IDT skin#1 v5.5 03/02/10 9download link to be updated)
By ill.die.trying · Aug 05, 2009in Completed Mods/Themes💬 1,618 posts👁️ 210,687 views
Page 30 of 65
Posted Sep 07, 2009 · 16:37 UTC#726
What are the green bullets that show up on the map? So far I have only seen them on the Interstate, but I just put in the v3 update and this mod. I'm not sure if they are part of the mod, or if they are part of 3.0. They are just round green filled in circles that show up at various points on the road while driving. When I reach one, it sometimes moves further up the road. It's not always there however.
i'm assuming you have MSN function as AFAIK those are traffic indicators,
Is there any documentation on what all the indicators are, and what special hidden functions are available? For instance, to say that if you touch the clock, it may open another screen, or when you touch the street name, the house numbers pop up. I have found some of them, but just wondering if there is any document that lists all the available features.
i'll create one and include it on the next update
Posted Sep 07, 2009 · 16:54 UTC#727
Hi IDT,,
Thank you for quick response,,
Tried to change coordinate system settings to all different modes and passed a speedcam nearby,, same effect,, at the moment the system is going to announce, reboot,,
Posted Sep 07, 2009 · 17:02 UTC#728
Hi IDT,,
did you change the the device type on the sys.txt to reflect the device type for F500?
Posted Sep 07, 2009 · 17:07 UTC#729
Yes,, its on 749UC,
Posted Sep 07, 2009 · 17:12 UTC#730
Yes,, its on 749UC,
couple more questions,
1)did you delete the save folder beofre running it?
2)have you tried reinstalling the zip?
Posted Sep 07, 2009 · 17:14 UTC#731
Will do both again tomorrow and reply to you asap,,
Thank you,,
Posted Sep 07, 2009 · 17:15 UTC#732
Thank you,,
let me know how it goes
Posted Sep 07, 2009 · 22:30 UTC#733
Hey IDT
been messing around with image files lately but i added the signpost script from your navigate 800 480.ui and it was successful, but what does this do?
;LANE INFO
Posted Sep 07, 2009 · 22:33 UTC#734
Hey IDT
;LANE INFO
if you check out the picture on p40 you'll see some red and blue arrows on the right of the gps arrow, what it is is a simple version of the signpost
Posted Sep 07, 2009 · 23:17 UTC#735
Hello IDT,
Just got back from a long cross country and your mod worked great. Still waiting for the upgrade to integrate the MSN into it as well.
A couple of things that I discovered along the way.
1. eldeep was having the same problem I was having with the reboots at red light cameras. I found out that if I turned off the voice spoken warning the reboots stopped. I am not enough of a programmer to ascertain if it is bad audio or a call to a file, but the navi keeps working fine. The beep warnings do not affect it whatsoever although that mode always defaults to disabled when I am start up the car.
2. The position of the car or arrow is a result of the new upgrades from Pioneer. After suffering through all the problems with reboots, I reinstalled the upgrade with no mods to check out stability and the arrow position. It is the same whether I use your mod, no mod, or someone elses. Just thought I would pass that along to save you some time in fixing perhaps an imaginary bug. If it were possible to reposition the arrow or the car that would be great but not sure if the benefit is worth the work.
Regards,
M
Posted Sep 07, 2009 · 23:35 UTC#736
Hey IDT
;LANE INFO
so do i need to add any bitmaps or anything else as well as the code in the navigate 800 480.ui?
I guess that is what the lane info/ guidance is?
Posted Sep 08, 2009 · 00:12 UTC#737
is there any reason why i don't see speed cams on my unit? I went and turned them on in the warning section.
Posted Sep 08, 2009 · 00:31 UTC#738
do you have the speedcam.txt?
Posted Sep 08, 2009 · 00:33 UTC#739
Hey IDT
;LANE INFO
:evil:
you could just use the stock one, it's already referenced in the navigatemap.ui so no need to add anything else unless you want it to look like the ones on the picture
Posted Sep 08, 2009 · 00:58 UTC#740
:evil:
I dont know what they look like, do they only come up when in route? I will test and see.
Posted Sep 08, 2009 · 01:36 UTC#741
Haha, wow I'm stupid lol. Could you please lead me to the latest file?
