MB-3DCars1.0 Add-On up to 1.1a -07/14/10 UP-
By misterblue · Jun 22, 2010in Hacks/Mods💬 108 posts👁️ 22,078 views
Page 2 of 5
Posted Jun 24, 2010 · 03:12 UTC#26
Sorry for being vague. I have 3d cars working, I am talking about how to add this add on so that i can adjust the car settings. I just basically am looking at where the ui files go and those images. dont mean to be a pain.
I dont know, I adjust the car settings manually in the SYS.txt. It is too easy. I dont trust .exe files as it does everything for you and then you dont know what it has done when things get messed up. I prefer to do this manually as it is so simple that an .exe file for this is really not necessary. That is just my opinion though
Posted Jun 24, 2010 · 03:30 UTC#27
I understand now I agree with you
Posted Jun 24, 2010 · 16:33 UTC#28
Where do you get the 3D cars from? I am looking for a pickup truck and can't find one.
Hey gnasr,
Still no pickup truck....must be very difficult to model one! Just out of curiosity, what kind are you looking for?
I myself am looking for a late model F150.
Redeye
Posted Jun 24, 2010 · 16:56 UTC#29
Deleted files. 06/24/10
I note that this add-on does not interest many people because the only subjects who post merely to sting only models 3Dde this add-on for manuellemen manually put in their notice and continue to manually change their sys.txt. In this case, find your own 3D models!
If you do not know Poas, take also the setting that I built in my sys.txt and allows better positioning on the GPS map 3D.
I do not appreciate people who do not respect other people's work!
For over a year that I come on this forum, I see that there are more skinners than modders ! The problem is that many skinners say they modders lol !
Posted Jun 24, 2010 · 16:59 UTC#30
Hey gnasr,
Redeye
I guess no one likes trucks. I am looking for a chevy 1500 silverado or any type of pickup truck.
Posted Jun 24, 2010 · 18:36 UTC#31
Hey MB,RESPECT!!I have installed your mod and tried it (and 3D cars)and they work just fine,thank you.I needed a couple of attempts to save my settings(ie move the SAVE folder)but after that it is fine.The only minor thing I have noticed is that on the route planning screen it shows remove(-) destination,remove via ets when it should say ADD(+) destination.add via etc.It also shows the same problem when you come to remove start,remove destination etc,it is showing + instead of -.I hope you can understand what i am saying!Thank God you and Abb are around to keep this forum going!All the best to you.
Posted Jun 24, 2010 · 18:52 UTC#32
Dont' really understand what you are saying, but if you are looking for a compliment, then you did a great job. Not really sure who is disrespecting you, but I am not a modder, just a copier and I was just wondering where you got those 3d cars and how to make a pickup truck. If anyone has any info that would be great.
Thank you
Posted Jun 24, 2010 · 19:01 UTC#33
I'll check this but it is definitely a problem with your backup files. I did not have this issue and users of my forum does very promptly report anything about it.
Posted Jun 24, 2010 · 19:04 UTC#34
@ gnasr74, I accuse you of anything.
Posted Jun 24, 2010 · 19:35 UTC#35
misterblue,
I too echo gnasr when I say that yours is a great add-on. I apologize if I offended you when I mentioned "no pickup truck". I've been looking for a 3d model of a pickup for a long time and thought with the additinal models that you offered, there might be one there. I'm not a modder and don't have the skills to model one or I would do it myself. Keep up the good work!
Redeye
Posted Jun 24, 2010 · 19:55 UTC#36
misterblue,
Redeye
Redeye Have a look here.http://www.igo8mods.com/dimka_download.htm
Posted Jun 24, 2010 · 20:03 UTC#37
Again I am not sure if I offended you due to your broken english, but like I said thanks for all your contributions. You are doing a great job.
Posted Jun 24, 2010 · 20:40 UTC#39
Thanks ovalball! I'll check it out
I looked there are tons of cars but still not pickups.
Posted Jun 24, 2010 · 20:56 UTC#40
How about one off the TomTom site?It might be possible to use/convert one of thier pick ups to use on the IGO.I don't know but i bet Abb does!!!ITT has pick up trucks..loads of them.
Posted Jun 24, 2010 · 21:07 UTC#41
From my research, it seems Gurjon be the first to create this add-on but it is possible that I am wrong.
I indicated in my first topic
The problem is mainly to find software that supports the format for iGo mdl. I found their use was not easy.
There is no problem, I do not feel offended by your posts. This is how my works have begun to be diverted me irritated. Since all interest of this add-on is being able to change when you want 3D vehicle while being able to choose the size you want, avoiding all that tedious manipulations under TESTMODE
Excuse my bad language, I do my best :roll::wink:
@ gnasr74, In MP you have indicated that you have 3D models. This is version Fr (no time to translate, Google Translate is your friend :wink: ) my instructions to add or remove models of your choice (it's pretty simple). If you have trouble, send me your files and I'll see if we can correct them.
Vous pouvez parfaitement compléter la liste des véhicules 3D.
Pour ça, il vous faut au moins 2 fichiers :
xxx.mdl
xxx.tex
Ces 2 fichiers doivent porter le même nom. A l'aide d'un éditeur hexadécimal, il faut vérifier en début du fichier xxx.mdl, que le nom de fichier .tex indiqué porte bien le même nom de fichier.
exemple :
si xxx.mdl contient xxx.tex = c'est bon
xxx.tex = c'est bon pour tout
si xxx.mdl contient xyx.tex = pas bon
xxx.tex = le fichier .mdl ne va pas trouver le fichier qu'il lui faut, dans ce cas corriger le nom .tex indiqué dans le fichier xxx.mdl. Attention vous ne devez pas changer le nombre de caractère.
