Diaftia's Hybrid mods V1 - UPDATED: 12/1/09 FINAL
By diaftia · Aug 12, 2009in Completed Mods/Themes💬 950 posts👁️ 132,666 views
Page 15 of 38
Posted Sep 26, 2009 · 13:22 UTC#351
I played with it last night on a 20 mile trip. Overall I really liked it. I think for my taste I need to change the zoom tilt level a bit.
I did get a reboot once. I was switching screens, I went to hit the menu button, but hit map by mistake, I then hit menu, maybe a second later and it rebooted. When it came up, it still had my route active, and all was well.
Also the trip computer only showed zeros the whole time, but I have been reading all the posts about that issue.
FWIW, I DO have the VSS wire hooked up, and I know it works because I live in Pittsburgh (THANK GOD the G20 is over...) and we have plenty of tunnels. Without VSS, when entering a tunnel in rush hour, the AVIC would assume I am going highway speeds, and it would show me a good ½ mile ahead by the time I exit the tunnel. With the VSS hooked up, it was very close, and if traffic stopped, the AVIC would show me stopped. I wish it used VSS better, but it seems to only use it when there is no GPS signal, it will not override it when you are stopped, it will still show .03MPH...
Posted Sep 26, 2009 · 15:43 UTC#352
Those of you getting reboots I have 3 questions:
1. Are spoken speedcams enabled?
2. Are you using the default scheme?
3. Are your units set to mph or kmh?
Posted Sep 26, 2009 · 15:48 UTC#353
Those of you getting reboots I have 2 questions:
PM sent
Posted Sep 26, 2009 · 16:37 UTC#354
Hey Diaftia, I installed your latest update. You said you removed the commonlib.dll and I assume this is the one Carver made. I haven't seen a warning message at all, strange? I'm not complaining just a little confused.
William
Posted Sep 26, 2009 · 16:47 UTC#355
William
unless you copy back the original one from your backup you won't see the message still. I just stopped distributing the modded one.
Posted Sep 26, 2009 · 16:52 UTC#356
Ah, got ya. Thanks for your response.
William
Posted Sep 26, 2009 · 18:29 UTC#357
1. I have no idea, I did not intentionally enable it.
2. I assume so, I did not knowingly change any scheme.
3. MPH.
I took it for another 10 min ride, and trip computer worked fine, other than altitude being in miles, not feet. I know I read about that, back to the search function!
Posted Sep 26, 2009 · 18:32 UTC#358
3. MPH.
I am not sure there is a fix for that. If you find one let me know. Its been a while since I've looked at it. I am at sea level and have not taken my car over 5280 feet. I have one other thing I can do by specifically calling out the unit measurement but I don't know if that will make a difference.
Posted Sep 26, 2009 · 18:47 UTC#359
I Live in Pittsburgh, so pretty much I am between 800 and 1200 feet, so seeing 0.2 miles is kinda a letdown going from 4 significant digits, to 1! Most trips will not go over 2500 feet for me.
Also, I think I want to tweak your mod. I would like to
1) remove the GPS indicators
2) add a beep for hitting the compass to switch map modes. (I TRY to to it without looking at the screen while driving, and a beep would help.)
Also, also, as for the 3d buildings, is there still a problem? They worked for me on 3.01 before the mod, but I have not driven near any since. I can do a simulation to check if needed.
Posted Sep 26, 2009 · 19:15 UTC#360
1. Wait for my next set of mods. You will be able enable and disable all the stuff on the map screen (gps icon, speed sign, elevation, signposts, etc) with settings.
2. I have been meaning to add that. I will do it.
3. 3D buildings I was under the impression did not work. Sounds like it might be though. I will look into it.
Thanks,
Alex
Posted Sep 26, 2009 · 19:42 UTC#361
We have not figured out a good text model to display elevation in feet in the trip comp. Diaftia has the correct code for the elevation bmp on screen. If you wanted you change the textmodel in speedometer 800 480 ini to gps.elevation to show in feet. Bear in mind though gps.elevation will show feet up to 5280 feet then you'd get 1 mile XXX feet.
