Diaftia's Hybrid mods V1 - UPDATED: 12/1/09 FINAL
By diaftia · Aug 12, 2009in Completed Mods/Themes💬 950 posts👁️ 132,666 views
Page 5 of 38
Posted Aug 21, 2009 · 22:58 UTC#101
I looked at them soon after Ben posted them. All appeared in order and what I noticed I commented on. You must have seen those. I've asked both yourself and 69six??? to try his zip and see if you have the same "problems". Neither of you replied if you did. Some units just behave differently for some stupid ass Pioneer reason.
I must have missed that recommendation. I will go back and look and see what zip you are talking about.
Hey N-S-E-W-
I used ben's mods on the way home today and got the 0's. Do you have your VSS hooked up? What does it do anyway if the GPS is sensin vehicle speed anyway?
I have the F500BT unit. There's no vss wire, plus I just use the cig plug. It's a mobile device that I move from car to car. For music I use the car stereo.
Sounds like there may be a wiring problem, but I don't know for sure. There's others on here that know much more about that than me.
Posted Aug 21, 2009 · 23:31 UTC#102
My mistake. I completely forgot you had a 500. In my case I am sure its hooked up correctly as I researched the VSS wire when connecting it. But I can try disconnecting it since that seems to be the biggest difference between yours and mine. I know several people left it disconnected because they could not find where to connect it to and have had no problems in general. Maybe Bud has disconnected already his as I know he was going to try that.
Posted Aug 21, 2009 · 23:53 UTC#103
My VSS is disconnected on my F90BT. Same ol, same ol. I do notice that it seems to be more accurate now as far as length to intersection, etc. Go figure :lol:
Posted Aug 22, 2009 · 00:05 UTC#104
Look what I found while playing around with Gurjon's zip. Do you guys realize hoy many 1000's of people have this on their unit. The IGO community is pretty big. And while I was out playing I decided to catch a football game.
Posted Aug 22, 2009 · 02:20 UTC#105
(Links updated 8/19/09. First post edited.) Fixes are new data.zip and sys.txt. If you want the sky to show in 3D map mode then edit out the commented lines in the map section of the sys.txt. Also edited navigatemap file to fix rebooting problem when saving a POI. Last change was to add in the GPS mods but those are now at the top above the your speed sign and all the signs below that have been moved down.
I want to have about .5 to .75 of an inch showing but I am not shure what to add or change in my sys.txt.
Any help would be very nice
Self
ps i hate to ask such a newb question but thanks anyway
Posted Aug 22, 2009 · 04:52 UTC#106
Look what I found while playing around with Gurjon's zip. Do you guys realize hoy many 1000's of people have this on their unit. The IGO community is pretty big. And while I was out playing I decided to catch a football game.gurjon tc.jpgda bears.jpg
Call me dense but I don't get it. :?
Posted Aug 22, 2009 · 04:57 UTC#107
how do you tilt using this mod?
Posted Aug 22, 2009 · 08:24 UTC#108
The 2 fields on the lower left corner (distance to Via point, and time to destination) appear to be fixed. When I change in the menu to different choices, nothing happends.
How do I change these fields.
With the new version, the demo mode stop button is now in the middle of the screen. Is this by design?
Got a place for the button given its limitations. Working on some other things as well. Hope to have something up this weekend.
Posted Aug 22, 2009 · 08:26 UTC#109
Can you check yours with this test? I have found that if I turn in my ignition but do not start the car the trip computer works EVERY SINGLE TIME. I am thinking the times it has been working was when I was messing with something then started the car and left? Not sure yet.
Posted Aug 22, 2009 · 11:29 UTC#110
I installed the mod yesterday. Thanks!
The trip was counting for me upon install with VSS and engine not running. Once I paused and reset the trip, it wouldn't count anymore.
Posted Aug 22, 2009 · 14:57 UTC#111
Would somebody please post the data.zip file with the MSN stuff removed? Thanks in advance.
