In fact the only thing it does is modify the default 3.0 software for NAV and nothing else.
Hey David,
Thanks for posting your mod; it is much appreciated. I had just starting trying to port your 2.0 mod to 3.01, but may not need to do that now that you have posted your mod.
What I had been doing was just adding your mods for the following to the standard 3.01 build. Basically, simply adding your code from your 2.0 data6.zip build into the 3.01 "navigatemap_800_480.ui".
* Nav mute during navigation
* Linear compass with delete route function
* Shortcut keys when no route is present (along top)
* GPS status (bottom right)
* Current speed and altitude when no route is present (beside shortcut keys)
* Current speed and altitude during navigation (4 boxes at bottom left as in the 2.0 version)
* euro speed limit/speedcam warning during nav and when no route is present
* house number display (the 2.0 version with the little house in the middle)
I was not trying to chnage anything else from the standard pioneer 3.01 build.
However, being a neophyte at this I have a couple of questions:
1. Are the only files that I need to modify to carry across the above mods, the "navigatemap_800_480.ui" and "speedcam_800_480.ui"? Obviously, plus the relevant bmp files.
2. Do I need to modify/replace the sys.txt to get the above to work?
Or is it much more complicated than this?
Cheers,
Duane
