IDT skin#1 v5.5 03/02/10 9download link to be updated)
By ill.die.trying · Aug 05, 2009in Completed Mods/Themes💬 1,618 posts👁️ 210,687 views
Page 43 of 65
Posted Sep 20, 2009 · 20:22 UTC#1051
Hi IDT,,
PS: how can I make the speed and speedlimit on the screen bigger with and without route,, use my gps also on mi motorcycle and the text is really small,,
thanks for the info,
Thanks,,
you have to edit the BMP's for it and change a couple the x and y values plus change the fontsize
Posted Sep 20, 2009 · 20:36 UTC#1052
How do you switch between 2D and 3D map settings with this theme? Forgive me if this is obvious but I couldn't change it like in 2.0 using the factory screen icon
Posted Sep 20, 2009 · 21:06 UTC#1053
by clicking the kinda map looking icon
Posted Sep 21, 2009 · 22:04 UTC#1054
Hey there, this is an awesome NAV scheme. The buildings in the screenies on Page 53, are they in the install files or are they in a seperate download? Also, I live in Canada, Will the building files and POI be good there?
Posted Sep 21, 2009 · 22:52 UTC#1055
i also live in canada
you have to download building files for the buildings to show up,
Posted Sep 21, 2009 · 23:07 UTC#1056
That is what I thought. Where do you get these? I tried one site for the new '09 maps for the 3.0 version, but they were only for the US :(
Posted Sep 21, 2009 · 23:12 UTC#1057
i'll post the one i have when i get home, don't keep your hopes up though as there's not too much in canada, and here in winnipeg there's none
Posted Sep 21, 2009 · 23:36 UTC#1058
Thats awesome, Thanks! I am looking forward to it. I do some travelling in Toronto, where I HAVE to use my GPS. I am sure that the files will be good there
Posted Sep 22, 2009 · 01:45 UTC#1059
Hi IDT..
All I can say is You have done excellent job. It makes a huge difference to the factory options.
I have few more questions:
1. Jpeg File viewer from SD Or USB drive?
2. Adding codecs to be able to play Xvid files? Or say can we add VLC media player to make it play any type of Video fiels?
3. How can I save my existing destination as Favorite? Say I am parked at Niagara Falls NY. And I want to save its destination in my favorite or POI, I tried to do it different ways.. I have yet to find out how to do that. ( I am so used to use Garmin Nuvi.. I carry it with me..as I can not add a location where I am parked at.)
EDIT: Oh yea. I have updated my F900bt to latest 3.010100 and maps to 2.00400 but when I go to WinCE>ControlPanel>System it shows I still have CE ver 5.0 and not 6.xx.xxx or something like that.. when I was upgrading to 3.010100 it showed that upgrade will include CE ver 6+ but then why system still shows older?
Really appreciate. Thank you so very much.
:D
Posted Sep 22, 2009 · 16:20 UTC#1060
Can anyone post pics of the various schemes included in this package? I would like to see what they look like before installing a scheme. Thanks in advance!
Posted Sep 22, 2009 · 16:38 UTC#1061
I am being prompted for a login name and password to ftp://buckeyecollision.us/illdietrying/IDT%203.0/ . Searched this thread and found others had this issue early on, but fail to see a login name/password or resolution?
Posted Sep 22, 2009 · 16:43 UTC#1062
If you use the link directly on p53, then you will be directed to the ftp site already logged in. If you try to get to it any other way, then it will ask you for a password and username when trying to download anything. So yes, you have to go ALL the way back to p53, and use the link there
Posted Sep 22, 2009 · 16:58 UTC#1063
I pulled that link from page 53 after clicking it :) I noticed when going in for the first attempt (before the prompt) it puts out "The webpage at ftp://avic:[email protected] ... IDT%203.0/ might be temporarily down or it may have moved permanently to a new web address." Error. Afterwards I tried the link I posted before, without the login creditintials in the link pasted above, and manually typed them in to no avail. login : avic and pw : avic-411 per the links suggestion... can you still get in?
Posted Sep 22, 2009 · 17:22 UTC#1065
And you can then browse to "illdietrying" directory and the "3.0" directory? I cant get into "3.0"without it asking for a password again. I can access the root and the "illdietrying" portion and download the older 4.2 with no problem, but was looking for 3.0 firmware 4.3 download :(
ftp://avic:[email protected]/
I have just used the address above and got straight in.