Posted Sep 26, 2009 · 19:58 UTC#362
I actually tried that in there during my development. It just looked odd though with the FT next to it. I suppose you could change the posted speed next to it to show the units for consistency but overall I was not a huge fan of how it looked.
Posted Sep 26, 2009 · 20:00 UTC#363
Thanks for all the great mods & help! I put in a X-910BT & put these mods on & I love them!(All the X-Series mods seemed to point me in your direction, even though your post is in the F-Series) However, sometimes out of no where, it'll reset, screen freezes, or the music from the SD will not play. I noticed you just updated this a couple days ago & cleared out a file that helps with this...Would you just suggest me to reload your file? Also, it seems that it takes awfully long to load...Anyway around this? Thanks Again!
Posted Sep 26, 2009 · 21:52 UTC#364
In my dev build I have all three of these things done. Here is a screen shot of the 3D buildings with the sky worked out:
Just working on some things with IDT around speedcams. Well, really he is working on them... I am just an integrator. ;)
Posted Sep 26, 2009 · 21:55 UTC#365
Hmmm regarding the resets that could be because of the speedcam issue I am working with IDT on. Hopefully should have that fixed this weekend.
Not too sure about the SD thing. Weren't there some SD and music issues with 3.0 in general?
What is the file you are talking about and does it help the SD issue above? If it doesnt impact the F series users I would have no problem adding it in. I am just not aware of what file it is. Let me know.
Regarding booting... Not too sure on what to do about this. I cant say it takes any longer on my unit than the original build did. How long are we talking? I have a feeling this might be because of your hardware difference?
Posted Sep 27, 2009 · 02:09 UTC#366
Small issue. The "Extras" icon should say "Extras" not "Extra's" - It's plural, not possessive. :) Sorry...grammar nazi. :lol:
Regarding the post above - I'm using this on an x910bt as well, but don't use SD for audio...I use an iPod, XM, and HD Radio without any issues...MSN as well. Maybe it's an SD issue?
Posted Sep 27, 2009 · 02:12 UTC#367
ah damn your right... According to this there is some person name Extra that owns that section. ;)
Posted Sep 27, 2009 · 06:12 UTC#368
You're. :lol:
Thanks again for all of your work. :)
Posted Sep 27, 2009 · 06:28 UTC#369
You're. :lol:
LOL!!!! Wow! I laugh because usually I am the one catching people doing that. Pet peeve to have people not use your, you're; two, too, to; there, their, they're; etc. correctly. Well at least I always notice it. Apparently, I am getting increasingly more dumb as I get older. ;) I look back at what I typed above and I even left the "d" off named. I'll chock that up to a typo. Nah, I am mildly retarded. :P I need more sleep. Speaking of, I am going to try to work on only that for the rest of the night. :)
Posted Sep 27, 2009 · 13:43 UTC#370
Very cool, thanks!
As for the 3d buildings. I have good news.
Posted Sep 27, 2009 · 14:51 UTC#371
Very cool, thanks!
Yep! Check out my post with the Transamerica Pyramid above. :)
Posted Sep 27, 2009 · 16:39 UTC#372
Very cool, thanks!
Posted Sep 27, 2009 · 17:27 UTC#373
Where are the rest of the buildings? Are you guys using both 3dl and 3dc files? Here's a pic of mine with both 3dl and 3dc files. There are are no landmarks (3dl) in my pic though, they're all pulled from the 3dc file.signpost  sim test.jpg
I don't seem to have 3dc files (at least in my emulator or 3.0 backup). What directory do they go into?
Posted Sep 27, 2009 · 17:43 UTC#374
I just wanted to show they show up on the current version. I was under the impression you were trying to fix/enable them.
Posted Sep 27, 2009 · 17:45 UTC#375
I got another reboot, I was on the iPod screen, and clicked the map button. So of my 2 reboots both were while pressing the map or menu buttons. :?
Page 15 of 38
