I'm drooling man.... I got a F900BT and I live in the deep south, I don't need msn,eu, tech support, just the mod man....come on..I'm hurtin' here...
got me hooked man..I gotta learn to code. Someone needs to post a how to manual. I will donate....
I sent it to you. Test it out and let me know if there are any problems. REMEMBER- NO MSN!
As far as learning to code, it is fairly simple. The key thing is to get the practice and know what commands do. The best way is to make a copy of your Data.zip, use that for experimenting and just change stuff around to practice. The easy thing is that all shortcuts, icons, etc., are placed by pixel height and width starting at 0 for both at the top left corner. For the placement of shortcuts, icons, etc., x is the vertical position going to 480, and y is the horizontal position going to 800. Look at the coding to get familiar with the commands and keep in mind that most of the UI for the texture placement can be found in 800_480/UI folder while the actual hard coding can be found in COMMON/UI folder. When playing, always make sure that you have a backup of your present Data.zip. If the scripting is incorrect, then your system will boot until you hit the NAV part and you will have an error showing you what script it cannot find (LOL, I had lots). Then just fix it or replace your working Data.zip. Hope this helps.
Me, I dont take donations because the mods that I do, I do for myself! If it is good and people want to use it, I will share it! If I take donations, then I would be expected to make mods for others that I cant test myself (eg. MSN, EU, etc.) and I will be spending countless hours troubleshooting which I do not have time to do