Posted Aug 22, 2009 · 17:39 UTC#112
I just installed this on my F90bt and when I started it up everything seemed fine until I tried to go to the map screen. Then I got an error message that said:
Failed to open file:
gfx/day/cs.bmp
Exiting application
After that message i'm not able to open up the destination menu or the map screen. Any ideas as to how to fix this? Apparently it can't open the cs.bmp for some reason but I don't know where that file is normally located. Can anyone help?
Posted Aug 22, 2009 · 17:52 UTC#113
OKAY..I'll let ya know. Thing is though, if I have it up nd booted THEN I go to start the truck it will have to re-boot again. On Toyota's the accessories are disabled upon moving the key to "START" so it might be a moot point but I'll give 'er a go.
Thanx!
Posted Aug 22, 2009 · 18:19 UTC#114
Thanx!
I hear you. It should still start counting at rest though. It will just be the idle time. Altitude should register too.
Only other thing it could be is where we have it sitting inthe config files. We might need it to load the scripts for it later if possible.
Posted Aug 22, 2009 · 21:13 UTC#115
gfx/day/cs.bmp
Exiting application
Make sure you copy the fonts over. You get that error when a font is missing.
Posted Aug 22, 2009 · 21:33 UTC#116
Ah thanks, I guess that does make sense. I will look into it.
You're welcome. All of this stuff is available as models so adding it is pretty easy.
Would that be distance to waypoint?
Posted Aug 23, 2009 · 00:43 UTC#117
His error is with a bitmap called by a color scheme, not a font.
Either of those.
Posted Aug 23, 2009 · 01:38 UTC#118
Either of those.
Yeh but it's referencing a bmp that has never existed in thIs setup. my only explaination is that is a non-descriptive error. The only time I have *ever* seen this error is when a font was missing. Made it real fun to troubleshoot. I know because I left one out originally and that was the error people were getting. ;). Back on page 2-3 IIRC.
Posted Aug 23, 2009 · 07:54 UTC#119
Original post updated but here is the info:
  • 1. Added IDT Speedcams with spoken warning and settings toggle
    2. Moved route overview cancellation button to a better location
    3. Removed elevation sign when navigating since its on the left already in the route info box (moved speed sign up when in route)
    4. Changed time to destination when in route to time to via point for multi-destination routes
    5. Added search for POI icon to search for everything from one location
    6. Fixed search icons. Got all of the search around GPS, Cursor and destination buttons working properly.
Links in first post updated.
Posted Aug 23, 2009 · 14:06 UTC#120
Daifia great combine mod......i dont no if this is a bug or its just my unit. i get this error message when i click the flag icon.
Posted Aug 23, 2009 · 15:41 UTC#121
Fixed. All links updated. Sorry for the problems... That button worked when in route but not when not in route. So now it works in both cases. :)
Posted Aug 23, 2009 · 22:25 UTC#122
Diaftia,
Thank you for all your hard work on this! I do have a question for you though. I tried adding a speed cam and when I clicked done, I got an error. I got the same error when I tried edditing/deleting the cam too. After the error the only thing that I can do is reset the unit to get the navigation portion working again.
IGO8 - Failed to open file: k_but_dest_home.bmp#3 exiting application.
Can you take a look into this? Or direct me on where you think the problem is coming in?
Thanks again for all you've done!
Sincerely,
R.
Posted Aug 23, 2009 · 22:48 UTC#123
Diaftia,
Sincerely,
R.
Using this its obvious that I need to do more testing. Rolling back the changes until I can test further and release properly.
Thanks,
Alex
Posted Aug 24, 2009 · 17:05 UTC#124
I think I have the fixes done. I will test today at lunch and tonight on the way home. If anyone wants to help test this fix and the speed sign fix PM me and I will send you a link to the data.zip file.
Thanks,
Alex
Posted Aug 25, 2009 · 04:01 UTC#125
Everything is working correctly now. Had some QA assistance this time too (thanks N2Deep). Sorry to those that had the hassle of upgrading to find bugs. I am going to pace things from now on and release less often with more testing. In a nutshell I am going to take N-S-E-W's advice (lesson learned). :)
Links in the first post updated.
Page 5 of 38
