IDT skin#1 v5.5 03/02/10 9download link to be updated)
By ill.die.trying · Aug 05, 2009in Completed Mods/Themes💬 1,618 posts👁️ 210,687 views
Page 28 of 65
Posted Sep 03, 2009 · 20:04 UTC#676
Hello, i try to install 3D car :
"the car images are still there and you just have to rename them to daycar.bmp and nightcar.bmp in the common folder"
Can you give me the method to do that ?
can you give me the text i must replace please ..thanks
:wink:
Posted Sep 03, 2009 · 21:15 UTC#677
:wink:
1)extract the data.zip
2)go to data/ui_pioneer/common folder
3)rename daycar.bmp to daycar2.bmp,
7)rezip the data folder and you're done
Posted Sep 03, 2009 · 21:38 UTC#678
What is a file page setup option "Warning"?
Posted Sep 03, 2009 · 21:44 UTC#679
could you clarify?
Posted Sep 03, 2009 · 23:30 UTC#680
I just installed v3.5 and everything looks good so far. Will take me a little time to get used to all the operation changes. I stuck with 3.5 for now to keep the MSN Direct functionality.
One thing right off that I can't find (I've searched everywhere I think).... How do you change the Navi voice selection? I can't find any voices to choose from or where you even select them. The default voice is fine, but is it TTS?
Thanks... Great Mod.
Posted Sep 04, 2009 · 00:01 UTC#681
go to the main menu screen, click settings, then click system settings and then language
Posted Sep 04, 2009 · 00:23 UTC#682
Thanks IDT for your great mods, especially for euro versions, which surely cause you lot of extra work! I will soon send you some cash for all your hard work. Your mod is nearly perfect, there's only two things I'm missing from your mods (I can propably add these by myself too): house numbers and different type of arrow showing route when navigating.
viewtopic.php?f=34&t=26379&start=30
House number view in this mod is really useful, so maybe you will add similar function to your mod, too? Also, I tried this mod on my AVIC and although route arrow in screenshots of that thread is similar with route arrow in your mod, route arrow looked like this in my AVIC:
So I'm wondering how to change route arrow to look like that?
That example picture I posted is not from my avic, just example to show what type of route arrow I had with Sven's mod.
the house numbers are included in the data.zip, pressing the current street will show the housenumbers and pressing the housenumbers will hide it
Posted Sep 04, 2009 · 00:54 UTC#683
Thanks. I can't believe I missed that. I had gone through the setup screen multiple times looking for it. I guess it's just not something that I change very often.
In my previous mod that I was using with version 2(and I can't even remember which one I was using), there were updated voice files that made the speech sound slightly more real, and the voice file was just over 2mb compared to the current one which I believe is under 100k, not sure on that. If I copy the voice file over the current, should that work fine?
It also appears that the boot screen is the same custom screen from the last mod. Apparently it's not stored in the "My Flash Disk" folder as I replaced that whole folder during the 3.0 upgrade. I would like to also keep the previous modded selection screen (where you select Destination, Contacts, or Audio). Is that a simple file, or is that included in the data.zip file?
Thanks again! This is one awesome mod for 3.0.
Oh one BIG question on a feature that I've been wanting since the beginning. Is it possible to create a "detour" option? I also have a Garmin Nuvi and one useful feature is when you get caught in traffic, especially accidents, the Nuvi has a feature that allows you to press a "Detour" button and it will recalculate a path around your current path. It usually tries to bring you out on the same road maybe 10 or 15 miles further down. This is very useful for when the MSN Direct is out of service area. Any type of option for that on the Avic? I know you can set it to avoid a road, but I don't necessarily want to avoid the road forever... just enough to get around the tied up traffic.
