IDT skin#2 v3.0 12/30/10 (download link updated)
By ill.die.trying · Oct 25, 2009in Completed Mods/Themes💬 442 posts👁️ 72,478 views
Page 8 of 18
Posted Feb 17, 2010 · 06:58 UTC#176
IDT, I have found following issue with you latest update. I use EU version from 02/15/10.
I go to search address, after typing correct address I'm on the planing screen and here the address is placed (shown) correctly. After I click "Add Dest" I'm moved to navigation screen on the map. However on that screen destination is places in wrong place and navigation tell to drive to wrong place. Usually it's about 1 mile moved.
With your previous mod (from 2009) everything was ok.
Posted Feb 17, 2010 · 07:30 UTC#177
The 2/15 version won't need the fuel consumption fix right?
And thanks for a great mod
Hi IDT,
I use your latest mod, and i'm curious do you know how to change the phone link from Phone menu to PhoneBook ?
Now when you click on the green handset the Phone Menu from AVIC is shown (there you have the dial pad, incoming/outgoing calls). Instead of this view I'd like to see the PhoneBook view where I can find person I want to call. Is it possible ??
Can you post me what to change to achieve following behaviour:
- short click on the green handset: open Phonebook
- long click on the green handset: open Phone Menu (as is now).
p.s. Please add to your instruction information for people who want to use custom branding.zip to delete kml.icon from data.zip (DATA.zip\ui_pioneer\icons\poi\kml.icon).
I agree this would be a good addition when you have time.
Posted Feb 17, 2010 · 15:30 UTC#178
Thanks for the help everyone. 1 more question how do i get navteq maps cause the map i have on my x910 is missing a major roadway in my area it will show it when im driving on it or if it routes me thru it but it will not give me a option of entering it as a address destination .
Posted Feb 17, 2010 · 15:51 UTC#179
search the threads re: NAVTEQ maps
Posted Feb 17, 2010 · 15:58 UTC#180
Hi IDT,
i will try to figure out how this could work, i'm not aware of any commands that would lead to the phonebook but i'll try
i will add this to the instructions, thanks for pointing it out,
Posted Feb 17, 2010 · 16:01 UTC#181
now this is weird, could you try reloading the original data.zip and try it and then reload the EU DATA.zip and try it too, not sure why this is happening, if the problem still continues i will look more deeply into it, anyone else having this problem?
Posted Feb 17, 2010 · 17:47 UTC#182
IDT,
Some Questions:
I currently have diaftia's mod on my unit and i want to try your mod. Can I just overwrite the files or do I have to go back to fresh 3.01?
Also: You have the msn version and the alternate msn version. what is the difference?
Posted Feb 17, 2010 · 18:12 UTC#183
NOTE: If you use this mod and you dont have a navteq map installed go to extension folder and delete map changer before you install the mod. I just had to reload my 3.0 cause i hit this button and it threw my system into a reeboot loop.
Posted Feb 17, 2010 · 18:29 UTC#184
-currently this has the subaru impreza rally car as the default 3D car
to change the 3D arrow to a car model
download the 3DCars.rar file on the download link provided and extract it
and you have to edit the sys.txt
change the current values of this
3dcarsizemin=2500
3dcarsizemax=5000
3dcarsizemul=15000
to this
3dcarsizemin=5000
3dcarsizemax=8000
3dcarsizemul=30000
and add this part to the [3D] section
car_day=hot_rod_red.mdl
car_night=hot_rod_red.mdl
ghost_day=hot_rod_red.mdl
ghost_night=hot_rod_red.mdl
you now have to transfer the desired carmodel and tex file to the gfx folder in the data.zip and change the names of the above code to your selected car model name, i haven't tested every car model out as i already like the hot_rod car, but it's just a trial and error thing
How do I transfer in to the gfx folder? It wont allow me . I tried change the text in there and i just get a arrow
Posted Feb 17, 2010 · 18:44 UTC#185
IDT,
Some Questions:
yes u can overwrite it I just did. Use the msn and if it does not work use the alternate.
Posted Feb 17, 2010 · 21:17 UTC#186
Hi IDT,
I made some testing and what I found:
- power up avic, connect mobile phone
- i'm in the navigation mode and press green handset -> move me to Phone Menu.
- Now I click Menu hard button and click on the contacts
- from the contacts view I click hard button MAP I'm back in the navigation mode.
- now when I press again green handset it moves me to contacts instead of phone menu.
