 Canoncita Lane
Plano,TX 75023
Regards,
M
i'll try it out later
Posted Aug 25, 2009 · 23:55 UTC#455
this is where i got mine from
http://www.gps-data-team.com/poi/canada/safety/
Thanks IDT . And what format i need to download
Posted Aug 25, 2009 · 23:57 UTC#456
igo txt format
Posted Aug 26, 2009 · 00:55 UTC#460
so how much are the F500BT selling for right now? the reason why i'm asking is so that i could easily check/modify the data.zip files in the house instead of going back and fort to my car, anyone selling a used one? all the donations i received will be used to buying an F500 so that i can troubleshoot faster,
Look, with your mod, the f500bt performance jumps 99% just like the big boy Avics, I love it more than my Avic-Z3, and my current OE system.... I find myself driving a little out of the way to enjoy the modded system a little more. I in for a little $$$ on a F500 if you decide to get one
we'll see in a couple of days if i could afford to get one,
Posted Aug 26, 2009 · 02:05 UTC#461
Okay, I'm a total newb. I'm not sure if this has been discussed or if it even is an issue. Is there a way to save the data from the trip computer? Every time I start the car, the trip computer resets itself. Just wondering if there is a setting I'm missing somewhere. Thanks for an awesome mod.
F
Posted Aug 26, 2009 · 02:13 UTC#462
F
it has been discussed before and no one has figured out yet how to do it,
Posted Aug 26, 2009 · 07:29 UTC#463
Hello Can anyone post a quick howto for using this mod on EU units? I see there was a message about getting the TMC in Europe to work, anything else (like taking out the MSN stuff and anything else we don't have).
Would be cool to have an IDT3.0 V3.1EU version!
next update will have an EU version with EU speedlimit signs and TMC shortcut instead of MSN, for now just use the IDT 3.0v3.1 and check the quote below for the TMC
When you change the following SYS.TXT lines:
[device]
type="PIONEER746EW" :arrow: **EW instead of UC, will enable TMC**
[interface]
skin="ui_pioneer"
default_day_color="COLORSCHEME~Pioneer Blue Day"
default_night_color="COLORSCHEME~Pioneer Blue Night"
tmc_events_icon_set="$tmc.spr" :arrow: **removing the 2 will use european style TMC event symbols*
small_tmc_events_icon_set="$smalltmc.spr" :arrow: **removing the 2 will use european style TMC event symbols*
show_kml_type=0
mapfontscale=200
Have fun
Jörg
for sure, one thing though
tmc_events_icon_set="$tmc.spr"     **removing the 2 will use european style TMC event symbols*
small_tmc_events_icon_set="$smalltmc.spr"     **removing the 2 will use european style TMC event symbols*
what do you mean 2?
If you compare to IDT's original SYS.TXT you will see there
tmc_events_icon_set="$tmc :arrow: 2.spr"
small_tmc_events_icon_set="$smalltmc :arrow: 2.spr"
the 2 points tu US style signs.
I hope that is clear now, any questions just ask
Posted Aug 26, 2009 · 08:40 UTC#464
Hey IDT,
found this:
[map]
nightmode_dependent_backlight="0"
auto_nightmode="0"
[screen]
nightmode="0"
[power]
backlight_sync_with_OS=1
powermgm_state="0"
What do you think? Can't find my SD cards at the moment, otherwise would try myself
rgds
Jörg
Posted Aug 26, 2009 · 14:34 UTC#465
IDT
I`m gonna atempt put trip comp on my 3.0v1 again...
Can you tell me in what files should I make changes?
Posted Aug 26, 2009 · 14:38 UTC#466
IDT
Can you tell me what files I should make changes?
before you proceed, why not use the latest version and just comment out the stuffs you dont want?
Posted Aug 26, 2009 · 14:47 UTC#467
IDT,
I have a general question on emulation of the Avic on our computers. I have emulated your V3.1 on my computer and was wondering how do I obtain a GPS signal because some of the icon on navigatemap isn't showing up (like settings, return home etc)
Posted Aug 26, 2009 · 14:53 UTC#468
IDT
make sense but I made some small changes on 3.0 myself too, plus on last 3v3 I dont like how the shortcuts geting smaler after you press them or they are fade it, also for some reason seems like respond of unit is much slower
I find multidraw and the POI function usless for me , that why I`m trying to tweek the simple but great 3v1
Posted Aug 26, 2009 · 15:14 UTC#469
IDT
i see,
add this on your navigatemap_800_480.ui
;Trip computer controls
add this on your desired button,
onrelease='run sc_tripresetrefresh, ui_NSEWtripcomp.show'
add this following bmps to your 800_480 folder
IDT_triphide.bmp#2
let me know how it goes
Posted Aug 26, 2009 · 15:36 UTC#470
i see,
IDT_triphide.bmp#2
I will
thanks alot
do I have to make any changes to setting_800_480.ui or navigetmap.ui and add tripcomputer_800_480.ui and tripcomputer.ui?
Posted Aug 26, 2009 · 16:00 UTC#471
IDT,
is your 3.1 mod directly compatible with GUGA's theme?
thanks,
Posted Aug 26, 2009 · 16:21 UTC#472
IDT,
thanks,
yes, i'm actually using it
Posted Aug 26, 2009 · 16:23 UTC#473
I will
thanks alot
good thing you reminded me, just copy and paste the tripcomputer.ui from v3 to your v1
Posted Aug 26, 2009 · 16:57 UTC#474
Well I got v3.1 (latest, MSN) installed on my F90BT. I've also copied over building files now twice, first from TA 2008.10, and now from my old Avic 2.0 setup (whatever version those were, 2008.04 maybe?). I get no buildings visible at all other than landmarks. I've got the worldwide license, plus the one that came with the 3.0 software. Seems like for whatever reason, my unit isnt liking the worldwide license. Need to figure this out as I miss seeing the buildings.
Trip computer: wow is this erratic to start up. I literally have to use a toothpick and click on a specific part of the speed sign to make it show up. If I use my finger I get the tilt settings. Need to do more testing all around, but I do really like the new features!
Posted Aug 26, 2009 · 17:03 UTC#475
for the buildings try the asbis license, you can find that on my previous 2.0 download
for the tripcomp shortcut, that was my bad as it was only the background that i had as a button, it will be fixed on the next one
Page 19 of 65
