Diaftia's Hybrid mods V1 - UPDATED: 12/1/09 FINAL
By diaftia · Aug 12, 2009in Completed Mods/Themes💬 950 posts👁️ 132,666 views
Page 25 of 38
Posted Oct 13, 2009 · 18:53 UTC#601
Many thanks in advance, I'll just try it tomorrow.
Hi, diaftia no working the street name! In the dispaly options is current road "on".
Please help me, thanks.
Posted Oct 13, 2009 · 19:00 UTC#602
Hi Alex,
Have the 10/8 MOD installed. Great job as always. Used it this weekend and missed the voice alert for speed cam. I do not look at the unit all the time and would not know if a speed cam is coming up without the voice alert. Could you put that back and make it so if you want it off you can turn it off. And to go a step further could you do the same for the speed limit voice comand. My eyes are on the road in front of me not the nav unit. Also one more thing when in non nav mode could you add the next cross road coming up to the top section that shows the road your on like Main Street/3RD Street with 3RD Street continually changing to the next cross street. Hopefully the cross road would show up larger so it would be easier to read. Thanks.
1. This is a tough one. I figured with the advanced set of tones that this would be enough. The problem is those audio files are about a 1.5 meg and really make the file huge. As you can see I am already at 11.5MB. On top of that I am not sure how many people really use them. I will look into it. I know there are a lot of scripts that go with the spoken warning but I am sure I want to put them in. Let me do some investigation.
2. It has not been done for the speed limit. That would have to be written as far as I know.
3. That is not possible unless its a directive while navigating. I think the intent is to have the map at a scale where you can see the next road or even two directly. I think this is why many people do not use the 3D mode. The 2D mode offers this much better than the 3D mode.
#2 AND #3 were wish list items not important. #1 I really feel is important and hope you can include in next release. Thanks for your consideration.
Posted Oct 13, 2009 · 20:53 UTC#603
Sorry for the confusion. Large red as in the bottom picture in your last post. One mod I had (maybe it was IDT's) had a much smaller speed cam icon. I don't really use this feature, but it is nice to see where a speed cam might be. I definitely have the speed cam warning turned off. However, the last 2 versions of your mod (10-8 and 10-10) I only copied the APL/IGO2 files, as the dates didn't change on the others. I did not delete the other files because then I need to reprogram my home address every time. I could try a fresh install of your mod if you think that would help.
I just verified that there is no beep when the turn restriction icon is present. Can you delete your save files, leave the settings as is and see if there is a beep? From there you can enable/disable stuff once its confirmed. I have a feeling that there is a saved setting from another set of mods that is enabling that beep. Its just not a part of my mods. If that STILL does not work then I will start searching through code. In my mods though (went to lunch today to verify yet again) its not doing it.
Thanks,
Alex
Posted Oct 13, 2009 · 20:56 UTC#604
Can you also delete your save files? As you can see there is very much a working current street when not navigating (top):
file.php?id=8370&t=1
and when navigating (bottom):
file.php?id=8375&t=1
If that still does not work please take a picture so I can see what you are looking at.
Thanks,
Alex
Posted Oct 13, 2009 · 22:21 UTC#605
Hey Alex,
Thanks for looking at the elevation thing.
But I also noticed there is a little "home" icon on the screen, sometimes two of them, with a number next to them that keep changing. What are those?
I know I'm missing something obvious...
Andy
Posted Oct 13, 2009 · 22:39 UTC#606
How come some people are having problems and I am not having any? Are they loading the mod properly? Are they deleting ths SAVE files? I have been using numerous versions of mods since before 2.0, and usually don't don't have any problems unless I copy something wrong.
Posted Oct 13, 2009 · 22:43 UTC#607
Hey Alex,
Andy
House/Street numbers. You can toggle them in the map display settings.
Posted Oct 13, 2009 · 22:44 UTC#608
I am pretty sure its an issue around save files. If someones else's mod sets a setting, and mine doesn't, that setting will remain in tact because there is nothing to change it.
Posted Oct 14, 2009 · 05:01 UTC#609
I think I got my mysterious two-tone chirps to stop. Turn off the Lane Warning sound in the Sounds Setting.