- if now i manually go to phone menu and get back to map, next click on the green handset moves me back to phone menu.
So probably the command
onrelease='EXEC "other.pioneer.postmessage" "Tel" "WM_APP_AV_IGOMAP" 0'
is ok, but the is some other variable that define where to go.
I hope it will help. On Friday I will make some more testing, to check if it's working after avic power off/on. Later I'll try to take a look on the user files. If i find anything interesting I'll let you know.
Posted Feb 17, 2010 · 21:23 UTC#187
I checked twice reloading between 02/15/10 and last version from 09. On the 09 version everything is ok, on the 02/15 is something wrong. I hope to have some free time on friday to check alternative EU version and oryginal.
I'll keep informing you.
Can anybody else from EU confirm that issue ??
Maps are TA 2009.09.
Posted Feb 18, 2010 · 03:43 UTC#188
this code
is pretty much what we have regarding the phone shortcut, like i've said in my previous post regarding phone shortcut whatever the last state is in the phone menu thart's where the shortcut will go to
Posted Feb 18, 2010 · 03:47 UTC#189
i will look in to this,
Posted Feb 18, 2010 · 04:16 UTC#190
i compared both EU zip files with the regular and can say that they are the same, could you try using the regular zip or the msn zip and see if it's still wrong, also, what map are you using? provide me with the map version and country and a destination where you always get wrong address and i will work on it on the weekend
Posted Feb 18, 2010 · 04:38 UTC#191
This all looks great, but I have a question. Where are you supposed to put the NavTeq maps? On the first page it says to add a folder in your IGO folder and put them there, but everyone knows that there is not enough space to have another map file in place. I think that I have about 120 mb of space left and that is after I deleted a lot of maps that I dont use. Also, where can I find the basemap.fbl ?
Posted Feb 18, 2010 · 05:48 UTC#192
in MYFLASHDISK\APL2\IGO\CONTENT and not in iGO folder, create a new folder and name it as map_nt, basemap.fbl should be found in your current map folder in MYFLASHDISK\APL2\IGO\CONTENT , there is a way for iGO to read content files from storage card (SD), i will still have to try this out but it won't be that hard as you just need to add something in the sys.txt for this to work, i'll have it figured out soon when i get a chance and have instructions for it,
Posted Feb 18, 2010 · 07:08 UTC#193
I am running the same data zip and haven't had any issues regarding the correct address,It has worked fine for me everytime.The only thing i have noticed is that when i press the POI search button the search screen appears but doesn't list any results after i input a couple of letters.However if i try the same thing a little later it works!
Posted Feb 18, 2010 · 11:02 UTC#194
How do you do, in me incorrectly are reflected the numbers of houses in new skine. The numbers of houses which are to the right reflected to the left and vice versa. you will forgive for the poor English of the, thanks
Posted Feb 18, 2010 · 12:35 UTC#195
ok last night I downloaded all the IDT files and then realized during insllation that I didnt know which files to use...so this is what I came up with;
I am on 3.01 firmware:
so I installed skin#2 3.01 and fuel calc
but after going through all this I am thinking I am missin something like : IDT 3.0 or 2.0 I dont know...
I want the whole mod, but should I have installed the IDT 3.0 before the skin#2 because I am missing some files ...like extension folder and the maps for map_nt folder I added.
So as for a step by step:
I think I shoud have done the IDT 3.0 install then the #2 skin ....right??? or not.
If some one would give me the right path thanks :?::?::?:
Posted Feb 18, 2010 · 12:39 UTC#196
also can I run idt3.02.5 with 3.01 firmware?..........thx
Posted Feb 18, 2010 · 13:35 UTC#197
what map version or map provider are you using, i had the street number coded that way as one of the EU users pointed it out to be on the wrong side,
Posted Feb 18, 2010 · 13:37 UTC#198
skin#1 and skin#2 is for firmware 3.0, please read the instructions carefully to avoid bricking your unit
Posted Feb 18, 2010 · 17:03 UTC#199
I got it ....thanks its pretty cool ..is there a way to change elevation to feet?
Posted Feb 18, 2010 · 17:15 UTC#200
IDT,
I just noticed this morning that I'm not getting my highway sign notifications. I looked in the road sign screen and changed from signposts to roadsigns(or lane info?) a few times and they don't show up. I tried this with and without a route. In my sys.txt I still have the show_roadsign=1 value under debug. I also added fov=55 to it but I had that before and it did not kill the highway signs. thanks for any help.
Page 8 of 18
