Gurjon skin for AVIC
By BorisM · Aug 20, 2009in Completed Mods/Themes💬 205 posts👁️ 55,073 views
Page 9 of 9
Posted Dec 18, 2009 · 17:01 UTC#201
Hello. I have a pionner F900BT and use the last lexa skin (GJ6.9.2p_800x480) and commonlib. All right. I want to ask if I can use newer skin (eg GJ6.14.p_da) and if so how. Thanks.
Posted Feb 04, 2010 · 09:25 UTC#202
Ultimately it is so difficult to be done?
Posted Feb 19, 2010 · 08:56 UTC#203
I was able to get this mod working but I can't to remove the girl in front of the car and the car image is position to the right of the road instead of the center. Can someone help me???
Posted Feb 22, 2010 · 19:43 UTC#204
Hi Xdanx,,
Search in sys.txt for female.mdl and change it to another one that you can find in GFX folder,, (speedbike,, sportscar,, chopper or whatever),,
Good luck,,
Posted Aug 14, 2010 · 11:07 UTC#205
Hi bsharp8,
I'm having the same problem that you had when I try to acccess MSNDIRECT, - the same error message comes up. How exactly did you solve the msndirect problem? I did read the posts, but I can't begin to figure out
"It looks like an original data.zip file!!! Make sure, that you are correctly has been installed skin into content\skin folder"
- what that means, or what it suggests I do.
Any help would be so appreciated!
thank you,
ic
1. You may not to rename skin. The skin name must be "GJ6.9.2p_800x480.zip"
2. You must put it into content\skin folder
3. if you are use an european device, download the file sys.txt from this post and put it into IGO`s root directory, if your version is US.... i don`t know what to do, it will be better to ask it from anybody, who uses an american device
There is a new version of skin. Now it`s possible to disable not used parts of the screen behind lateral buttons, top and the bottom bars from MAIN MENU - SETTINGS (pioneer map size)
Hello, I´m from Spanish. I don´t speak english very well.
I´ve download this files ("GJ6.9.2p_800x480.zip") and sys.txt but I need a data.zip.
Thanks from Spain
Page 9 of 9
