Abb's NAV Mod V2.75 for 'Chrome Theme' - Upd. July 7 '10
By abb1 · Mar 23, 2010in Completed Mods/Themes💬 719 posts👁️ 85,531 views
Page 12 of 29
Posted May 08, 2010 · 19:09 UTC#276
Just rename the button in the ui to whatever you want and then put the number behind it for the number of functions and images that are within the bmp. I already have a history button in my mod. You get it by longpressing the address button. This mod literally has just about everything :)
Posted May 08, 2010 · 20:42 UTC#277
Yeah, it has everything and I seems not be able to know all the hidden stuffs, like the long pressing address button.
:mrgreen:
Posted May 08, 2010 · 22:50 UTC#278
:mrgreen:
Yes, it does have everything! The main screen has 14 icons with 7 that have a dual fuction by long clicking. You also have the time (dual function), speed, and street which are also all clickable for a function leaving this mod with a total of 25 features clickable on the main screen to bring up features of this mod. ALL buttons and descriptions are on the front page and they are updated regularly as they are updated
Posted May 09, 2010 · 05:43 UTC#279
Hi ABB,
I have been trying to find the name's of the bmp's of the box that show the next arrow turn, the box with mute and delete route buttons and the box with the name of the next turn street. Also can't find where they are referenced in the nav 880_480.ui file. Would you mind pointing them out for me?
thanks
Posted May 09, 2010 · 13:43 UTC#280
In 800_480/IDT_dir_cockpit.bmp
Posted May 09, 2010 · 14:34 UTC#281
Ok, found it thanks ABB. you have been a great help. One more question.
In order for me to rearrange this box, i guess I would also have to modify the in the nav.ui file in the common folder as well and is there anywhere else that I would need to modify?
Posted May 09, 2010 · 15:48 UTC#282
No leave that alone, just do the changes to the box, there is no need to go anywheres else. All you are doing is changing the appearance of an object, NOT the scripting, so just leave it and work on the box only
Posted May 09, 2010 · 16:29 UTC#283
for some reason when i use your data file with the emulator, i cant seem to get bto the nav screen. it takes me to the route planner screen. can you let me know how to get to the nav screen with the emulator?
thanks
Posted May 09, 2010 · 17:00 UTC#284
If you have access to the "About" button at the bottom of the screen, long-click on it and it will bring you to the nav screen.
Another alternative would be to load a saved route, if you migrate your AVIC's saved configuration to your emulator.
Posted May 09, 2010 · 20:15 UTC#285
thanks
I have never used an emulator. I tried to get one for the 3.0 version when it first came out and I couldnt find one that works with it. I now use my spare F700BT right beside my computer, so this is a MUCH better solution for testing.
Posted May 09, 2010 · 20:34 UTC#286
I have been using the avic emulator that was just posted on daftias site in response tomy request. It is pretty good and at least helps with the image and icon placements. I got it to work and it is not bad. In response to before, I am planning on changing the location of those images and that is why I asked about the nav.ui in the common folder.
Posted May 10, 2010 · 01:42 UTC#287
Hello Abb,
Been following this thread closely for a while now and I think I'm ready to install your chrome theme and latest nav mod. I have a question that I wasn't clear on after reading the posts....I currently have Diaftia's V2.3 mod installed. Can I install your chrome theme and latest nav mod without reverting back to stock? Thanks for all your hard work!!
Yes, just make sure that you install ALL the files in the proper locations. When it asks to overwright, just say 'yes' and you are good to go. Any mod can be overwritten, you just have to make sure that 1) - you install ALL the files associated with the mod and 2) - delete all user data in your 'MyFlashDisk/USER/UserData' folder by deleting the igo folder.
Do this and your good to go :)
Well Abb guess I have to be the one fly in the ointment! I loaded your Chrome Image V1.2 file, then your Chrome Nav Mod1.65 AV and both seemed to load O.K. I then tried to load your GFX folder and it seems to load about 40 % of the files then starts giving me errors (appears not to load the files completely) and as a result of these errors and the incomplete load the Schemes folder won't load at all. I'm not a complete idiot when it comes to computers, but I've tried deleting and reloading the files 3 times and get the same errors. Any idea what I could be doing wrong?
