What is the diff between the Simple and Full display?
No more ability to change the camera warning distance?
Thanx!
Bud
Thanx!
Bud
Youu say add the 3D cars to the IGO8 folder...where is the IGO8 folder? ![]()
Thanx,
Bud
Thank you for your great job!Have you corrected the problem of adding mobile camera speed ?
i have tried and could not get it working, i tried using cmh's and his doesn't work either so i'll just let it be,
What is the diff between the Simple and Full display?No more ability to change the camera warning distance?
Thanx!
Bud
simple is the small one you see just below the time/date area, full is the big box
i will look into it, when i was going through the speedcam.ui i noticed a lot of useless commands and stuff that's why i deleted them
Thanx,
Bud
just add the car model that you want to the gfx folder and then follow the instruction on page 78
69sixpackbee
thanks for the donation bro
Hi IDT,Great work,thanks.I seem to have a problem with the schemes which i had from dpdurst.They are still there to be selected but i get the message file not found and the nav part of the avic won't reopen.All i did was copy the new data.zip and sys.txt files over>have i missed something?Thanks again.
Did you copy the new GFX folder I have as well? Did you copy the ui_igo8\common folder out of my data.zip into the idt data.zip? If they were working before, sounds like the ui_igo8\common folder is the issue as that is where some of the spr files and such would be located.
Yes that was it.I have now copied the ui igo 8 files over and..happy days!Thanks again for your help.
Hi,did you copy all ui igo8 or just replaced the commom folder
Thank's
is this really strange problem? " But it worked well in the CMH's mod. If I could help I will gladly.
It should perhaps leave the origin files "speedcam" can resume modifies one after the other to identify the problem?
Thank's
common folder is inside the ui_igo8 folder, so copy the ui_igo8 folder with the common folder. They go together.
I have a problem: I moved the buttons "Simulation Control Mod"
;Simulation Control Mod
but when I made a simulation, the buttons are invisible except the "stop button".
How to solve this problem?
I just did this mod, upgrade from the previous mod, the icons along the top haven't changed, no favourite button, although the new mods are there, the option for fading the icons and text colour change.
I'd like the fav icon displayed but i don't want to loose the TMC icon, would it be possible to change the screen off icon for the fav icon, thereby still keep the TMC ?
Thanks IDT, paypal coming to you soon.
Paul.
Is there anyway to display the Current Speed in KM/h
It is showing in MPh.
Thank you
Thank you
did you chang the unit settings?
I just did this mod, upgrade from the previous mod, the icons along the top haven't changed, no favourite button, although the new mods are there, the option for fading the icons and text colour change.I'd like the fav icon displayed but i don't want to loose the TMC icon, would it be possible to change the screen off icon for the fav icon, thereby still keep the TMC ?
Paul.
i'll think of a setting for those buttons on the next update
Paul.
I also like the Favourites. I would be happy to loose either the day/night or the Screen off icon to have it.
>IDT, I was trying to see if I could do this myself without bothering you yet again. I had a look at ui_pioneer\800_480\ui\navigatemap_800_480.ui and could see that the line for the favourites icon exist but is commented out. So I tried commenting out the day/night icon lines and activating the favourites line and change the location to be the same as the day/night. Sadly I get a FFUI ERR box pop up about unknown object identifier in script "sc_Navi_MenuAlphaRestore" command 5, so I guess it is more complicated than that (seemed to good to be true!). It did actually all work OK after ticking OK on the error box, but I get the same error everytime I startup.
Hi IDT.Wonder if you can help me here.Installed latest update(4.9 eu) and realised no speed cameras showing on map.In the speedcam folder showed 2 folders but zero bites.Checked this against mt v2 flashdisc back up which showed 2 files 1.2 mb.So i copied these 2 files into my v3 folder.After a very long start up,the speed cameras showed on the map so i thought i had sorted it.Not so.When i searched for poi's the nav rebooted.Again a very long wait time and no start up image.Anyway,i have deleted the 2 v2 files from the speedcam folder(in apl2/igo/contents) and all seems ok again.That still leaves me with no speed cams again.Thanks for all your support.
Paul.
checj your navigatemap.ui and comment out the btnNMB_changescheme , and then uncomment btnNMB_favourites_onmap and chane its x value to the x values of the day/night scheme
i think the speedcam file you have is too big. try downloading it from here and load it to your unit http://speedcamerapoi.com/download.php, let me know how it goes
i used CMH's 3.0 and it's not working so how come your saying that it's working well? if you could make it work then let me know, but if not then just let it go as I DON'T HAVE ANY PLANS ON MODIFYING IT
Thanks for that IDT.Do i just copy the txt file straight into apl2/igo/content/speedcam?Is that it?Nothing else to go with it?I have never really got to grips with the speedcam files as you can see ![]()
Problem or not ?
I do not know if it's a real problem, but the EU version when I made a navigation with destination and I click on the window of speed, window-board computer does not open properly. Only the button "out" and "pause" to appear.
Another thing, when there is a radar warning and I click on the large window, the little icon opens but I can not revert to standard mode? Finally, when I made a long and supports the standard windows warning radar, the mute function is not activated?
Again, great mod and an excellent update. It really brings functionality to the unit.
I wouldn't presume to ask for custom changes but I do have a function issue. Sine I originally installed your 3.0 beta and each following update (including today) my elevation reads 0.2 mi. On the GPS signal statues screen I get actual elevation (1108 ft.) but on map, nav, trip screens it always 0.2 mi. Any thoughts?
And one generic question, can I install 3.01 from Pioneer over your mods? Will I be able to at all? Will it delete your mods? If so can I just re-instal your newest version?
Thanks again for your help and improving AVIC's everywhere.
Vic
you just have to copy the the file and put it inside the speedcam folder
Nobody's figured out the elevation thing. I just modified the existing string in the Navmap/800_480.ui file in place of the sign and it works with the custom settings:
;ELEVATION ; ;
..Bud
Problem or not ?I do not know if it's a real problem, but the EU version when I made a navigation with destination and I click on the window of speed, window-board computer does not open properly. Only the button "out" and "pause" to appear.
the current speed is not designed to show up when you have a route so i don't know how you made it,
for the speed camera warning box functionality, i will still to work on the displaying back and reverting of the sounds,
