I have read through the post regarding the trip computer and there are a lot more steps to adding this TC. I would rather follow your coding, So far I have done this:I added the files into my navigatemap_800_480.ui.
Then I added the bitmaps you listed.
Then i copied tripcomputer.ui and tripcomputer_800_480.ui into my data.zip file.
and you are saying that i need to add something into my templates_800_480.ui file and 2 additional bitmaps, Please explain.
1. What do I add this to """onrelease='run sc_tripresetrefresh, ui_NSEWtripcomp.show'""""? Is this for an onmap icon?
2. Should I just follow those instructions and pull the code out from your files including the main.ui file, setting_800_480.ui and variable_def.ui. Some of them are different then yours.
2. there just seems to be alot that was fixed since the instructions were posted and I would rather follow your set of instructions
Thank you hate to be a pain
hold off for now,
i'll have a complete how to later as soon as i get to work
