Diaftia's Hybrid mods V1 - UPDATED: 12/1/09 FINAL
By diaftia · Aug 12, 2009in Completed Mods/Themes💬 950 posts👁️ 132,666 views
Page 26 of 38
Posted Oct 20, 2009 · 21:27 UTC#626
Everytime I boot I get the error that it can't load ui_pioneer/800_480/loading.bmp. Then it won't go to maps, and reboots after about a minute, repeatedly. Any ideas?
I have not seen this at all or heard anyone else having this either? Did you grab the latest version, delete your save files and if all else fails check to see if that file exists in the data.zip? I would do it but my laptop had an accident with a glass of wine and is out for repair.
Posted Oct 20, 2009 · 22:36 UTC#627
I got my first "out of memory" error today with this mod. It happened when I started a route and then it popped up. I turned the car off and back on then it was ok. A fluke maybe??
Posted Oct 20, 2009 · 23:19 UTC#628
Hey diaftia, If i want to show sky in the 3D map mode, How have to edit out the semicolons in the [map] section ? Can you post me the correct [map] section ? Thank's a lot!
Posted Oct 20, 2009 · 23:45 UTC#629
I don't think you have to edit anything. Go to the tilt up and tilt down settings and set them at 80 or higher. 90 will show a lot of sky. Hope this helps.
Posted Oct 21, 2009 · 00:05 UTC#630
Exactly, I need to remove that as you can now adjust those settings in the software.
Posted Oct 21, 2009 · 02:02 UTC#631
I got this very same error applying your Oct 10th update to your earlier one, I beleive Oct 8th ver. I reverted back to the older ver to fix. I did check the the data.zip file and the loading.bmp file did exist.???
I am building up nerve to try again. I just finished reinstalling Windows CE, restoring back to stock ver 3.01, applying your mod. It is all working, but not with your Oct 10th mod.
I also can not add new schemes (only) from the GPSSoftware mod - do I need to add the hacked ezrider.exe????
Posted Oct 21, 2009 · 03:42 UTC#632
OK I saw this... putting on Dynamic volume seems to just crank the voice guidance volume to max. Turning it off again puts it back to normal. Do that until I can take a look at it. Thanks for finding it.
Thanks,
Alex
Thanks, Alex. You're the coolest!
Posted Oct 21, 2009 · 16:10 UTC#633
Hey Alex,
Any luck on finding that elevation in feet thing? Perhaps for the next iteration?
Or if you've found just that code, I could try and modify that part.
Andy
Posted Oct 21, 2009 · 17:07 UTC#634
thanks for the great mod. paypal donation coming. it will take a little while to get used to and figure out all the added functionality. got one question, what are the two green buttons/indicators by the compass in the top right corner?
Posted Oct 21, 2009 · 19:05 UTC#635
The elevation is too big for the box, the smaller size was fine, or the box can be bigger, either way. Thanks, the mod is awesome.
Posted Oct 21, 2009 · 19:05 UTC#636
Posted Oct 21, 2009 · 19:16 UTC#637
Well, for me, the size of the text is about as small as I would want it, without having to put my nose on the screen.
But I think if it were in feet, it would fit.
I'm at about 5900 ft where I live, and besides, I would prefer seeing 5900 ft anyway.
But I do love the mod. Just need to figure out all the new stuff.
Andy
Posted Oct 22, 2009 · 16:11 UTC#638
Alex,
Been using your mod for 10+ days now and love it. Hope you're getting lots of paypals.
The only suggestion I might have (and its only a matter of personal taste) is to eliminate the black bar across the top or at least make it blue or green and very transparent . Don't eliminate the street name info or the clock, only the box behind it. I think the text will show up fine without the box and this would allow more sky to show without setting the tilt to 90 to see it.
If it's only a matter of commenting out a line of code to accomplish this, or if I knew what .bmp to change the color of, I'd appreciate knowing where and what. That way, I could just change my copy...
Thanks for all your work!!!! :D
Posted Oct 22, 2009 · 20:53 UTC#639
Andy
It is in feet and 4122 ft has the 4 on the box left line. Please make box bigger.
