IDT skin#1 v5.5 03/02/10 9download link to be updated)
By ill.die.trying · Aug 05, 2009in Completed Mods/Themes💬 1,618 posts👁️ 210,687 views
Page 6 of 65
Posted Aug 09, 2009 · 09:49 UTC#126
hey idt i cant set my return to home. i get all the way til i am supoesed to hit ok at the bottom right but no ok button.
Yes I had the same problem
But I used set home by map location (I think) and that way worked
i'll check it out
Posted Aug 09, 2009 · 15:41 UTC#127
Nice mod, how do you delete added pin?
Posted Aug 09, 2009 · 16:28 UTC#128
Click the pin in in 2d map mode and then delete it the same way you added it.
Posted Aug 09, 2009 · 17:18 UTC#129
does anyone know if the Multi-Route feature is the same as the Multi-plan from Yuri's mod?
Posted Aug 09, 2009 · 18:13 UTC#130
it's the same
Posted Aug 09, 2009 · 22:37 UTC#131
has anyone had a problem with their ipod making noise from the speakers while changing tracks? This only happens when I change songs manually. Im not sure if its the hack or not. Im using version 1 that idt put out. I turned the volume down on the buttoms when using the knob so it doesnt make that annoying beep. Any help appreciated. This never happened with my 2.0 update.
Posted Aug 09, 2009 · 23:51 UTC#132
this not not by anyway related to my mod
Posted Aug 10, 2009 · 00:55 UTC#133
IDT great work as usual I was wondering how to make the Blue info button in the top photo go to the screen in the bottom photo?
Posted Aug 10, 2009 · 01:24 UTC#134
where do you want it to be placed?
Posted Aug 10, 2009 · 01:35 UTC#135
I'm sorry I would like the short cut link to go to the bottom screen instead of going to poi info.
Posted Aug 10, 2009 · 03:32 UTC#136
could you edit the picture you posted to show where and what you want to do, sorry my brain's not working to day as i haven't had much sleep the last few weeks
Posted Aug 10, 2009 · 03:42 UTC#137
I Installed the version 3.0 update and that made a big difference. I installed your MOD today and wanted to says Thanks IDT, you helped make my $1200 deck worth $1200 again. You added features that the dipshits at Pioneer should have added when they released the deck to the public. As soon as my Replacement knob arrives i will be content in using this deck.
There is one question or suggestion i have:
When there is an incoming call from a number that is not in the contacts list it always displays as one long number with area code and no spacing. While driving i find this extremely difficult to decipher who is calling by looking at the 10 digit number.
Is there a way to modify so it doesnt show area code and also add spaces and a dash? (123) 555 - 1234
Even if you know which file this setting is in i can try and mod this myself :D
Its always been the main glitch that has annoyed me from day one along with how small the Answer and Hangup buttons are when there is an entire 7 inch screen they make them so small that when a call comes in its a hectic event to try and figure out whos number it is then press the tiny answer button.
Posted Aug 10, 2009 · 03:50 UTC#138
no problem,
regarding your question/suggestion, calls are handled by other software in our units, so far no one has hacked that part of the unit so you have to live with it for now
Posted Aug 10, 2009 · 03:53 UTC#139
Hi IDT, thanks for the multi-plan mod...been looking forward to that!
In your future data.zip's can you add the curso file to the common/night folder (unless u dont add it for some reason)? Just makes things easier..i forgot to add it, then tried loading some of the themes and realized it was missing again.
thanks a bunch
Posted Aug 10, 2009 · 04:02 UTC#140
thanks a bunch
no prob,
also what cursor file were you reffering to
Posted Aug 10, 2009 · 04:35 UTC#141
I would like the blue info button in the top left corner to take me to the menu that the original curser led to.
Posted Aug 10, 2009 · 06:35 UTC#142
thanks a bunch
Hi IDT, im attaching the cursor file that eliminated the theme error. Added it to the common/night folder and all is working perfectly
cursor_places.zip
Posted Aug 10, 2009 · 13:45 UTC#143
The reason I am asking is when you select the blue information button it brings up a list of POI’s around the cursor. When you select POI it goes straight to the poi information screen and never gives the option to call the POI like the POI search does. Basically there is no option to call POI.
Posted Aug 10, 2009 · 13:57 UTC#144
i'll take care of it
Posted Aug 10, 2009 · 14:17 UTC#145
Thank you very much just sent you something for all the hard work you do making this unit worth using.
Posted Aug 10, 2009 · 14:38 UTC#146
Great work IDT, I can't wait to dive in and look at all the work you done. Looks Great.
Posted Aug 10, 2009 · 15:07 UTC#147
thanks bro
Posted Aug 10, 2009 · 15:09 UTC#148
IDT,
Dont worry about the MSN Traffic thing I was mentioning. It was working with the Pioneer scheme's, so my guess is that its just something wrong with the other schemes, not having support for road color shading maybe (other than when in route)? I would say its not an issue at all with your mod.
thanks for the donation bro
Posted Aug 10, 2009 · 15:13 UTC#149
IDT,
you're welcome, least i could do!
Posted Aug 10, 2009 · 16:16 UTC#150
thanks bro
Page 6 of 65
