Diaftia's Hybrid mods V1 - UPDATED: 12/1/09 FINAL
By diaftia · Aug 12, 2009in Completed Mods/Themes💬 950 posts👁️ 132,666 views
Page 17 of 38
Posted Sep 28, 2009 · 19:05 UTC#401
@ Diaftia, yeah I have a complete back up before modding the unit
Posted Sep 28, 2009 · 20:03 UTC#402
Excellent. Go into that backup into the APL2/iGo directory and open the original sys.txt file. Look at the following line in that file:
[device]
type="PIONEERXXXX"
(yours will not be XXXX but a specific number)
Copy it to your clipboard on your computer (ctrl+c or edit>copy). Open the new sys.txt file that came with my mods and replace the line in that sys.txt file with the clipboard contents (highlight the txt to be removed and click ctrl+v or edit>paste) to make it the same thing.
Take the file and put it to your SD card and go into testmode and copy it over to the AVIC.
Should fix it.
Alex
Posted Sep 28, 2009 · 20:45 UTC#403
Ever since I went to 3.0 and Keeper's 9-24-09 my unit reboots every 60 sec for about 5 reboots. It will finally stick and work ok. If I start it using the Eject,Menu and reset it will work every time!! What is the difference in the normal reboot and the reset,eject and menu boot.
Posted Sep 28, 2009 · 20:48 UTC#404
Alright thank you very much, Ill try to do it again after i get off school
Posted Sep 29, 2009 · 00:11 UTC#405
Ok. I think I screw up my unit. I am not panic or anything just frustrated. I just reflash mine back again with Official 3.0 update from Pioneer and my unit is now rebooting every other min or so. I didn't put any mods at all and still rebooting by itself. Please let me know if there's anything I can do.
Posted Sep 29, 2009 · 01:37 UTC#406
Try downgrading to 2.0 and flashing to 3.0. There is a thread in the general forum on it. Just do a search. It will be fine.
Posted Sep 29, 2009 · 02:22 UTC#407
@ Diaftia, hey I tried changing the thing in the .sys file but i still get the same error : FFUIERROR: Parse error [ expected] :(
Posted Sep 29, 2009 · 03:04 UTC#408
and if it means anything, Im running 2.006000
Posted Sep 29, 2009 · 03:20 UTC#409
I am getting the reboot problems again. it seems the rebooting is associated with activating spoken warning. rebooting disappeared when i disabled spoken warning and then it started rebooting again when i enabled it!
Posted Sep 29, 2009 · 14:01 UTC#410
I have same rebooting problem but mine was randomly. I experienced freeze if song name is more than 40 character or foregin character. I will try without SD Memory today see if there is any rebooting problem.
I will post it later for result.
Posted Sep 29, 2009 · 14:41 UTC#411
This happened to me when I commented out a few things in the navigatemap_800_480.ui file and forgot to comment out one line in the code. Have you made any modifications yourself?
Posted Sep 29, 2009 · 14:43 UTC#412
MIne rebooted today, iPod was not connected, I was listening to the HD receiver in analog mode. Maybe 2min after boot up, it rebooted. No recent button presses. It was probably recalculating a route at the time, and I ahve Samantha as the active voice now.
Posted Sep 29, 2009 · 18:29 UTC#413
Hey Guys-
I was working on some changes but what I might do is just take the existing set of mods and make it so that there will be no reboots. Its caused by the audio files for the spoken warning. IDT found that there must be some corruption in the files themselves. I will get a new one up in a few minutes.
Alex
Posted Sep 29, 2009 · 19:30 UTC#414
Links updated in the first post. Rebooting problem should be fixed now.
Posted Sep 29, 2009 · 20:50 UTC#415
Alex,
I think now that the quick menu is an over lay there is nothing to stop you from adding it to other menu's such as the speedo. I was thinking of adding a button like this to the bottom of the speedo screen.
Posted Sep 29, 2009 · 21:09 UTC#416
Alex,
Yeah that is a good point that it can be launched from anywhere. I guess the other theory is that you could just hit back and launch it from the main screen but convenience is always a key.
I have had strange reports of the menu not going away when the new menu layer is up and someone hits the hard map button. Then nothing can be gotten to. Even if you hit the hard menu button and then the map button the menu comes back up. Odd. I have yet to try this myself but was thinking that a timeout value to hide might help it.
Posted Sep 30, 2009 · 01:07 UTC#417
I have not made any modifications at all besides the few you have instructed me to do so.. and I followed the instructions step by step.. so according to what you said, am i supposed to find that file and add something? Im not that great with html/java/linux but can follow specific directions.. thanks for the help youve given me this far though.. i just want to have these mods because they make the device so much better.. the f500 doesnt come with anything.. even my portable garmin device tells me my current speed..
Posted Sep 30, 2009 · 18:51 UTC#418
All I can think is that there might have been some corruption when you downloaded. I have only seen that error when making changes to the data.zip's ui files. Leave out a syntax comma(or other misc bad formatting), add a ui to a state when it doesn't exist, etc. Its a vague error but always revolves around a coding issue.
Maybe someone else that has a BT500 can comment on here to verify that my mods work on that unit?
Posted Oct 01, 2009 · 09:26 UTC#419
HI
i`m new and the skin is great.
but i`ve got a question.
how can i save my coursor position and save this in poi?
thank`s
Posted Oct 02, 2009 · 19:11 UTC#420
HI
thank`s
Go to the quickmenu then to the POI icon and its the last option. I think that is what you are looking for.
Posted Oct 03, 2009 · 17:58 UTC#421
Hi
thank`s for the way with the poi . I`ll check this tomorrow.
But now I`ve another Problem. I talk with my Telephone and if there any speedcam warning the phone will be going down with the noise. When i turn off the speedcam warning i have no problem.
Also if I turn off the spoken speedcam warnings the other speedcam warnings (beep) going out.
And another Question. The Button for TMC-Traffic. Can I get This Button in the front? because I need this every Day.
Thank`s
Posted Oct 03, 2009 · 20:57 UTC#422
can anyone confirm that it works with the f500bt.. i read a few posts that a few did get it to work.. wondering why mine doesnt :cry:
Posted Oct 03, 2009 · 20:58 UTC#423
did you change the device type on the sys.txt to reflect the device type of F500?
Posted Oct 03, 2009 · 20:59 UTC#424
Hi
Thank`s
I have a new set of mods coming in the next day or so. Just finishing up some testing. I am at about 98% complete. Just a couple of images to edit. Getting in the larger speed limit, your speed and elevation signs that everyone has been asking for. Pretty much a re-rewrite from the ground up so lets see if it solves your problems.
Thanks,
Alex
Posted Oct 03, 2009 · 21:57 UTC#425
Thanks,
Alex
Does your next update include the speedcam reboot-problem fix and the female voice from IDT, posted in his thread on Thu Oct 01, 2009 6:39 pm?
Page 17 of 38