Posted Sep 22, 2009 · 17:29 UTC#1066
Yes,no problems.
Posted Sep 22, 2009 · 20:14 UTC#1067
How do I remove the shortcut icons on the main map page...the ones that dim at the top of my screen...home,route,prefs,etc...This is a great theme bro! Thanks for your hard work in making our devices more enjoyable.
Posted Sep 22, 2009 · 20:32 UTC#1068
the next update has a setting for it to be turned on/off and a selection on how dim you want it to be.
Posted Sep 22, 2009 · 20:56 UTC#1069
IDT:
First of all, thaks for dedicating so much time and efford to this mod. Overall it is a great aplication and I'm enyoing playing with it.
However, and please don't take this as a complaint there are some things that don't work for me.
1) I seem to have the same problem as many people with the seedcam reboots. Here in Madrid (Spain) there are so many that the sistem is rebooting most of of the time. I've turn off the voice warnings and the problem seems to stop so I guess it has something to do with that.
2) The default tilt and zoom makes it absolutly imposible to navegate. I have to say that it looks great but it isn't at all practical specially when you don't have a route plugged in. I've been playing arround with the "d_max_tiltlevel"
and "3d_max_zoomlevel" but can't seem to find the ones i want (between yours and the factory default) and it's really a pain to have to do it by modifing the Sys.txt file. Could it be posible to add a section in the 3D settings to modify this default and max values?. I've seen it done on other mods.
3) This is probably my fault but i can't access this
file.php?id=8109&mode=view
or this
file.php?id=8108&mode=view
I'm using the EU version of the mod. Can you please tell how to access them?
Thanks for your attention and count with my donation very soon.
Posted Sep 22, 2009 · 21:40 UTC#1070
IDT:
i have fixed this and tested it and have a couple of testers checking if it indeed is working properly, hopefully i'll have a feedback soon but as far as i have used it everything is working ok,
doesn't the zoom and tilt level get saved when you turn your unit off? also do you manually adjust the zoom and tilt and do you have the smart zoom turned on?
or this
you have the press and hold the time/date/compass area to get to picture 1 and to get to picture 2 you just have to press it
Posted Sep 22, 2009 · 21:58 UTC#1071
guys tell me the procedure to load the speed camera on AVIC F900BT firmware 3,000,300 with IDT by
Posted Sep 23, 2009 · 02:35 UTC#1072
Hi IDT..
:D
sorry but i don't have any answer for all of your questions, it's out of my league
Posted Sep 23, 2009 · 02:38 UTC#1073
IDT, regarding the speed camera warnings that you are looking into, I just wondered how easy would it be to add the following as an option?
Instead of a voice warning as you approach every camera and/or a beep when you are over the speed limit as you approach, I think a really good option would be just a voice warning ONLY if you are over the limit on approach.
Because we have so damn many cameras in the UK, a warning as you approach each one soon gets very irritating, so I tend to turn that off and just use the over limit beep. That alerts you OK but obviously doesn't give you a confirmation of the actual limit. A voice warning of "Speed Camera 40" etc that only occurs if you are over that speed would be absolutly perfect IMO.
I've just done a 180 mile trip and I have to say that the system is now virtually perfect. I cannot praise you enough for the work you have done turning a clunky, crappy bit of firmware into the slick product it now is.
that's a good idea, i'll have it on the next update for sure
Posted Sep 23, 2009 · 02:39 UTC#1074
you have to put the speedcamera text file to myflashdisk/apl2/igo/content/speedcam folder and turn the settings on
Posted Sep 23, 2009 · 07:33 UTC#1075
Great. This was really bothering me. You're the MAN. :D
Don't really know what you mean. I have made tests with smartzoom on and off. Changing the SYS.txt values to 9500 tilt and 750 zoom don't seem to have any effect. The view i get whet i turn on the unit is mostly the same i get with your 8800 and 1500 values. I've tried with tilt 10000 and zoom 500 and the view i get is very similar to the one i get if I erase the values completetly. Can't seem to find the values in between. When I change manually using the knob for zoom and the screen for tilt, i finally get the view i want but nor it stays after a reboot not will it be the default view with smarzoom turned on. On both ocassions it will revert back to the original settings.
Dont' know if i made any sense with this explanation. :D:D:D
I told you it was my fault. :D:D:D:D Thanks for the tip.
Page 43 of 65