Posted Sep 08, 2009 · 01:47 UTC#742
What are the green bullets that show up on the map? So far I have only seen them on the Interstate, but I just put in the v3 update and this mod. I'm not sure if they are part of the mod, or if they are part of 3.0. They are just round green filled in circles that show up at various points on the road while driving. When I reach one, it sometimes moves further up the road. It's not always there however. " end quote
With the msn activated, these dots tell you how the traffic is flowing. Green means ok. A yellow dot with a number in it will let you know the traffic is slowed and at what average speed it's moving. A red dots tell you the traffic is stopped. If you have turned on the feature to use this information, the nav sys will reroute you if the alternates appear to be a better route.
Posted Sep 08, 2009 · 09:29 UTC#743
Thanks IDT for your great mods, especially for euro versions, which surely cause you lot of extra work! I will soon send you some cash for all your hard work. Your mod is nearly perfect, there's only two things I'm missing from your mods (I can propably add these by myself too): house numbers and different type of arrow showing route when navigating.
http://avic411.com/forum/viewtopic.php? ... 9&start=30
House number view in this mod is really useful, so maybe you will add similar function to your mod, too? Also, I tried this mod on my AVIC and although route arrow in screenshots of that thread is similar with route arrow in your mod, route arrow looked like this in my AVIC:
So I'm wondering how to change route arrow to look like that?
That example picture I posted is not from my avic, just example to show what type of route arrow I had with Sven's mod.
the house numbers are included in the data.zip, pressing the current street will show the housenumbers and pressing the housenumbers will hide it
Hmm...I tested this yesterday and house numbers show in wrong sides of street (I'm using your mod V3.5 europe), is this bug in mod or are house numbers included in map, so this were error in map itself?
Also I have two other strange issues:
1. I'm living in Finland which is bilingual country (we have finnish and swedish as official languages). Somehow f.ex. most of streets near my home show in swedish, which is "secondary" language in Finland, although all regional settings are set to finnish/Finland. I installed same map that I have in my windows mobile-based phone (it has iGo 8.3 too), but problem still remains with Avic but iGo in my phone shows all street names in finnish. I'll have propably try to reset save-folder once if this might fix this problem.
2. When I installed unmodded version of Pioneer 3.0 update, it shows me one lane sign near my home (its on smaller street, not on highway), after installing your mod this sign doesn't show anymore. I've tried with two different map versions and this lane sign doesn't show but I haven't tested in highway yet, so I dont know if problem is only with this sign or are all signs missing. AFAIK signs should work by default with your mod, no need to enable them separately?
Posted Sep 08, 2009 · 17:16 UTC#744
IDT,
Awesome job! I just updated to v3.5 and I'm loving it. You sir are a master at what you do. I can't wait to see the new changes. Keep them coming!!
respectfully,
my_black_RS5
Posted Sep 08, 2009 · 17:30 UTC#745
Thanks IDT.
Seems like you solved one of my pet peeves, to go to blank screen from the main screen GREAT!
Now that your the man is it possible to put on the main screen a BT button instead of pushing the volume knob on the unit,( I always seem to change channels on the radio when I press that knob very distracting) also remove the nag screen before the map and the dvd player.
Keep up the exellent work.
Posted Sep 08, 2009 · 23:55 UTC#746
i will post EU and MSN version as soon as someone has confirmed that the signpost and camera are all working as they should
has this happened yet?
...no MSN version posted, so I havent tried the 3.0v4 BETA yet.... need IDT 3.0v4 MSN.zip .... :roll:
k
Posted Sep 09, 2009 · 00:04 UTC#747
k
almost done bro, i had some last minute additions, some more tweaking and it'll be ready, might be tonight or tomorrow afternoon
Posted Sep 09, 2009 · 00:08 UTC#748
the the map is responsible for the house numbers, what i currently do with my EU release is i just switch the textmodels,
1) try deleting the contents of the saved folder and let me know if it works
2)the lane guidance is being covered by the signpost, everything is fixed on v4, next release will be up soon,
Posted Sep 09, 2009 · 01:04 UTC#749
SO VERSION 4 HAS STREET NUMBERS? How do i access them?
Posted Sep 09, 2009 · 01:07 UTC#750
by pressing the current street
Page 30 of 65
