How can we change the truck image to the standard triangle in this skin?
Hmm - very interesting. I've chosen a VW Golf as "my car" (it's in the settings somewhere), but yet I have the standard triangle as my position indicator on the maps. ![]()
MY DEVICE IS F900BT, FOR USE MOD IN F500BT DEVICE, READ HERE:
So. My latest version of mod... I`d has been fixed many of bugs +
-Added MSN support (in test mode)
-Button 'Destination..' starts external progs list
-By pressing volume button mutes IGO sounds
-Parking brake independence
-Performance as in IGO8 ver
http://www.4shared.com/file/130954399/8 ... FINAL.html
It`s full flash from AVIC, just add maps, voices and other content
How to install?
1. Enter as TESTMODE.
2. Backup all your data to SD or USB.
3. Select My device - control panel - storage manager
4. Select SDMLC, the size must be 1,8 Gb
5. Press Properties - Dismount
6. Press Format, and select FAT 16. Then run.
7. Wait for "Format OK" message, press ?? and then "MOUNT". Close all windows.
8. Copy APL, APL2,... and other - (all content of my FullFlash) to My flash disk
9. Restart your device.
Folder Voice and Lang must to contain only one file.
Why i choose FAT16 file system? Find in google.....
It`s all tested, works well, just install it as in instruction wrote....
Image.res file (copy it into APL directory) and skin (to fix a problem with size and situation with mediaplayer string and button in navigation map mode). Copy skin into CONTENT\SKIN
http://www.4shared.com/file/131226487/a ... Image.html
http://www.4shared.com/file/131222296/4 ... 0x480.html
Lexa-Osmenog
Nice. For MSN page, though, I would use the stock one. This one (from stock PDA iGO) is missing new data features we got with 3.x firmware -- stock prices, local events, and news headlines.
So. My latest version of mod... I`d has been fixed many of bugs +-Added MSN support (in test mode)
How to install?
Lexa-Osmenog
This is nice.
However, for most F500BT users (including myself), who are currently mixing WINCE, APL from official Pioneer 2.00600 firmware with APL2 from X910bt 3.0 packe, plus the hacked Ezrider.exe. I suspect this will NOT work directly.
As I previously tested, the game stopped is the MainMenu.exe, and there are also some incompatible issue in the SystemSetting.exe, and minor issue with Av.exe. By replacing those three with the 2.00600 version, the system will still work.
I have not got chance to fully test everything. But for F500Bt users, if you want to try out the latest Gurjon mod, I believe you need to do a bit mix to the Lexa-Osmenog's package before proceed:
1) set the device type to PIONEER749UC (US) or PIONEER749EW (EU) in the sys.txt file to reflect your F500BT mode correctly.
2) Replace the MainMenu.exe, SystemSetting.exe and AV.exe in Osmenog's APL folder with the one you currently have.
3) Follow Osmenog's Step-By-Step instruction.
Your abs\right!!!!
P.S. There are 2 new files in my earlier post.
Has anyone gotten the MSN feature to work on the Gurjon skin? I found the button for it and press it but nothing happens.
Thanks, William
-=NEW=- 10.09.09.
Most probably the final version of the skin.
- Bottom bar is made wider -- looks cleaner, no gaps. Track name goes on the background now.
-Tapping Distance to Destination button calls up "Delete Route" dialog.
- Number of satellites moved to a separate layer under the Menu button. Brightness of the GPS layer is the same as Current Speed layer.
- When in route, altitude is displayed in the bottom bar. When driving with no route, above the number of satellites.
Nothing should overlap.
link?
link?
Above?
I am having trouble again saving the volume. Even after deleting volume setting out of SYS it still goes back to way to loud. Any idea how to fix this.
Is the device code in SYS correct for your uit?
I have a f900bt so wich code should i use I now use PIONEER746EW
Just to make sure... Navigation voice volume, or something else? I'll let Osmenog know if he doesn't see it here.
-=NEW=- 10.09.09.
I would hope a newer version to have the [Home] function fully implemented like the official one in stead of using Favorite 1. So that we can also Call Home from the phone menu.
I actually have spent sometime on reviewing the ui files in both GJ_Lexa skin and the original one, I think porting the Home function in GJ_Lexa skin is feasible, but it will take some time.
I need some help. I installed the final skin and I get an error when I push the MSN Direct button. I took a picture. Sorry about the quality it's very sunny outside. I tried my best to clean it up a little.
Thanks, William
It looks like an original data.zip file!!! Make sure, that you are correctly has been installed skin into content\skin folder.
Here is newer version (mix with 6.10 version of gurjon original skin with driver alert support)
SKIN http://www.4shared.com/file/132345796/a ... 0x480.html
Half Patches (Extension) http://www.4shared.com/file/132345269/b ... nsion.html
Thanks, William
That did it. This is perfect because I like the older skin better anyway. Thank you very much.
William
Thanks, William
William
Oops! Now it says out of memory when I turn on the radio and go to the map. Any ideas?
William
William,
Try to disable a scrolling in the street names
After porting the "Home" function code from the pioneer data.zip file, I kept getting error of missing . I thorougly checked all the related ui files. Can't find any missing a closing.
A bit stuck at here, at tips is appreciated.
Hi bsharp8,
I'm having the same problem that you had when I try to acccess MSNDIRECT, - the same error message comes up. How exactly did you solve the msndirect problem? I did read the posts, but I can't begin to figure out
"It looks like an original data.zip file!!! Make sure, that you are correctly has been installed skin into content\skin folder"
- what that means, or what it suggests I do.
Any help would be so appreciated!
thank you,
ic
Hi bsharp8,
thank you,
ic
1. You may not to rename skin. The skin name must be "GJ6.9.2p_800x480.zip"
2. You must put it into content\skin folder
3. if you are use an european device, download the file sys.txt from this post and put it into IGO`s root directory, if your version is US.... i don`t know what to do, it will be better to ask it from anybody, who uses an american device
There is a new version of skin. Now it`s possible to disable not used parts of the screen behind lateral buttons, top and the bottom bars from MAIN MENU - SETTINGS (pioneer map size)
Is this for 2.0 or 3,0 ? The reason that I am asking is that I am still on 2.0 and I would love a cool Nav theme except that they are all for the 3.0 firmware ![]()
It's for 3.0