Posted Oct 22, 2009 · 22:26 UTC#640
Andy
Ok, I hadn't seen (since this mod) anything below 1 mile so didn't know it was still doing that. For me, it shows up as "1 mile 700 ft", or similar, and that is definitely too long.
So yeah, the box will have to be bigger even if in all feet.
aa
Posted Oct 23, 2009 · 14:05 UTC#641
Alex,
Same thought here. Would like to have the black bar transparent. Would be happy to change it myself if you could post the line code to do it. The only other thing for me is the dynamic volume....it goes from my minimum setting to my max volume when it reaches the set threshold with no change in between. Other than that, I like your mod better than any other I've ever used. A big thanks from me too. :mrgreen:
Posted Oct 24, 2009 · 19:26 UTC#642
I just installed this mod last night. I must say that it is very impressive. I think this is the one I will be keeping.
I went for a short drive after installation and everything works very well.
I have a few questions I hope you wouldn't mind answering.
1. I noticed I have no poi icons such as gas stations or restaurants. Tried to figure it out to no avail.
2. Can anyone tell me what the "Run an Application" is about? Res info, File Explorer, Opera
Thanks...
Any information appreciated
Posted Oct 25, 2009 · 08:41 UTC#643
diaftia,
Thanks again for continuing to update this. I love your previous version and just went to the new one. Overall I like it much better, but the one thing i'm struggling with is the search. before i would just hit POI, and i could type anything that i knew of, even if it was 450 miles away. for example i live in sacramento and my buddy has a shop in Los Angeles. I could type his shop name and it would find it. But now if i tell it to search it seems to only go about 140 miles away max. Previously i could search for home depot and it would show me tons of stores all over, some close some far.. But now it doesn't return as many. This is how my avic worked originally before i installed your older hack.
Perhaps I don't quite get the search, but with your old search button i could just hit search and type something. now i have to do it 1) around current gps location, 2) around location, etc. and it just doesn't seem to return the results it used to.
What am i missing here? i'm sure it's me :?
Thank you!
Posted Oct 25, 2009 · 12:37 UTC#644
Diaftia, great work as usual. I was wondering about the POIs as well. Can you clarify? I ran across this topic in the forum and I wonder if its something you could add. Seems like it could be useful.viewtopic.php?f=34&t=28044. Anyway thanks again for putting all this together.
Posted Oct 25, 2009 · 16:22 UTC#645
Go into settings for the POI, and click on manage, then you have to turn on all the poi icons, it can take a while and I have noticed after installing new versions, they all need turned back on.
Posted Oct 26, 2009 · 02:34 UTC#646
Tried installing the mod and I thought everything was good. Followed directions and double checked. Now when I boot up I get the System Starting. Please Wait screen and it never goes away. Now I restored my "myflashdisk" back with my backup files and still stuck on the system starting... please wait screen....this kinda sucks...
Posted Oct 26, 2009 · 12:31 UTC#647
went ahead and deleted all of "myflashdisk" again, restored to my 2.0 backup. Same thing, gets to sytem starting please wait...I am out of ideas....
Posted Oct 26, 2009 · 21:20 UTC#648
Hey Alex,
Andy
Hey Andy-
Sent you with a PM of a file to use to test this. There should be a link in a PM from me. I have no way to test it so let me know how it goes.
Alex
Posted Oct 26, 2009 · 21:22 UTC#649
Alex,
The top bar is k_header.bmp. I would love to have a grayish or transparent black bar at the top but I have not been able to sit down with PS to figure out how to do it a slightly transparent image. If you do create one PM it to me and I will take a look at making it a permanent change in the mods.
Alex
Posted Oct 26, 2009 · 21:29 UTC#650
Thanks...
1. Did you install the branding.zip file?
2. You can run these apps from an SD card. Don't worry about them unless you have a wifi card or tethering done on your AVIC. I dont use them either and have contemplated removing to simplify things.
Page 26 of 38