Pour compléter la liste des véhicules il suffit de placer les 2 fichiers de véhicules dans le dossier 3DCars se trouvant dans :
My Flash Disk\APL2\iGo\3DCars
De préférence, il faut aussi une image xxx.bmp à placer dans :
My Flash Disk\APL2\iGo\3DCars\bmp
Elle servira de vignette de sélection. Si ce fichier ne porte pas le même nom que pour le .mdl et .tex auquel il correspond ou si ce fichier bmp n'existe pas, le système affichera une vignette "vide". Vous pouver créer cette image en respectant la bonne taille..
Si vous possédez aussi les fichiers (facultatifs) :
xxx_ghost.mdl (parfois aussi xxx_ghost.tex)
xxx_night.mdl (idem xxx_night.tex)
xxx_grey.mdl (idem xxx_grey.mdl)
placez-les dans leurs dossiers respectifs se trouvant dans :
* Une fois les nouveaux modèles placé dans votre avic, accéder à la page de choix des véhicules puis cliquer sur "Scanner Liste", une nouvelle liste est ainsi créé.
* Pour une suppression de modèle xxx.mdl, xxx.tex, xxx.bmp etc... (sous Testmode) il est impératif de supprimer la liste des véhicules en cours. Sinon vous aurez un plantage de l'avic au moment du prochain accés à la liste des véhicules.
La suppression de la liste se fait dans :
My Flash Disk\APL2\iGo\Save\userlists\
- effacer le fichier 3DCar_list
Au prochain accés à la page de liste des véhicules, cliquer sur "Scanner Liste" pour en re-créer une nouvelle à partir des modèles actuellement dans votre avic.
Posted Jun 25, 2010 · 01:13 UTC#42
It is not any of you that he is pissed at, it is me. He left me a derogatory PM. I guess that he didn't like me explaining how to install his 3D cars in other mods manually. I really didn't understand it because I spent weeks doing up my schemes (and trust me, they were a lot of work), and I didn't care what mod they were used in. I even explained to one member step by step how to make my schemes work in the mod that he was using. I dunno? I just thought that we were here to help each other
Posted Jun 25, 2010 · 11:27 UTC#43
@ abb1, Yes, we're here to help. But what about the use of this add-on that took me many, many hours to run on AVIC This also includes the scripts that I modified and the ones I created to make this add-on practical use (resize models). If my work is what you have learned could be used in the GFX folder iGo folder in interesting you in my mod you would have also noticed that I used an audio folder in the iGo folder. The principle is to be able to update some files without having to modify the data.zip every time.
The problem with messages on how not to use my add-on that they had nothing to do in this topic. For this you enough for sharing your discovery in the topic for your mod, since you seem to have understood all interest of this add-on that can easily be supported by any other mod (I 'I wanted it).
@ gnasr74, Do you understand how to update models of vehicles ? Otherwise, I'll translate the proceedings.
Posted Jun 25, 2010 · 11:40 UTC#44
Good morning Misterblue, can you please post your MB-3DCars Add-On, Thanks.
Posted Jun 25, 2010 · 12:09 UTC#45
@ sirseven, files are reactived in first topic.
Posted Jun 25, 2010 · 13:53 UTC#46
I did translate what you sent me through google and I understand how to add 3d cars, I have had 3d cars working with my files for a while, I just don't understand if it is possible to make a pickup truck 3d model. I do not know how to make those .tex and .mdl files. As of now I am using the jeep car but would like a pickup truck. I noticed you had some new cars in your file and was hoping you knew how to make those 3d cars. Anyway Thanks for your help though.
Posted Jun 27, 2010 · 12:19 UTC#47
MB - Looks like a really nice addition. Since I do use my own zip, I don't think I'll be able to take advantage of your hard work unless you separate it from the MB mod.
Posted Jun 27, 2010 · 18:49 UTC#48
UPDATE 06/27/10
This update to avoid a copy of the file save in APL2\iGo\ . It was one of my biggest single problem in running this add-on on our Avic. I find a solution but requires copying save folder in APL2\iGo\ and also the change of parameters in the automated file sys.txt.
Now save folder remains in place decided by Pioneer in User\UserData\iGo\ and add-on works without problems.
For those who already Install version MB-3DCars-1.0, you just take 3DCarList.mscr file from the archive downloaded MB-3DCars-1.1 and replace the existing file in APL2\iGo\3DCars\. And then if you want to keep your last GPS option settings, make a copy of save folder APL2\iGo to replace one that must already be in User\UserData\iGo\
The replacement file sys.txt is optional. If you keep your own, to start the AVIC, go to the page of vehicle choice and then click Init., The AVIC restarts and hop everything is ok.
For the others, and those who have already installed version 1.0, go to in which first topic are the download archive and read new installation procedure.
Posted Jun 27, 2010 · 18:55 UTC#49
I already explained that this add-on (as its name suggests) is not exclusive to the mod MB-IDT3.0-4x. I leave it open to other modder to integrate into their mod a few lines of code needed to support this add-on. Those who would be unable to identify lines of code included in my mod, can contact me by PM for that tell them what it takes for them mod to handle this add-on.
Posted Jun 29, 2010 · 00:24 UTC#50
hi, thanks for the mod! LOOKS GREAT!
Any chance you will be able to add a 2005-2008 GT Mustang ? Just wondering...
thanks!
Page 2 of 5