Posted Sep 04, 2009 · 01:54 UTC#684
not sure if you could use the TTS file from the 2.0
kinda like road blocking feature, this mod has it
Posted Sep 04, 2009 · 02:21 UTC#685
Hi IDT Thanks for the new mod.I have a question when i drive no more pop out speedcam box with distance but i can hear the voice and if there any Highway Sign Boards for Canada.Thanks
Posted Sep 04, 2009 · 02:23 UTC#686
i have it fixed, 4.2 will be out hopefully tomorrow
Posted Sep 04, 2009 · 03:02 UTC#687
I guess I'm the only one with this problem.
I'm going to reinstall the 3.0 update via the x910 My Flash Disk and testmode.
Then I'll install IDT 4.0 and see what happens. Weird. I think it has to do with day/night and 3d color schemes....
I had the same problem. But don't think it was the same problem as you said you completely deleted your flashdisc. I did not and had old schemes. Very bad things....
Posted Sep 04, 2009 · 03:23 UTC#688
IDT,
quick question ? I'm still running 3.0 v4beta , everything was working And fine STILL is but I noticed that as soon as I add the speedcam.txt file boot time was much slower , streets on nav show up later then before . Everything is pretty much perfect but them to items . Any reason it might of got slower? I restarted the unit to see if that helped but it stayed the same .
Posted Sep 04, 2009 · 04:48 UTC#689
IDT,
the first time you add a speedcam.txt file the boot time would take longer as the text file gets converted to a spud file that the unit can read, although after that the boot up should remain the same, try deleting the save folder and see if that helps
Posted Sep 04, 2009 · 06:46 UTC#690
could you clarify?
what is this file xxx.ui page setup option "Warning"?
Posted Sep 04, 2009 · 06:57 UTC#691
could you clarify?
setting_800_480.ui
Posted Sep 04, 2009 · 09:34 UTC#692
Hey IDT,
sorry to bother you with this, but you seem to be the man to ask a question like this:
Is it possible to get rid of the caller ID Pop up while on a call? We do not have voice dial here in Europe and no matter how you start a call (dial from contacts, dialpad or phone) you get the pop up which blocks the whole unit and all keys.
In my opinion this is one of the most annoying things in the software, as if you are on a longer call, you have no chance to monitor traffic messages, enter a new destination if told so on the phone and so on.
I appreciate some people might like to see the caller ID so the most useful thing would be to have it go away after the call was accepted.
Thanks for your opinion if this is possible
Jörg
Posted Sep 04, 2009 · 16:22 UTC#693
@ill.die.trying
In this folder, i find daycar.bmp, nightcar.bmp, but no daycar.bmp1 and nightcar.bpm1
where is my error?
thank
I try the V4 beta today
Posted Sep 04, 2009 · 16:30 UTC#694
@ill.die.trying
where is my error?
thank
its daycar1.bmp not daycar.bmp1 , that was an error on my part
Posted Sep 04, 2009 · 16:41 UTC#695
thought about that as well, just looks nicer imo
I think you have just to change this setting in sys.txt but haven't tried yet.
[3d]
show_guidance_arrows=1
show_guidance_strip=0
Jörg
tested it and works you can do the same in the 2D section of SYS.txt
Jörg
show_guidance_arrows=1 ;setting it to 0 will turn off the grayish arro
show_guidance_strip=0 ;setting it to 1 will use the guidance strip
Using this image is the guidance strip the dark orange line and the guidance arrow the light yellow arrow? I am confused by the above when it says "grayish arrow".
Posted Sep 04, 2009 · 16:44 UTC#696
[3d]
Jörg
Jörg
the guidance strip is the light yellow arrow, the guidance arrow is not in the picture
Posted Sep 04, 2009 · 17:04 UTC#697
thanks for the donation
Posted Sep 04, 2009 · 19:29 UTC#698
yes
Isn;t guidance arrow the old-style arrow that jiggles around at the turn location?
Posted Sep 04, 2009 · 19:33 UTC#699
yes
yes, and the guidance strip is the one on the picture
Posted Sep 04, 2009 · 23:55 UTC#700
IDT,
once agian IDT thanks again , I deleted everything in the save folder and everything is back to normal . Thanks again for your hard work in always fixing our issues
Page 28 of 65