Posted May 10, 2010 · 01:45 UTC#288
You might have to delete some maps to make space. The GFX folder is some 120 MB, so with the internal 2 GB less all the maps, you are likely to run out of space.
Posted May 10, 2010 · 02:03 UTC#289
What do the errors say? if it is space, then first off delete the GFX folder that is already in place (if there is one in place), second, do like Chuck says and delete some maps from your map folder that you do not use, like Mexico, Hawaii, Alaska, etc.. Depending on where you are at, of course
Posted May 10, 2010 · 03:34 UTC#290
Sorry, I can't recall exactly what the errors say, in fact, many times it doesn't mention an error but just indicates that it only loads about 15% of a file then moves on to the next and only loads a small portion of it and when all is said and done it, my GFX folder is only about 47 MB. Makes sense that I probably need more room. I'll try deleting some maps and free up some space and hpoefully that will solve the problem. Thanks to you & Chuck!
Posted May 10, 2010 · 12:04 UTC#291
Just DON'T FORGET to make a complete backup of your "My Flash Disk" folder before deleting anything :mrgreen: .
Posted May 10, 2010 · 16:08 UTC#292
Abb, regarding my PM to you, is it difficult to grey out the unavailable buttons when there is no GPS, instead of make them completely disappear?
I saw your #2 or #3 BMP thing with PhotoShop in the previous posts, but don't know whether they can apply to this.
Sorry to bring this up all the times but I frequently lost GPS because of the underground parkings and tunnels :mrgreen: .
Posted May 10, 2010 · 16:43 UTC#293
No, that wouldn't work as the visible model is still GPS Valid, meaning that the button will remain invisible unless there is a GPS signal. Actually, the icons dissapearing is a good thing. If they were up all the time, you would not know when you have a GPS signal or not. My GPS comes up immediately in my car, so I dont even notice it, but in my home, it takes 30 sec or more to get a GPS signal, so, I actually want that so that I can see when the GPS is active. I tried your idea about combining the invisible icons together and it works good. I will put it in my next release :)
Posted May 10, 2010 · 17:58 UTC#294
But I was hoping that the PS #X function of the BMP image could (when combining with scripts), instead of linking to the visiblemodel="", link to some kind of grey out function that make the icons unselectable, monochrome, let say, instead of colorful. This way the line of icons will always be full.
I thought that this function is available.
Posted May 10, 2010 · 18:18 UTC#295
Hi Abb,
So far so good with my modding.
For some reason i cant change the color of the clock letters and the nav text. Does that have to do with the street color and name mod?
I also have a question regarding what this is for? ....onclick='run sc_NaviMenuAlphaRestore' ....
Just wanted to know if this has something to do with the fade of the buttons and if i should be adding that to any new nav.ui buttons I add and doing the same in the nav.ui in the common folder.
thanks
Posted May 10, 2010 · 18:22 UTC#296
No, the 'visiblemodel=' overrides all. Like I was saying though, if all icons are full, you would never know if you have a GPS signal or not. Eg. sometimes in Toronto, with the skyscrapers which will block out a GPS signal, you would not know of your GPS Status, if all icons were present.
Posted May 10, 2010 · 18:52 UTC#297
Yeah Abb, I understand what you are saying but I believe that you didn't understand my idea of the greyed out or monochrome and unselectable icons.
:wink:
Posted May 10, 2010 · 19:55 UTC#298
:wink:
No, I tried putting an inactive button with the visiblemodel=GPSvalid and it did not show up at all, there again, the way that the script reads is that unless the GPS signal is there, no button (icon) will be present
Posted May 10, 2010 · 20:28 UTC#299
That is normal behavior. You have to remove the dependency with the "visiblemodel=gps.valid", so the greyout icon will be shown without regards to the GPS signal, but unselectable. :wink:
This is what I did for one or two icons in the navigation_800_480.ui file that I PM you last week (the dependency removal but not the greyed out icon). You can do the same.
In my opinion, this will make your mod much nicer, for many.
Posted May 10, 2010 · 22:55 UTC#300
I tried that and the grey did not show simply because there NEVER is an inactive button, in the NAV, they are always active, so the colored image would show and not the grey. I tried removing the visiblemodel, but the grey would still not show, just the normal colored version
Page 12 of 29
