Thanks Alex -
Perhaps I wasn't clear. I am a real green newbie...
Is the FLASHDISK the update I just received, or something else (not sure where I put all of the original documentation)?? Do I create this on an SD card?
Step 4 - The sky only shows when you change the tilt level in 3D right?
I can hardly wait to get home and try this!
THANKS!
BL58
Take the contents of my zip file you downloaded in post #1 and put these folders/files onto a freshly formated SD card. Insert the SD card into your AVIC and go to step 1 in the first post.
If you want to have the sky mode show in 3D mode go into the sys.txt file in the download and remove the semicolon in front of these lines in that file (do this on your PC):
[map]
2dheadup=1
zoomfactor=110
3d_tunnels=1
show_oneway=1
;3d_max_tiltlevel=10000
;3d_max_zoomlevel=1500
;3dcarsizemin=2500
;3dcarsizemax=5000
;3dcarsizemul=15000
It will then look like this:
[map]
2dheadup=1
zoomfactor=110
3d_tunnels=1
show_oneway=1
3dcarsizemin=2500
3dcarsizemax=5000
3dcarsizemul=15000
Save the file and make sure that new one you edited is in place on your SD card before putting it into your AVIC. The folder it goes into on your SD card is: "Copy and Paste in APL2-iGo". Once its on your SD card copy it over to the unit, per the instructions, with the rest of the files.
