Replace the Clip_planes.ini file in your common file with this code:
[clip_planes]
; mode, lower bound, upper bound, lower value, upper Value
; mode: 0: by zoom level,
; 1: by number of cells,
; 2: by intersect value (0..45),
; 3 by camera tilt angle (0..100 from totally flat to top-downview)
; values: 0.0 .. 1.0 * 1000 (= 0..1000)
faded_buildings_near = 0, 10, 200, 600, 600
faded_buildings_medium = 0, 10, 200, 650, 650
faded_buildings_far = 0, 10, 200, 750, 750
solid_buildings_near = 0, 95, 100, 1000,980
solid_buildings_medium = 0, 95, 100, 1000,980
solid_buildings_far = 0, 95, 100, 1000,980
landmark = 0 , 1, 50, 1000, 1000
road0 = 3, 20, 70, 930, 1000
road1 = 3, 20, 70, 950, 1000
road2 = 3, 10, 75, 970, 1000
road3 = 3, 0, 100, 995, 995
roadsign = 2, 0, 40, 1000, 900
;a ket reszletesebb terrain
terrain0 = 0, 30, 30, 750, 750
terrain1 = 0, 30, 30, 850, 850
;reszletes shapek. Mivel lassu, ezert ne vigyetek tulzasba.
shape0 = 2, 1, 10, 1000, 0
and/or replace the clip planes string in each of your color.ini files in the schemes with the same or you can delete the clip_planes in the schemes altogether as the one in the common folder will take precedence. Then you will have some good street naming. Not perfect but ALOT better.
Good luck!
Bud
