Alex,
I am having a hard time trying to use the AVOID menu (STREET, MANEUVER etc, sometime it works and sometime it doesn't), because the CURSOR is staying at the starting point of the itinerary, so when I click on AVOID MANEUVER after the first turn, there is no effect on the current route because the CURSOR position is in the past.
I am looking for the code to set the CURSOR position to the next turn (whenever the AVOID menu is popped up), as this will render the AVOID instruction effective.
Can you lead me to it?
Thanks.
There are a few but the ones you are probably looking for are:
map.MOVECURSORTOSELECTEDITEM or map.MOVECURSORTOGPS