Posted Oct 14, 2009 · 14:00 UTC#610
Hi
thank`s for the good mod.
I`ve a question about "showing the Sky".
How can I get these? You write get out the Semicolons but I don`t find these.
Please can you help me.
And what step`s I must make to get the traffic button.
Thank`s
Posted Oct 14, 2009 · 17:19 UTC#611
Deleting the save files should set that to off. Good way to test though to see if it does fix it without doing so. Nice find.
Posted Oct 14, 2009 · 17:21 UTC#612
Hi
Thank`s
There are two ways to show the sky. One you can turn off smartzoom and adjust the tilt angle how you see fit by touching the screen. The second way is to leave autozoom on and adjust both of the bottom two sliders (for tilt up and down) all the way to the right.
Setting the proper region in the regional settings should enable TMC.
Posted Oct 15, 2009 · 01:22 UTC#613
Yep - that fixed mine as well. Confirmed this morning - but haven't had a chance to post.
Jim
Posted Oct 15, 2009 · 04:42 UTC#614
Jim
I know Boris posted a bunch of stuff in another thread about some of these obscure settings. I will go and get his quotes and gather them altogether. Should help clear up some of this. I know there is some clarification around the speedcam settings (on, full, off, custom). There is also Guidance Superiority. Not sure what that one is but I think its been posted before.
Posted Oct 15, 2009 · 10:32 UTC#615
Hi Alex,
I have the same problem with no nave mode, I miss the top street name and with nave mode, I miss the botoom street name! Current street is on!
I think I am missing a font ?!
Posted Oct 15, 2009 · 14:53 UTC#616
Hi Alex,
Did you delete your save files?
Posted Oct 16, 2009 · 06:27 UTC#617
This may make me sound stupid but I can't find an easy way to add to my favorites after the latest mod. Before when you enter an address it brought you to a page where you could route, add to favorite, add waypoint, etc. Now it just routes as soon as you type the address. I was able to add a favorite finally by clicking on plan mode, clicking on the destination on the map, clicking on the red target thing, then adding to favorite but this seems to be a real round about way of doing it. Is there a easier way or an option to get that old menu back?
Posted Oct 16, 2009 · 13:51 UTC#618
In the POI part of the quick menu click the second icon over. That will take you directly to the menu that has the add to favorites link. From there it will pre-populate your current location or you can delete that an enter your own.
The way it's designed is you should only need to go into planmode if you are entering in a waypoint/via or do some route planning. To enter in a single destination you can just do that in the quickmenu.
Posted Oct 19, 2009 · 00:20 UTC#619
Hi Diaftia,
First of all, the mod likes great. Thank you.
I have a problem with saving sound setting. I changed the volume for the guiding voice but every time I start the unit, it defaults back to very loud setting. How can I make it save the settings?
Thanks.
Posted Oct 19, 2009 · 04:50 UTC#620
Hi Diaftia,
Thanks.
I haven't noticed this. Did you clear your save files when loading this version?
Thanks.
Posted Oct 19, 2009 · 05:30 UTC#621
Hi Diaftia,
Thanks.
Thanks.
I did delete the old save files. In fact the "saving thing" was working fine until I tried the dynamic volume, then I could not save any settings anymore since.
Posted Oct 19, 2009 · 13:40 UTC#622
Has anyone else had problems getting the Call button to work on POIs? It is grayed out for me, even though my phone has been connected via bluetooth.
I was trying to call ahead at a restaurant we were going to to put our name on the list and it didn't work.
Posted Oct 19, 2009 · 16:30 UTC#623
Everytime I boot I get the error that it can't load ui_pioneer/800_480/loading.bmp. Then it won't go to maps, and reboots after about a minute, repeatedly. Any ideas?
Posted Oct 20, 2009 · 21:24 UTC#624
OK I saw this... putting on Dynamic volume seems to just crank the voice guidance volume to max. Turning it off again puts it back to normal. Do that until I can take a look at it. Thanks for finding it.
Thanks,
Alex
Posted Oct 20, 2009 · 21:25 UTC#625
I think this was brought up in the original stanislavovich thread. I will keep an eye on it.
Thanks,
Alex
Page 25 of 38
