Updated d/l link posted in first message.
Now works with Gurjon or default iGO skin. MSN might work as well. Cosmetic changes.
Thanks boris, I will test it out tonight see if it fix some problems I am experiencing on my F500BT.
1. Error when launching the the phone dialer thru Navigation/Map screen.
2. Error when making phone calls thru POI interface.
These two are supposed to be fixed. It will use AVIC's internal Bluetooth inteface now.
Just tested on my F500BT, better user interface, especially on the menu settings.
POI call is now fixed, but still having same error when launch phone dialer thru Map/Navigation.
Another new error, I am currently using Samantha TTS 1.2, It's working fine, but if I try to switch it, system reboots.
go to [setting]->[Region] and press on [samantha TTS 1.2] -- REBOOTS.
Will try to replace the data.zip to do more testing tomorrow.
Can confirm, reboots when you go to change the voices. I am using a non-TTS voice on an F500BT.
It does now have audio with the supplied data.zip (on F500BT units). You don't have to use a generic data.zip anymore.
Thanks again BorisM for posting these updates.
You're welcome...
I don't think one should change voice through normal iGO facilities... Does it blow up if you go to system settings and change it there?
Tried with a different data file, and did some minor change on the gurjon skin (removed the Exit button). It's works much better now.
Sorry I forgot the orginal source of this data file, I was previously use it with leetlauncher/igo, with all the unnecessary resolution removed.
For those who are interested to try out, here are the data.zip and modified gurjon skin:
Thank you for sharing.
Can you tell me on thing ?
Should I delete the iGo fodler and then copy the skin files or copy over the skin files to the existing iGo folder ?
No, DO NOT delete the IGO folder, the IGO you downloaded from boris's link is not a completed igo, it's missing stuff like ScanSoft, which is used for the voices.
Thank you again.
Fully working with your changed data.zip.
Perfect !
Can you explain what changes you made to the gurjon zip please?
I only made a minor change base on Boris's latest update. That is to remove the [EXIT] button. As EZRIDER.exe is not designed to be able to exit and re-launch thru Poineer Main Menu, we should always use the [OFF] button to hide the Navigation/Map instead of let it EXIT from the memory.
BORISM,
got a question for you, i understand how the installation is but if i want to use IDT's mod back do i have to replace everything again or would just replacing the data.zip work?
BORISM,
I believe DATA.ZIP, SYS.TXT, and clean up the SAVE\iGO folder.
Update 26-08-2009
http://www.4shared.com/file/127716134/6 ... 08_09.html
Just copy over existing files.
- Clock back to Tahoma font
- sys.txt cleaned up- Larger 3D font, map move intertia, clean-up.
- Misc. interface changes.
I have been using Gurjon skin on my Mio-PNA and like it very much.
Now I just updated my F500BT to the errider 8.3 version and run the latest 8.3 maps very smoothly.The firmware is 2.0006. I tried to install Gurjon skin but F500BT didn't boot up. The screen just stays in "system in progress... " Wonder if this Gurjon version only works with firmware 2.006? Appreciate your help.
It's designed to work with proper firmware 3.0, which is tghe only way to get proper iGO 8.3 working. All bets are off if you have some kind of hybrid setup with 2.006 firmware and iGO 8.3 grafted on top...
i dont know how you guys are getting this to work lol.. ive followed the directions and i cant get past the system startup screen, i added the extra lines in the sys.txt also but still no dice. im trying to run this on an f90 bt with the 3.1 fw
Me neither...and I have tried! Just about given up. Also have the F90BT.....reboot, after reboot, after reboot!
Try your original ezrider.exe file. I suspect the one in the gurjon package is the hacked version. I think there are issues with the hacked version and some Avics (from reading the hacked 3.0 thread).
I had to add this to the sys.txt of the latest gurjon release to get the disply to show correctly. It was only showing the upper left hand corner of the screen until I added this.
add to sys.txt if you have display problems.
[rawdisplay]
screen_x=800
screen_y=480
class="landscape"
highres=0
dpi=250
Specter,
Is there anyway you can port dimka skin to work with AVIC?
Specter,
yes, it can be done. Needs the same code updates that are being added to the gurjon skin.
On a side note:
You can change the voices for the gurjon skin by changing them from the systems settings menu. Also, the TTS voices work! If you took my advice of deleting everything from the IGO directory before updating, you will have to copy the scansoft directory from your original install back into the igo directory. That should fix the TTS issues.
Hi I have to isues with the new update. Tmc is not found and doesn't work. And my phones audio doesn't get picked up autmaitcaly when in call. For the rest it is working great. Any idea on how to fix tmc?
Ok got tmc wordking. Only having problems with bluetooth. Any ideas.
[rawdisplay]
screen_x=800
screen_y=480
class="landscape"
highres=0
dpi=250
I tried everything including deleting everything in the APL folder. I reinstalled using the Gurjon package and also added softscan directory from original file. I also copied the sys.txt along with ezrider file. Still hanging when starting up,
Any other ideas?
Jimbo
