FX3.1 Complete Firmware Image
By Retell · May 09, 2010in Hacks/Mods💬 895 posts👁️ 443,952 views
Page 3 of 36
Posted May 12, 2010 · 19:03 UTC#51
This upgrade is terrific. I have it now on my F90TB. I do have an issue that I could use some help with and that is, when I increase the volume, the unit scrolls through all of my Sirius stations. One click of the volume sent the station changing well over 200 times before I turned the unit off and restarted it.
Any ideas of what can be done to resolve this and also some advice on enabling the branded POI on the map? I have checked just about every option and cannot find anything that displays the branding icons.
Posted May 12, 2010 · 19:17 UTC#52
Did you make a search before asking? Thera are lot of talks in this forum regarding Branding.zip.
This will answer pretty much what you are asking for: http://avic411.com/forum/viewtopic.php?f=34&t=18428
Posted May 12, 2010 · 19:48 UTC#53
Does anyone know if FX3.1 will be on newsgroups? My ISP blocks all torrents, it has been years since I used them..........
Should iGO.8.v8.3.2.80621. work? I can get hold of that.
Posted May 12, 2010 · 20:51 UTC#54
I thought I did search well enough but as you can tell by the ease of finding the information, I did not do a good enough job...
Posted May 12, 2010 · 22:48 UTC#55
I have downloaded the fix on SD card and followed the steps but when I get to step 4. select update SD format it gives me 4 choices 1 is update wince sd/mmc (format) when I press that it tells me cant find winceimc.cks file. What am I doing wrong? This is all new to me any help appreciated.
Posted May 12, 2010 · 23:18 UTC#56
2fup and sgambino . Reformat your SD card as Fat32 filesystem and recopy the files the card and restart update process from the begining. That should fix everything :D
kj42598 I don't have a Sirius Tuner or any external tuner for that matter, for now all I can suggest to you is to reformat your SD and try it again like the 2 fellas above. Just to completely rule out an install error. I should have a sirius tuner soon that I can play with, If the 2nd time around install doesn't help just go back to regular 3.0 for now, do you have a copy?
godskitchen I believe someone will be putting this on rapidshare soon, if it doesn't go up in a few days I will personally upload it. :mrgreen:
Posted May 13, 2010 · 00:14 UTC#57
Complaining is not my intent, no harm and enjoy modding :mrgreen: .
Posted May 13, 2010 · 02:52 UTC#58
Retell, i appreciate the help. i just tried your suggestion and that screen still appears. but this time i left the sd card in after i reset it for 5 seconds, and it seems like the pioneer logo comes up, then that screen come up, then it resets automatically with the pioneer logo, then goes into windows ce. is that supposed to happen? am i supposed to take the sd card out? im stuck now, i have read that it may have something to do with the polarity, so worst case scenio, i will take out the unit and mess around with the unattached wire.
Posted May 13, 2010 · 03:20 UTC#59
If you left the SD card in with the Testmode folder, then it is normal that it goes into the WinCE screen again. You have to remove the SD card with Testmode folder stored to let AVIC boot to the main screen.
Posted May 13, 2010 · 04:15 UTC#60
Is the "safety cam" mod working for anyone?
Also, how do you switch "voices" without a complete reset?
Posted May 13, 2010 · 08:22 UTC#61
Thanks, it turns out I was able to use a friends connection to dl the files. Have not put it on the unit as yet but will report back when I do with the Euro maps.
Posted May 13, 2010 · 09:18 UTC#62
I have installed the image.
deleted all the US maps from maps directory.
Dl maps of europe given in this thread
Woola!
ITs working
Thanks for the upload again.
Regards
Shaz
Posted May 13, 2010 · 10:17 UTC#63
Woola!
ITs working
Regards
Shaz
Good to know, what unit are you running?
Posted May 13, 2010 · 15:22 UTC#64
F700 bt US version
Working in UK
Posted May 13, 2010 · 15:39 UTC#65
Anybody know the difference(s) between the US FW 3.0201 and the european FW 3.0202?
Thanks.
Posted May 13, 2010 · 16:08 UTC#66
I installed a fresh copy of 3.0. The one issue I cannot find a work around for is, when I turn the volume up or down, the Sirius stations begin to scroll after a one click turn of the volume control in either direction. Anyone have any suggestions?
Posted May 13, 2010 · 16:21 UTC#67
The short answer is NO. Pioneer AVIC use ezrider.exe to load the iGo navigation software instead of iGo.exe, because there are hardware related code within the loader.
Posted May 13, 2010 · 16:35 UTC#68
:? if i change firmware to fx3.1 in 900bt menu have change to menu like avic fx3????
please some screanshots.
Posted May 13, 2010 · 17:10 UTC#69
The menu system will be the same as those of X710BT and X910BT.
Posted May 14, 2010 · 04:04 UTC#71
Anyone? Bueller?
Posted May 14, 2010 · 15:43 UTC#72
To be exact, EZRider is iGO specially built by NavNGo for Pioneer.
Regular iGO can be used, supposedly, with a special ezrider stub that includes support for Pioneer-specific commands. Our Russian friends made good progress on that, but when I tried it here, MSNDirect did not work, so I have not paid much attention to it afterwards...
Posted May 14, 2010 · 18:40 UTC#73
I did the install all went well, How ever now when i add an address or destination i get an error message and then it reboots?
Posted May 16, 2010 · 14:20 UTC#74
I am attempted to update my F500BT US version. will it work, any one has tried? :?::?:
Posted May 16, 2010 · 15:04 UTC#75
will this work on the f500bt?
Page 3 of 36
